Question about Acer TravelMate 2303LCi Notebook
Acer travelmate 280
I have a problem with my notebook. It doesn't register the cd- rom drive in
the bios setup.
  • Nathan Scheef May 11, 2010
    did you install the cd-rom are the jumpers right? please give more info computer type os so on.
Icant get my acer travelmate to boot from cd
You need to set the BIOS configuration to boot from the CD.
I'm not sure how the Travelmate enters the BIOS (Setup), it could be the F1, F2, ESC or DEL ket after the ACER logo and before the Windows logo appear on the screen. When the BIOS opens, go to the Config page, set the CD to be the first boot device.
Aug 15, 2011 | Acer TravelMate 722iTX PC Notebook
How to go the bios setup travelmate 342t acer
F2 - BIOS Menu and change Boot order to CD - 1st Boot Device
Jan 16, 2010 | Acer TravelMate 342T Notebook
I need instructions to reformat my Acer travelmate 280 .ms2132
During bios boot up (Laptop starting) press ALT + F10. This should send you to the factory reset/format setting.
Warning; You will lose all your data, so back up pics, docs etc
Jan 13, 2010 | Acer TravelMate 2300 Notebook
Boot error PXE-E61: media test failure, check cable followed by, PXE-M0F: existing Broadcom PXE ROM followed by, Operating System not found
Hard drive has been coruppted. Hold alt f10 on statup to format and reinstall. If that dont work you may need to try install from cd's provided when you purchased laptop. If that dont work buy new hard drive and restore from cd's. Good Luck.
Nov 23, 2009 | Acer TravelMate 800LCi Notebook
Acer travelmate CD drive changing
Dear,
u have to remove the screw behind the laptop and oppsite to CD rom.
Cheers
Sep 19, 2009 | Acer TravelMate 4150LCi Notebook
Booting of CD Rom
If Your Travelmate comes with Preloaded operating system.You must have operating system Cd. If it is not u r not having operating system CD. may u r trying using driver and documentation cd.It is not a bootable operating CD.
2.if u r using right cd then go to bios setting select option cd as first bootable device.
if it solves u r problem
rate me
Jun 25, 2009 | Acer TravelMate 342T Notebook
ACER Travelmate 244
You could have a problem with the cdrom drive, thus the whine. Since it can't read the cdrom drive it goes then to read the hard drive (thus going around in circles).
If you have access to another computer, put the cd recovery drives on a flash drive, have the computer boot to the flash drive (if bios capable). The flash drive will recover your computer the same way your cd's did.
Let me know if this helped.
Dec 24, 2008 | Acer TravelMate 244XC Notebook
Acer travelmate 2420 laptop
You don't need the original setup cd as long as you have the windows cd you can boot up the pc using that cd and just repair the windows or install it over cause its only a file messed up. Get back to me
Apr 17, 2008 | Acer TravelMate 2300 Notebook
CD ROM Boot
In the BIOS are you able to "discover" the CD-ROM device? There should be a way such that you can specify what devices are connected to the system.
The BIOS version should recognize what devices are attached to the system.
You may need to "flash" (upgrade) the BIOS. Now a days, BIOS upgrades are available on the manufacturer's website.
Hope this helps :) Kindly leave a rating. Thanks..
Nov 27, 2007 | Acer TravelMate 2702WLMi Notebook
Medion notebook hardrive
If you're gonna format it using i.e a Windows XP-CD I guess you'll have to press C? H should be for booting to harddrive.
Sep 15, 2007 | Acer TravelMate 272XC Notebook
Acer TravelMate 2303LCi Notebook Logo
102 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
