Question about Sewing Machines
BOBBIN INSTRUCTIONS FOR EMDEKO SEWING MACHINE
5 Suggested Answers
SOURCE: thread keeps snapping on NEW Euro Pro 32-Stitch sewing machine
I also have the same sewing machine. The machine is not very user friendly and the instruction manual doesn't really illustrate the right way to thread the machine. For the bobbin, make sure you thread it through the two tiny holes in the small rectangular metal piece in the bobbin case. I had to use a dental floss threader and tweezers to thread the bobbin correctly, if you can believe it! As for the upper thread, follow the directions EXACTLY as illustrated in the manual. Don't miss the little loop underneath the machine or the tension will be wrong.
Also, use extra strong thread. I used a professional quality break-resistant thread from Germany for both the bobbin and top thread, and the machine works okay.
Posted on May 19, 2008
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
SOURCE: Bernina Bernette 65 sewing machine
I had the same problem. I'm a novice sewer. I just bought my machine. It did the samething, tension didn't work, the thread kept knotting up underneath, and the fabric kept curling up in the back.
I adjusted the tension knobs to no avail. Then it kept bothering me that it was curling up. I then decided to set the dials back to where the factory had them and adjusted the presser foot just a hair counterclockwise and I haven't had anymore problems.
The other day the needle almost broke because the tension was tight on the thread. You have to make sure that the needle is at it's highest point to get it to release the fabric so you have a thread tail.
This is my first purchased machine. I had a New Home years ago that was given to me, however it blew away in the tornado of 1991 in Kansas and I never replaced it. I really do love this machine. I don't believe I will ever want another.
Posted on Nov 11, 2009
I need help putting the bobbin threader back onto a Nelco JA38 sewing machine and the springs are giving me fits. Any help?
Not sure if you are having problems with the bobbin winder or threading the bobbin. This may help:
Nelco JA 38 Sewing Machine Threading Diagram
To avoid awful thread nests under the fabric, be sure to ALWAYS RAISE the presser foot when threading the top thread.
Interestingly, the bobbin threading instructions (above) show the bobbin loading into the bobbin case so it turns COUNTER-clockwise. This is the opposite of instructions for most machines. You can probably try both, the clockwise or Counter-clockwise,and see if one works better than the other.
Be sure to use fresh, good quality sewing machine oil or Tri-Flow Synthetic Oil on your machine. Open it up, while gently wiggling the handwheel, drop a couple drops of oil every place that metal rubs against metal. Avoid plastic or rubber parts! You may even find little round holes throughout that are oil ports. Be sure to get the area around the needlebar, presser foot lifter, feed dogs, the bobbin area, and all the dial and selector mechanisms.
You can find manuals for your machine online (not free!).
Nelco Sewing Machine Manuals Instruction and Repair Manuals
Aug 07, 2017 | Sewing Machines
Kenmore sewing machine model 158.905 how does the bobbin and bobbin cqse go back in?
Sears carries manuals for most of their machines (usually for free). The manual is invaluable for using your machine, including threading instructions.
Kenmore 158 1792 Sewing Machine Threading Diagram
May 02, 2017 | Kenmore Sewing Machines
Older Emdeko machine. Push power pedal hear motor but wheel not going around or needle going up and down problem?
Probably needs lubrication and a new belt. A good sewing machine shop will have it in stock and may even show you how to oil it. Yes, older machines needed to be oiled regularly!! It's not hard, but there are some 'ports' tha are easily missed. The manual is likely this one, or similar enough.
http://pages.suddenlink.net/maryhwa/emdeko/index.htm
Apr 03, 2017 | Sewing Machines
How to thread bobbin on Singer Serenade 30
The owner's manual should have instructions. Otherwise, search the internet for videos/tutorials for using your machine, ie:
Inserting the bobbin on Singer sewing machine
How to set up singer sewing machine MP4
Machines vary on how the bobbin is installed. A lot of Singers have a drop-in bobbin, but others actually have a removable bobbin case. Just search until you find one that is similar to yours.
Feb 14, 2016 | Singer Sewing Machines
Winding bobbin on Pinnock Craftmatic MK11
How to wind and install the bobbin, and thread the sewing ...
? 8:42
www.youtube.com/watch?v=eaEjvpwXrYA
Feb 19, 2010 - Uploaded by lanido13 This is part #1 of the tutorial. It shows how to wind the bobbin. Please check out part #2 of this tutorial for ...
Pinnock sewing machine instructions 'Sewing Machines
www.offou.com/pinnock-sewing-machine-instructions-sewing-machines...
I have picked up a Pinnock Majestic Craftmatic MK11 Model HZ-140 and I am ...Machine - Setting the Needle and Awl - Threading the Machine & Bobbin.
Oct 03, 2015 | Sewing Machines
The thread is not coming out of the bobbin properly
I could not find any reference material for this model.
But, Singer has examples and instructions for both a drop in bobbin and a rotary (side/front) bobbin.
Hope this helps.
If you contact the White Sewing Machine Company they may send you a new manual.
Apr 24, 2010 | White Sewing 1632 Mechanical Sewing...
I need instructions on How to wind a bobbin on a Kenmore 8 Stitch Sewing Machine
I could not find information for the 8 stitch, but if you look through these instructions you should be able to find one that is the same.
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Mar 17, 2010 | Kenmore Drop-In Bobbin 505S-21BH...
Bobbin Info and threading!
Take your machine to any sewing store that sells parts and accesories and they will be able to match the bobbin case to your machine. I am still using the bobbins that came with mine but you can pick up the metal bobbins at Walmart for under $4 for 6 of them.
May 19, 2008 | White Sewing 1632 Mechanical Sewing...
Sewing Machines Logo
450 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
