Question about Bosch HBL 745 Stainless Steel Electric Single Oven
Bosch HBL 745 Oven over heating error code F111
Error code F111
SOURCE: Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Posted on Dec 11, 2007
ginko
  • 19396 Answers
SOURCE: Bosch oven won't pre-heat/heat with door closed
Some oven has a door sensor, which prevents heating when door is open, evidently this is faulty, you need a service manual to identify and replace the part, If I find something I will post here.
Posted on May 24, 2008
SOURCE: HBL 745 - stopped working
seems the oven was locked by the kids by mistake - found the manual and unlocked it.
Posted on Oct 16, 2008
  • 491 Answers
SOURCE: Door Hinges for Bosch oven HBL 545
CONTACT BOSCH FOR INFORMATION
Posted on Jul 18, 2009
  • 491 Answers
SOURCE: Hi experts. I have a Bosch Oven Model: HBL 745 A
FIRST CHECK FOR ANY BURNT WIRES THEN REPLACE THE HEATING COIL AND TERMOSTATS AND YOUR OVEN SHOULDWORK FINE, BUT MAKE SURE YOU CHECK ALL WIRING FIRST.
Posted on Nov 08, 2009
Hbl 745 error rtds not cal, how do i get the food out
Did you ever get an answer?? Same issue here. Oven is 10 yrs old. Had a different issue the first year & won't be buying an expensive Bosch again.
Apr 20, 2014 | Bosch HBL 745 Stainless Steel Electric...
Tip
Common heating faults with Bosch HBL 745 single oven
For all Free appliance repair videos visit our VIDEOTUTORIALS 1, If the Bosch fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the BOSCH element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your BOSCH fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 745 Stainless Steel Electric...
I have a bosch Oven model HBL745A UC and the heating element at the back of the oven won't turn off.
Most likely part is the oven control board, it has relays on it . There is one stuck. IT is 2235 dollars to replace.
Dec 09, 2013 | Bosch HBL 745 Stainless Steel Electric...
Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Plz rate my solution.
Thankyou.
Jan 05, 2009 | Bosch HBL 745 Stainless Steel Electric...
Oven is not heating...the convection fan blows, but no heat
If the oven is electric and fan assisted,then I would suggest that the oven fan element is faulty.
Plz rate this solution.
thanks.
Nov 08, 2008 | Bosch HBL 745 Stainless Steel Electric...
Oct 14, 2008 | Bosch HBL 745 Stainless Steel Electric...
Wall oven error code
Having the same problem.
Has anyone found a solution to this problem?
Thank you
David
m5beemer(at)gmail.com
Sep 03, 2008 | Bosch HBL 745 Stainless Steel Electric...
Bosch built under oven
you can try high-temp gasket maker from an auto supply store.
Jun 04, 2007 | Bosch HBL 745 Stainless Steel Electric...
Bosch HBL 745 Stainless Steel Electric Single Oven Logo
275 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
