Wish to use kogi 17 inch tft monitor for a tv
  • I'm sorry I didn't explain that I connected, via the vga, a digital tuner equipped DVD/VCR (Magnavox ZV45OMW8), and got no results. I have ascertained that the monitor still works as a computer monitor by connecting to a Vista laptop. The monitor had been used with an XP desktop. Sorry that I was away; thanks to mahesh jawahar for your response.
xMadx
  • 64 Answers
SOURCE: Need drivers for a KOGI L7CH 17" LCD monitor
These guys should be able to set you up with the drivers for your monitor.
http://members.driverguide.com/driver/detail.php?driverid=154093
Posted on Jan 22, 2008
SOURCE: mo picture on monitor
I had the same problem. power led would flash green for a few minutes then the monitor might come to live. the problem was multiple bad G-LUXON capacitors on the power supply board and inverter. the monitor is full of them. just search online for bad caps and they are near the top of the list. replaced them and it came back to life.
Posted on Jan 14, 2009
  • 135 Answers
SOURCE: Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Posted on Feb 24, 2009
  • 3 Answers
SOURCE: kogi 17'' flat screen monitor
there are four(4) buttons on your monitor to the left of the on/off switch.
Press the first one to the left of the off switch, which will bring up a menu, so you can select
bright or volume, screen size, etc; Next, there are two (2) buttons to the left of the first left button
that you can push to adjust brightness, size, vertical, etc;
Posted on May 09, 2009
  • 7 Answers
SOURCE: Dell E173FPf 17 vertical line problem
Yes, but the cost is not worth it. If you get it apart you will no doubt find a couple of bulging capacitors. Dell site has the disassembly instructions.
Posted on Oct 10, 2009
How do you change the resolution on l7eh Kogi 17" monitor. Cannot change manually or in Display
install an AGP card into an AGP slot then you can see the high resolution. internal display card does not support to high resolution because of insufficient memory .use 8X AGP card for better result
Apr 12, 2010 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
I just hoolked up a Kogi l7 eh 17
It may be that your video card is too old, that probably is the problem since you are running Windows 2k. If not open up your monitor's menu and see if you can manually change the monitor's resolution. Newer monitors do that.
Need driver for L7EH-TA Kogi Monitor
nee driver for L7EH kogi monitor. built in speakers don;t work
Nov 22, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi 17'' flat screen monitor
Apr 03, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Cables for the KOGI 17"
Any Computer Electric Plug Will Work But The Cable For The Screen To Hook To The Computer Can Be Bought On Ebay, Circuit City, Radio Shack, Best Buy Wal-Mart Even.
Jan 05, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
My Kogi 17 inch monitor illuminates for 2 seconds and then the light goes out. The monitor is still on but hard to see. Each time you power cycle the monitor, the display appears normal for exactly 2...
Hi and welcome to FixYa,
Initially, lets try determining which is at fault.
  • power supply (unlikely) - the unit powers up, even after the display going off, the monitor is till on;
  • LCD screen (possibly) - will have to be determined later;
  • CCF Lamps (backlights) and/or inverter (most likely) - a check; power on the unit, run through the routine, change channels etc. with a flashlight shine obliquely against the screen. If with the use of the flashlight a darker semblance of the desktop could be seen, then you have just confirmed that it is either the CCFL or the inverter and definitely not the LCD screen.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 08, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi l7eh-ta ko 17 in. Flat
dear,
you can get driver from the company for which it belongs..
try to search in its website link..
regards,
Aug 09, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi monitor bulbs blink on and off
ok,
remove the vga cable from pc and connect it again while running..
regards,
Feb 01, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
