Question about Sewing Machines
The top thread just hangs and knots on bottom of material
The top thread is not picking up bobbon thread and does not sew just hangs from bor\ttom of material in bunches
  • Sewing Machines Master
  • 7,365 Answers
Try changing the needle-flat side goes to the back of the machine
check to see if the thread has come off the thread take up lever
try rethreading the machine top thread & bobbin
clean under the needle plate area & also in the bobbin area for lint or loose threads
Posted on Feb 21, 2012
  • Maree Johnson
    Maree Johnson Oct 01, 2015
    Thank you that fixed it.
SOURCE: Thread bunching and knotting under fabric
After talking to my favorite Bernina dealer... I discovered a fix for my machine. And I"m going to guess it will also be your problem. The hook has grooves worn into it. This either needs to be filed very hard to remove all of the grooves or you can purchase a replacement hook. By the way they only make metal replacement hooks and my machine has a plastic one. So this must have been a common problem. My husband just filed mine down considerably and it's finally working. I am still planning to buy a metal hook to have on hand. Hope it helps you! Lydia Jo
Posted on Feb 25, 2008
mallow1
  • 35 Answers
SOURCE: Thread tension?
I own this little gem of a machine. It definitely sews a perfect stitch. I'm assuming you own the green 3/4 size machine as denoted by your product number. The half size blue one pictured is incorrect.
Anyway, this machine sews a perfect stitch, due to the oscillating bobbin. Most sewing machines with rotary (drop in) bobbins don't have an easily accessible bobbin tension screw, which means your fabric is usually slightly puckered. Fiddling with only the upper tension helps very little. This frustrates me to no end for sewing long curtains, clothing side seams, etc. Wrong tension causes them to hang with puckers, making them look awful. With the Hello Kitty 3/4 size Janome, there is a screw on the bobbin case which allows you to adjust for every thread diameter perfectly. Always a perfect stitch, if you take the time to adjust this screw.
To adjust the bobbin for a perfect tension, load the bobbin into the bobbin case and thread it through the guide. Holding only the thread between two or three fingers, let the bobbin case dangle below. This will be slightly difficult, because the bobbin will want to fall out of the case. Don't worry, just don't move it around too much and it will stay in long enough for this test. If the metal bobbin case slowly drops lower, unwinding thread as it goes, the thread is too loose. Tighten the screw on the side of the bobbin case a little (about a quarter turn.)
If the bobbin case seems to be dangling firmly, give the thread a gentle tug, lifting up fairly quickly. If it doesn't release a couple of inches of thread, it's too tight, loosen the screw. You know the tension is perfect when a quick, light tug of the thread releases a couple of inches of thread.
Posted on Aug 16, 2008
kent581
  • 87 Answers
SOURCE: Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Posted on Mar 18, 2009
bargainbox
  • 1388 Answers
SOURCE: on underside of material thread is loose and not catching
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Posted on Sep 02, 2009
  • 29 Answers
SOURCE: Bunches of threads on the bottom
You didn't give the brand, but if it's any of the older, non computerized machines, your problem is most likley in the tensions.
Loopies (tangles or nests of thread) on the bottom means upper tension too loose (or bobbin too tight).
Let's do the bobbin first...once it is set...99.9% of loopies on the underside are a problem with upper tension.
This is for bobbins that load on the front/side of the machine.. Take out the bobbin case...check the area (hook/race area) that the bobbin goes into for lint, tiny thread pieces, etc.). Now, most of this type of bobbin loads into the case with the thread going counter clockwise (when you are looking at the open side of the case), insert the bobbin in the case, and pull it through the hole/slott in the side of the bobbin case. To test for proper tension:
Lay the bobbin case in the palm of one hand, pull on the thread coming off the bobbin case. The bobbin will gently lift off your hand & if you wiggle the thread, the bobbin case should slowly drop about an inch at a time. If it's too tight, loosen the Larger (closest to where the thread comes out) screw on the side of the bobbin case about 1/16 of a turn...tiny bit...retest. Once that is done try a test stitchout. Remember to hold onto the bobbin & top thread for first few stitches.
If you still get loopies on the bottom...tighten the upper tension...it should be set between 4-5 for regular sewing.
Make sure the needle is in properly.
For a drop in bobbin...adjusting that tension is harder. You take the face plate (needle plate, the plate covering the sewing area of the machine) off and remove the bobbin case...First...look at the case in the machine...there is a little lip sticking out, usually at the bottom right corner of the open area (closest to you)...this is where you need to have the little lip when you replace the bobbin case.
Remove the case...check under it and inside the machine for lint/dust/threads & using a small paint brush (I use a childs tooth brush sometimes), clean the lint out. Now check the bobbin case for lint, especially where the thread fits..look at the inside of the case, you will see a little flat metal thing with a slott in it...make sure no lint in that slott. I use a pin to remove lint from there. Reinsert the bobbin case, rethread it all, (bobbin goes counterclockwise). Put the faceplate back on & test the stitches...still loopies with the upper set to between 4-5? Then you will remove the faceplate, remove the bobbin case & loosen the screw on the outside about 1/16 of a turn (these are usually covered in a colored coating) and retest.
I know that most home machine makers say not to adjust the bobbin..but that was back when you had one size thread...now we have many, many sizes and types of thread, so adjusting the bobbin may be needed sometimes.
Rule of thumb is:
loopies on underside...tighten upper tension
loopies on top...loosen upper tension.
But, like I said...with all the new threads..sometimes you have to adjust that bobbin.
Posted on May 14, 2010
Embroidering in blue thread, and the white bobbin thread was coming through on the material. Adjusted the tension to -8, sprayed the bobbin casing and area lightly with WD40, changed the bobbin, changed...
The white bobbin thread was showing on the top of the material correct? Make sure bobbin thread is in the tension correctly, check the top thread spool and make sure thread is not caught around it, if you have a manual top tension make sure that is set correctly. Personally I would never use wd40 in a sewing machine, sewing machine specific oil is always better. You seem to be describing two different problems. The thread bunching is probably from the thread jump out of the take up lever.
Sep 12, 2013 | Brother Sewing Machines
Bobbon thread keeps bunching
then it's very possible that the machine is out of time & needs to be serviced
make sure the needle is in serted correctly--flat side to the back of the machine & all the way up into the needle holder
May 18, 2012 | Singer Sewing Machines
When i sew the bobbin thread bunches up. what to do?
remove the thread and bobbin.
take out your manual and follow the exact instructions for threading and inserting bobbin.
If this does not help check the tension on the top(the number should be about mid way).
If it is too low it will bunch up on the bottom.
Nov 12, 2011 | Brother LS-1217 Mechanical Sewing Machine
My sewing machine is properly threaded up etc but will not catch the thread from the bobbin please help..
Your timing is off, remove the floor plate on the table and run the flywheel over by hand, the needle should bottom out and start its up stroke. At this  time the hook on the bobbon carrior should pick up the loop in the thread. If not loosen the set screws on the back of the bobbon  carrior and adjust.  What type machine is it ? and model number ,, let me know. trisquare@frontier.com
Apr 22, 2011 | Sewing Machines
How do you thread the bottom bobbin?
Depends, it is a top load bobbon or does the bobbon go below the needle shaft. ???
Just remember that when you place the bobbon into the shuttle the tread always has to pull clockwise. So if you are holding the bobbon facing you the thread comes from the top to the right.
Lay the bobben into the shuttle making sure you pull the threads in a clock wise motion until you pull it under a metal point that looks like a flattened needle. This is also your bobben tension and then take your hand and turn the clutch wheel slowly. You will see the thread loop around the bobben thread and pull it up.
Dec 20, 2010 | Singer Sewing Machines
Bunching and Looping (Bobbin Side)
Thread the machine with different color thread for the needle and the bobbin, then see which color is bunching up.Ill bet it is the top thread.
Jun 16, 2010 | Brother CS6000i Computerized Sewing...
Bobbon thread is too losse /thread breaks no
Clean out the bobbin area.
Thread the machine with the presser foot up. This opens the tension so the thread can enter. Threading with the foot down closes the tension and the thread cannot enter as it should. When you sew, the top thread is loose and cannot properly connect with the bobbin thread to form a tight stitch. The stitching does not hold and pulls right out.
Thread breakage - top thread? Check the thread spool to be sure there aren't any nicks to catch the thread.
When the thread breaks, check the spool pin to see if the thread is unwinding too fast and wrapping around the pin. Thread nets can help stop this. You can find them at sewing machine dealers.
Mar 11, 2010 | Singer Sewing Machines
Singer sewing machine stiches not forming & thread bunching
Sounds like what is called bird nests or thread nests. The top thread is not seated completely in the tension disk.
Remove the top thread completely from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Now, retest your machine.
Jun 28, 2017 | Singer Sewing Machines
Neddle hitting the bobbon
does the hook assembly move when you turn the handwheel? If no, then your hook drive gears are shot.
Jun 07, 2009 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
110 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
