Question about Ricoh Aficio 1018D Copier
SC922 Error Need help on error code sc922. I unplugged the imb and the put back in and there is still an error.
  • Heath May Feb 23, 2012
    + Add a Comment
  • Ricoh Expert
  • 155 Answers
922 B IMB DRAM error
The machine detects a discrepancy in
the IMB DRAM write/read data during
its write/read test (done at power off/on
and at recovery from low power or
night/off mode).
• IMB defective
• BiCU defective
• Poor connection between BiCU an IMB
might be time to replace copier for what it cost to fix it.
Posted on Mar 06, 2015
What is an error code e-68 on a galaxy series dryer mean
E68 error code is a stuck button error code. You can try to wiggle each button on the control panel to make sure they are all functioning freely. If so, then unplug the dryer and leave it unplugged a couple minutes then plug the dryer back in to clear the electronic panel's error code. If the panel still shoes E68, then you'll need to replace the panel. Part#134557201
Hope this helps!!
Jun 13, 2016 | Dryers
How to fix the error code for Ricoh 1232c sc517 and how to clear it
there's no error code like that
http://www.unitedtechsonline.citymax.com/page/page/4653767.htm
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER)
384-385:IMAGE DATA TRANSFER PROBLEM WHEN TANDEM IS USED(SBU,INTERFACE
BOARD,SICU,PRINT CONTROLLER)
390:TANDEM IMAGE DATA TRANSFER ERROR(NOISE,SICU,INTERFACE BOARD)
391-392:IMAGE STORAGE ADDRESS ERROR(SICU391-01)
395:CD-R/RW ERROR, INTERFACE BOARD ISSUES
397:CD ACCESS ERROR
398:CD-R/RW DATA ERROR
400:TRANSFER BIAS ROLLER ISSUES
401:TRANSFER ROLLER
430:QUENCHING LAMP ERROR
440:DRUM MOTOR LOCKED
441:DEVELOPER MOTOT LOCKED
491:LASER COOLING FAN LOCKED
495:TONER BOTTLE PROBLEM
496:TONER COLLECTOR BOTTLE PROBLEM
501:LIFT PROBLEMS FOR TRAY 1
502:LIFT PROBLEMS FOR TRAY 2
503:LIFT PROBLEMS FOR TRAY 3
504:LCT 1ST TRAY PICKUP OR LIFT PROBLEM
505:LCT 2ND TRAY PICKUP OR LIFT PROBLEM
506:LCT 3RD TRAY PICKUP OR LIFT PROBLEM
510:PAPER FEED MOTOR PROBLEMS
511:LCT MOTOR PROBLEM
515:TANDEM REAR FENCE MOTOR PROBLEM
520-521:DUPLEX JUGGER MOTOR PROBLEMS
531:FUSING DUPLEX MOTOR LOCKED
532:RELAY MOTOR LOCK
541:OPEN FUSER THERMISTOR
542:LOW FUSER TEMPERATURE
543:HIGH FUSER TEMPERATURE
544:HIGH FUSER TEMPERATURE
545:HIGH FUSER TEMPERATURE
546:LOW FUSER TEMPERATURE
547:ZERO CROSS PROBLEM
550:WEB EXPIRED
591:TONER SUPPLY MOTOR PROBLEMS
592:TONER BANK MOTOR PROBLEMS
601:SBICU TO SBU COMMUNICATION PROBLEMS
602:SBICU TO HARD DISK DRIVE BOARD COMMUNICATION PROBLEMS
620-622:SBICU TO ADF COMMUNICATION PROBLEMS
625-626:BCU TO FINISHER COMMUNICATION PROBLEMS
630:LINE ADOPTER TO CSS CENTER COMMUNICATION PROBLEMS
640-645:BCH TO SICU COMMUNICATION PROBLEMS
646:SICU PROBLEM
650-653:COUNTER ERROR JAPAN
701:ADF P/U ROLLER PROBLEMS
702:ADF FEED MOTOR PROBLEM
703:ADF TRANSPORT BELT MOTOR PROBLEM
704:ADF EXIT MOTOR PROBLEM
705:ADF ORIGINAL TABLE LIFT ISSUES
720:FINISHER LOWER TRANSPORT MOTOR ISSUES
722:FINISHER JOGGER MOTOR ISSUES
724:FINISHER STAPLER HAMMER PROBLEMS
725:FINISHER STACK EXIT MOTOR PROBLEMS
726:FINISHER SHIFT MOTOR PROBLEMS
727:FINISHER STAPLER ROTATION PROBLEMS
729:FINISHER PUNCH MOTOR PROBLEMS
730:FINISHER STAPLER MOTOR PROBLEMS
735:FINISHER PAPER STACK PLATE MOTOR PROBLEMS
736:FINISHER EXIT GUIDE MOTOR PROBLEMS
737:FINISHER FULL STAPLER HOPPER
738:FINISHER SHIFT TRAY LIFT MOTOR PROBLEMS
739:FINISHER FOLDER PLATE MOTOR ERROR
740:FINISHER FRONT SADDLE STITCH STAPLER MOTOR PROBLEMS
741:FINISHER REAR SADDLE STITCH STAPLER MOTOR PROBLEMS
742:FINISHER JOGGER SIDE FENCE MOTOR
750:COVER INTERPOSER BOTTOM PLATE MOTOR PROBLEMS
800:VIDEO OUT TRANSFER,CONTROLLER BOARD
804:VIDEO OUT TRANSFER,CONTROLLER BOARD
818:OPTIONAL BOARD,CONTROLLER BOARD, SYSTEM PROGRAM
819:BAD SOFTWARE
820:CONTROLLER BOARD OR SOFTWARE
821:CONTROLLER BOARD
822:HDD PROBLEM
823:NIB, CONTROLLER BOARD
824:CONTROLLER BOARD, NVRAM
825:NVRAM ERROR
826:NVRAM
827:CONTROLLER BOARD, RAM
828:SOFTWARE,ROM,CONTROLLER
829:RAM, CONTROLLER
835:CONTROLLER,CENTRONIC LOOPBACK CONNECTOR
836-837:FONT DEVICE
838:CONTROLLER BOARD
850:IP ADDRESS,CONTROLLER BOARD,NIB
851:1394 I/F CONNECTIONB,I/F INTERFACE,CONTROLLER BOARD
860-861:HDD
862:HDD BAD SECTORS
863:HDD
864:DATA TRANSFER ISSUES
865:HDD
900:NVRAM PROBLEM.ELECTRICAL COPY COUNTER
901:MECHANICAL COUNTER ISSUES
921:IMB, BICU FAILING
922:IMB, BICU FAILING
924:DRAM,BICU,IMB FAILING
925:BICU, IMB FAILING
926:BICU, IMB FAILING
951:F-GATE SIGNAL ERROR PROBLEMS
953:SCANNER IMAGE SETTING ERROR ISSUES
954:PRINTER IMAGE SETTING ERROR ISSUES
955:MEMORY SETTING ERROR ISSUES
964:PRINTER READY ERROR ISSUES
966:POLYGON MOTOR PROBLEM
970:SCANNER READY ERROR
980:HDD ACCESS ERROR
981:BICU, NVRAM
982:HDD CONSTRUCTION ERROR
984-987:HDD DATA TRANSFER ERROR
990:SOFTWARE PERFORMANCE ERROR
991:REBOOT SOFTWARE ERROR
997-998:DIMM, RAM ERROR
999:PROGRAM DOWNLOAD ERRORS
Oct 29, 2008 | Ricoh Office Equipment & Supplies
I have a ge air conditioner model AHM24DPH1 WITH an error E2 / E1. What do I do to possibly fix.how do I reset maybe
E1 is humidity sensor error unplug unit and then plug it back in.
E2 is Temperature sensor error unplug unit and then plug it back in this will clear codes. if codes come back on then you will need to replace sensors.
Jun 24, 2014 | Heating & Cooling
Dear i got a functional problem (sc922) how can i fix it? if any one can help me.
sc922 can be caused by:
  1. Poor connection between IMB ab Bicu
  2. IMB defective
  3. Bicu defective
unplug the machine from the power source, you need to remove the Dram and the IMB and reinstall again, becareful don't touch the Dram and the IMB with your fingers you can damadge them by your body electrostatic charge.
Dec 27, 2010 | Ricoh Aficio 1018D Copier
Have a partial red ring. in the 4th controller position, with a E 73 code on the screen. how do i fix it?
3 ways to fix the Xbox 360 E73 error
1. Restart your console.
2. Unplug all AV cables, and also unplug the power cord from the wall socket. Once that's done, plug them all back in correctly, and put your console back on.
3. Take out the hard drive, and put your console on. If the troubleshooting error has been gone, put your console off, and get the hard drive in again. Than put your console back on.
If these tips didn't fix your Xbox 360 E73 error, you will have to open up your console, and fix the problem from within. You can do this by 2 ways. You either send it over to Microsoft, or you will actually repair the troubleshooter by yourself with a repair guide.
hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
Hello, ricoh aficio 1018d error code display sc 925 what can i do for it.
IMB non-connected error
Symptom:
IMB is not connected. This SC only
appears with B040 and B043 version
machines.
Possible Cause:
• IMB is not connected
• Poor connection between BiCU and
IMB
• IMB defective
• BiCU defective
Sep 27, 2010 | Ricoh Aficio 1018D Copier
On a ricoh aficio CL1000N, what does the error code SC922 or SC992 mean?
There is no sc922 for the CL1000N, but sc992 is a general software error. It typically shouldn't interrupt operation, but it if it does and it happens more than once, try to figure out what you were doing when it happened. Were you printing a big job? Were you printing a job with a particular font? Does it always happen at a certain time of day? Narrowing down the conditions can help to figure what is causing the error code.
Jun 30, 2010 | Ricoh Aficio CL1000N Printer
This is Cali222 with the IMB 161 and 163 error code,
hi there, yes, its an error code for ibm computer, it may be a hard disk or the hdd controller error. do some check up and test. ty
Feb 03, 2008 | IBM ThinkPad 380ED
Blinking orange light- will not power up
it could be a memory error (the beep you hear tells you what is the error code, 1 beep is usually a memory error. Go to http://www.customautomaticsystems.com/ShowArticle.aspx?ID=54 to learn more about computer P.O.S.T. and error beeps.
Also the fact that you kept you <processor??> clean. Does this mean you didn't put thermal paste on it? If so you definitely need to put some on there to help with heat exchange with the heatsink.
Alex
Dec 19, 2007 | HP HEAT SINK
137 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
