Question about JVC KD-G320 CD Player
My l/o works but my speakers running from head unit does not
I have a jvc kd-g320, and I had just recently installed it, and when i turn it on the only thing that makes noise r the speakers connected to the amp connected to teh l/o on the head unit. The voltage goin to the unit is good, around 12 on the acc and teh constant, so I am wondering what my problem is, I've changed which way the leads were connected but still no sound.
  • will richards Aug 26, 2006
    Nevermind I fixed the problem
You have to find the subwoofer setting on your head and turn it all the way up.
Posted on Feb 04, 2008
Manual for jvc kd-6320
I don't see any references to a KD-6320 receive. Please check the model number. JVC has a KD-G320 AM/FM CD receiver. The installation and instruction manuals are available from the product support page here: http://support.jvc.com/consumer/product.jsp?modelId=MODL027623 . The direct link to instruction manual is http://resources.jvc.com/Resources/00/00/93/GET0349-001A.pdf . You can also check here: http://books.jvc.com/ for JVC manuals.
I hope this helps.
Apr 02, 2016 | JVC Car Audio & Video
JVC KGD 320: I don't have the owner's manual. How do I set the clock?
Hello there, The product model is refereed to as KD-G320 as opposed to KGD 320 which you provided. This made it a little difficult for us to get. But here is a complete user guide for the unit.The instructions to direct you on how to set the clock can be found on page 13. First you would have to turn off the satellite radio adjustment system which the unit has inbuilt to it.
Hope this solution has been helpful?
Thank you for visiting FixYa.
Aug 23, 2011 | JVC KD-G320 CD Player
Jvc kd-g340 rear speakers not working. I recently bought the car with this unit installed. I noticed that there is a l/r cable, power, ground in the trunk which means there was probably a subwoofer...
check the wires in the back of the stereo if not then make sure the back speakers are not hooked up to a internal amp and if it is make sure that it is not blown
Mar 31, 2010 | JVC KD-G340 Car CD/ MP3 Player
I have a jvc KD-G320 deck and need help hooking up subs...
Hello c92bivens,
While your KD-G320 does not have a specific subwoofer output, Kenwood did make provisions for adding one. There are two stereo pairs of line outputs on the back, one each for front and back. On the set for the rear, you can select a "line output mode" of "REAR" for normal speakers, or "WOOFER" for operating a sub.
Page 14 of your owners manual details the setting procedure while page 31 shows the connections. The manual incorrectly refers to the FRONT line outputs on page 14. Use the REAR line outs instead. If you do not have a manual, you can download the PDF version here at Crutchfields's web site. Ignore the "DISCONTINUED" notice (it's an old head unit), and scroll down the left just under "What's in the box" and click the "download owners manual" link.
Hope this helps. If it does, please rate as "FixYa".
Apr 25, 2009 | JVC Car Audio & Video
I have a jvc KD-G320 cd player and i am trying to hook it up to my 2 12" subs n the cd player doesnt seem to b sending the message to the subs to kick is there anything special i have to get to make...
ok first make sure all the leads are good
remote
and rca leads
check power to amp
then go in to settings in the head unit and change from rear to woofer and then do sub contol on high
Aug 16, 2008 | JVC Car Audio & Video
My JVC KD-623 Car deck is recieving power as the stand by light is on but it will not turn on or eject the disc. It was professionally installed.
there is two power sources to head units, one is a constant that makes the unit remember the time and such and the other is to actually run the unit. So am I correct to assume that the unit does not come on when the car is turned on? If so, check the wiring for the ignition
Aug 13, 2008 | JVC Car Audio & Video
How do i remove a jvc kd-g320 cd player from my vehicle?
Here's -->LINK<-- the installation manual. You'll see that you need 2 flat tools to insert/remove stereo.
Regards
Philip
Jul 21, 2008 | JVC Car Audio & Video
Wont keep memory
Most stereo manufacturers agreed on a color-coding scheme for their wiring to keep things consistent. In that scheme, red wires are run to power (ie, the battery) and serve as the ignition-switched power leads (so when the engine is shut off, the head unit also shuts off), black wires are grounds, and purple, gray, green, and white are used for the main four speakers. Blue is an antenna and/or amplifier turn-on wire. Orange is a dimmer wire (for cars with dimmers on the dash lights, this can be tapped in to also dim the head unit's lighting). Yellow wires are typically the memory wires. These feed power to the head unit constantly, regardless of whether the car is on or not, so that memory presets and tone settings are maintained. Your JVC unit should have a yellow wire coming off the back as part of the harness - this would be the one to supply power. You can run this directly to the battery - that way if you blow the fuse in the fuse box that you're considering using, you won't lose your stereo settings as well as whatever feature the fuse was utilized to protect.
Jul 20, 2008 | JVC KD-G320 CD Player
JVC Daisy Chain
If your autochanger has an input as well as an output connector it will be possible. The iPod adapter would have to be plugged into the changer's input, and the changer's output cable would run to the KD-G421.
This manual here from JVC shows a diagram on the middle of page 1 where an i-Pod adapter (I'm assuming you have the KS-PD100) is connected daisy-chained with an XM tuner or a DLP unit. Although it doesn't explicitly say that it would work with a CD changer, I don't think it'll be a problem as long as you have an input on the changer.
Feb 22, 2008 | JVC KD-G421 CD Player
JVC KD-G320 CD Player Logo
124 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
