Question about IBM eserver xSeries 220 8646
We need To Install Another Processor But The 2nd Slot Doesn't Work
2 Suggested Answers
  • 143 Answers
SOURCE: We need To Install Another
hi,
Welcome to Fixya
By the way have you purchased the VRM module . If you are about to upgrade the server with second processor you should have VRM also . Without VRM , the second process wouldn't work and it will light out amber LED(Orange) . Now If you have VRM then just swap the processor and check. That is check whether the second processor works while insert it in first processor slot. If it works then it relates to motherboard issue .
Thanks
Posted on Mar 05, 2011
Looking at DS Lite for granddaughter and this granny doesn't know squat about these systems
As far as i know ds lites will play ds games (in the back) and gameboy advance games (in the front) the gameboy advance slot usually has a cover on it you pull off.....If its not working all the time buy some compressed air in a can and blow out where the games go....hope this helps.
Mar 27, 2012 | Nintendo DS Lite
I want to be know what is compatible with AOpen s651m motherboard. i'm kind of an ammature, so please help.
AOpen S651M motherboard:
1) Processor Support:
Uses Intel processors that fit in a Socket 478 processor socket,
http://en.wikipedia.org/wiki/Socket_478
The Processor has the contact pins (478 of them), and the processor socket has the socket holes. (478)
The Maximum FSB supported for the processor is 533MHz.
(Front Side Bus, 533MegaHertz)
Processors supported;
http://en.wikipedia.org/wiki/List_of_pentium_4_processors#Northwood_.28130.C2.A0nm.29
Start with the Northwood Core models shown in the link above.
The ones that have a Front Side Bus of 533MT/s, and fit in a Socket 478.
The few shown in the next chart, Prescott (90nm), may not work. The voltage requirement.
2) Ram Memory Support:
DDR Sdram that operates at 333MegaHertz, or commonly known as PC2700.
TOTAL Maximum Amount is 2GB.
There are two ram memory slots. The Maximum Amount for EACH ram memory slot is 1GB.
If you only have one ram memory module ('Stick') place it in Slot 1. (DIMM 1)
This is the ram memory slot that is closest to the Processor.
[ The Processor 'sees' ram memory Slot 1 first ]
Graphics Card Support:
The graphics expansion slot on the motherboard is an AGP slot. (Advanced Graphics Port)
It uses the AGP 4X technology.
Above the 3 white PCI slots is the brown AGP slot.
Use AGP 4X/8X graphics cards.
(These types of AGP graphics cards can be used in an AGP 4X slot, or an AGP 8X slot)
Example of a AGP 4X/8X graphics card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814139053
Another one,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161318
,and yet another one,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161337
For additional questions, or to have me clarify anything I have stated above, please post in a Comment.
Regards,
joecoolvette
Sep 24, 2011 | AOpen S651M (918EM10S50) Motherboard
Just installed mobo ms-7091 m atx but find it as no video out ports how do i get a picture.i know its old but its my first attempt at building pc can i just install a graphics card.
I found the user manual here :
http://217.110.237.70/Manuals/Medion%208383XL%20mit%20MS-7091.pdf
Your motherboard provides 1 pci-express x16 slot, so you will need to install a pci-express video card.
Try to get a video card that doesn't need to be powered by the power supply. There are some out there that don't need to be powered, but .....
Most, but not all, pci-e video cards need to be plugged into your main computer power supply to work. If your power supply was designed to power a pci-e video card, it will have a 6 pin pci-e power connector to connect to a pci-e video card. If your power supply doesn't have this connector, you should replace the power supply with one with the pci-e power connector.
Sep 10, 2011 | Computers & Internet
Hi. I have a P8H67 ASUS mother board. it has two PCI 16 Express slots. the first slot is Blue and second slot is black. When I put my 1 GIG DDR2 9500 GT graphic card in the first slot, it gives me 3 beeps...
There are 4 types of expansion slots on this motherboard.
The expansion slots on this motherboard are as follows.
Expansion Slots 1 x PCIe 2.0 x16 (blue)
1 x PCIe 2.0 x16 (x4 mode, black)
1 x PCIe 2.0 x1
1 x PCI
Sep 03, 2011 | ASUS US P8H67M PRO Desktop Motherboard...
When i give a print command this error apears on the paper : pcl xl error subsystem:kernel error:illegaltag operator:0xfe
1st: turn off your printer, wait 5 minutes, turn on again. Try to print again and see if the problem is solved. If this doesn't work:
2nd: de-install your printer from your computer, download the latest driver for your operating system, install your printer again. And if this doesn't work, download the latest HP Laserjet generic driver and install it again.
You can find the drivers on the support page from HP, searching for the model printer that you have and select the driver for your operating system (windows xp, vista, 7..)
Aug 07, 2011 | HP LaserJet 1320n Printer
What is the processors that can be compatible for Intel motherboard
Confirm your motherboard's compatibility with the Intel CPU you want to install. Motherboards typically only support one type of CPU slot, so purchase an Intel processor that is compatible with that slot.
Ensuring your processor and motherboard are compatible is vital when choosing parts to build your own computer system. If they are both the same socket type, they will most likely work together.
Brands
There are a plethora of motherboard manufacturers, but only two main processor manufacturers: AMD and Intel.
Every motherboard, regardless of manufacturer, has a socket that will accept a processor.
Intel
Common Intel socket types include LGA775, LGA1156 and LGA1366. Older models include PGA370, PGA423 and Socket 479.
Your motherboard and processor will be generally compatible if their socket types match. ...
Intel Core 2 Quad Q9650 Processor Compatible Motherboards
Hope this will help you and please don't forget to rate me. Thanks for using FixYa
Aug 02, 2011 | Intel Motherboard
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
We need To Install Another Processor But The 2nd Slot Doesn't Work To new one That Work In the other slot
hi,
Welcome to Fixya
Thanks
Jan 27, 2011 | IBM x3400 Server
Problem with upgrading processor
Sounds like the processor you're trying to upgrade to isn't the same frequency. The processor, motherboard, and memory have a matched frequency. For example; a motherboard with a frequency of say PC4200 will only accept a processor and memory of a PC4200 frequency. If you try to use PC5300 memory it basically won't do anything, blank screen, or maybe a beep. The same if you tried to use a processor with PC5300 on the PC4200 board. The best way to find the frequency rating is to look on the memory. They class the memory by frequency, but rarely ever list the frequency for the board or processor. Research the new processor to find out the memory class and then see if it matches the memory in your machine. If it doesn't then the processor won't work. If it does, then new processor may not be compatible, and that means more research.
Jul 18, 2008 | Shuttle AV42 Motherboard
2nd slot issues
IBM's may need a bios update to read the 2nd slot do that first, and then check your setup for both slot availabilty. IBM always has, and always will make your life interesting.
got backup for your IBM Thinkpad?
Feb 16, 2008 | IBM ThinkPad T30 2366 Notebook
IBM eserver xSeries 220 8646 Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
