Question about Husqvarna Garden
Husqvarna wb53se mower self drive needs adjusting
The wheels spin in the air but wont pull the mower, how do i adjust it, thanks
  • Husqvarna Master
  • 2,478 Answers
Remove cover on the wheel, tighten the ball bearing idler. Should be 3 thumb screws to remove cover.
Posted on Feb 21, 2012
  • 79 Answers
SOURCE: NEW WHEELS AND BRAKE ADJUSTMENT MOWER WILL NOT MOVE IN ANY GEAR
Is it a hydrostatic drive and did you pull the pin that is located by the hitch. The pin should be pushed in in order to engage hydrostatic drive.
Posted on Apr 13, 2009
  • 6 Answers
SOURCE: Craftsman riding lawn mower wheel toe needs adjustment.
put it in reverse ton the wheel to the right and hit the wall again....or ir you were backing up when u hit the wall runn into foward
Posted on May 19, 2009
SOURCE: How do I adjust the tracking on a Husqvarna model Z5426?
With both handlebars in full foward position, the machine pulls to the right. How do I adjust this
Posted on Sep 07, 2009
wireguy212
  • 1627 Answers
SOURCE: Bought a used Murray wide body 42
There tie rod ends on those rods that can be adjusted,if you see no visible threads than you may need to adjust the other side to match the one tha looks like it is swung out ,maybe it is swung in.
Posted on Nov 10, 2009
  • 95 Answers
SOURCE: How do I adjust the deck level on a Husqvarna
Not sure if you are looking for the nuts and knobs or how to level? Most newer decks have knobs for adjuctments. I park my mower on a concrete level surface make sure all tires are at the correct psi then with tape measure check front left and right at bottom of deck for same measurment. You can also put a 2 ft level on the deck and adjust.
Posted on Mar 13, 2010
How do I adjust front wheel height?
Are we talking tractors or mowers here? If its a mower we are talking about there should be adjusters on each wheel. Possibly three holes that you bolt the wheels on. Each wheel should be in the same hole as each other wheel.
Jun 04, 2015 | Garden
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Hydro mower wont move after changing filter
Raise unit off the ground and support it so its safe to drive in the air then start the tractor and cycle from forward to reverse this will bleed out any air without damaging the trans just keep in mind if the wheels don't turn after 15 seconds or so you might have other issues
Apr 30, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a walk behind mower. The drive belt broke and I replaced it and now it wont pull itself. The wheels still spin if I lift it up but when I set it down it wont go anywhere
you must have a belt tensioner somewhere. Have a look near your belt pully or a idler pully that has an adjustment screw where you can tighten your belt to give grip. It appears the weight of the mower is causing the belt to slip hence it no moving because your belt /belts are slipping
Jul 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cable to front drive system to loose
that cable your pulling on has adjusters you need to adjust it and tighten it
Apr 29, 2009 | Toro Lawn Mower With Toro Power Tools
Apr 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Check the front wheels. I have the same problem and one of the wheels is locked which keeps the mower pulled in that direction. I am trying to figure out how to get the wheel loose.
Mar 15, 2009 | Husqvarna Zero Turn Mower Z5426
Garden Logo
136 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
