Question about Bosch WFK 2401
Bosch wfk 2401 how to clean filter?
I'm getting an error message code #3. The tech at ABT said it's medium-easy to fix but requires taking whole front off. Can anyone point me to a set of directions for getting the front cover off this washer and how to clean the filter? Many thanks.
  • 1462 Answers
SOURCE: Bosch Washer WFK 2401
leaks could be from anywhere. remove the top and back cover, put on a cycle and try to trace where leak is. sorry if this is not very helpful. water in filter should not smell. this may be due to using liquid detergent which causes a smell like drains if used over a period. put on a boil wash and revert to using powder
Posted on Jun 14, 2007
barkencoa
  • 3463 Answers
SOURCE: Bosch WFK 2401 Washing Machine On/Off Switch Replacement
TRy www.espares.co.uk/bosch
or www.bosch-spareparts.co.uk
If it runs o/k with the switch held in .\then all youneed is a new switch.
Plz rate my advice.
Thanks.
Posted on Jan 03, 2009
barkencoa
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
  • 78 Answers
SOURCE: Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Posted on Apr 20, 2010
Macmarkus
  • 2605 Answers
SOURCE: Bosch clothes washer model WFK 2401 with error
Welcome to FixYa.
Based on your description it sounds like a faulty door lock mechanism. As you may or may not already know the 06 error code for the WFK2401 Bosch washer indicates an error in the lock has been detected.
This is from the Bosch service tips I have, so you should be able to check it with this info...
I also have this available to you in "pdf" and I can send you if you want to provide an email address since the "pdf" cannot be attached or sent via these post's.
You can also run a self diagnostic/test program by following these steps I've laid out, then let me know what you find...I suspect a faulty lock as I alluded to though.
To enter test program for WFK 2401 washers:
1) Set cycle knob to any "X" (reset) position
2) Press and hold Pre-Wash and Start buttons at the same time. While still holding Pre-Wash and Start buttons, turn unit on by pressing On/Off button.
3) Keep holding Pre-Wash and Start buttons (only) until digital display comes on (~ 5 seconds).
**HINT: Turning washer off at any time will end test program**
When test program has been entered:
Start light will flash
Digital display will show 00 for no faults or will show fault codes below:
Let me know what you find as I said or if you require further assistance. Thanks for choosing FixYa for your repair inquiry and good luck
please rate the solution I provided accordingly.
Regards,
Macmarkus :)
Posted on Dec 29, 2010
Code 08 on bosch wfk 2401
Faulty door switch
Aug 27, 2014 | Bosch WFK 2401
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
What does flashing error code 2 on Bosch a WFK 2800 washing machine indicate
Problem from heating. Could be element or wires from it
Oct 21, 2010 | Bosch WFK 2401
Apr 20, 2010 | Bosch WFK 2401
Installing carbon brushes on Bosch WFK 2401
Remove drive belt.
Remove motor plug
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Bosch WFK 2401 Code 03 Error
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Pl rate me ‘very helpful’ for the free help!
Sep 23, 2008 | Bosch WFK 2401
Fault Code 06
put the selector switch on the x setting and hit the start button it will tak 60 sec and the door will unlock
Apr 19, 2008 | Bosch WFK 2401
Washing Machines Logo
93 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
