Question about Garden
How do you work on an oil pump assembly on a mcculloch 3200 chainsaw
I have taken the pump off can see nothing visibly wrong with it but it wont pump oil ive used a drill to turn the pump and no oil comes out at all
dontbother10
  • 2220 Answers
SOURCE: my McCullough chainsaw series 3200 is leaking oil,
Operator Manuals for McCulloch are difficult to find and will not help with this problem unless you want a repair facility. You can try here:
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it!
You provided no model number; this one was given in a 3200 fuel problem I answered earlier. An IPL for the model you provided follows (this is actually a 3214, I have never found a 3200):
http://www.ordertree.com/modelinfo/MCC/11-600032-32-Mac-3214-06%2F93-IPL-211229/139.11-600032-32-Mac-3214-06%2F93-IPL-211229.1.59.1.html
It is the only 600032-32 here:
McCulloch IPLs (all)
The IPL (exploded parts list) for your saw is the only detail for the oil system is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
There is a less detailed print here:
Chainsaws 32cc-35cc
On this block of saws the oil pump is under the flywheel and there are many hoses. Please use the IPL to identify and locate oiler parts. I hope you find a burst hose. There are oil pump repair kits listed. Unless the pump has an obvious crack or hole I would not attempt to change it until I had exhausted all other possibilities.
This works for older MCs but MTD (this one) saws often deviate from the explanation. It will give you a little guidance if you try to locate a different IPL.
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
I know it is not plugged but this may also be helpful.
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
These are very difficult to work on, most saw shops will not attempt a repair. I hope the chainsaw Gods smile on your undertaking. Good Luck. If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa HTH
Lou
Posted on Mar 27, 2010
dontbother10
  • 2220 Answers
SOURCE: my McCulloch chainsaw 3200 internal fuel line in
Try your friendly neighborhood chainsaw seller/mechanic. Take a piece of the old hose with you.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
Posted on Oct 13, 2009
SOURCE: mcculloch 484 chainsaw,with manual oil pump that does,nt work
IT GOES IN THE HOLE OF THE SMALL FILTER
THERE IS ENOTHER SMALLER BALL WHITH SPIRG INSIDE THE METAL TUBE THAT HOUSES THE PISTON
BOTH OF THEM WORK AS ONE WAY VALVES
Posted on Dec 25, 2009
SOURCE: NEED INSTRUCTION MANUAL FOR MCCULLOCH 838 AS CHAINSAW
Found it at
http://www.mcculloch.biz/int/support/owners-manuals/?query=MAC+838&types=O
Posted on Apr 16, 2010
Testimonial: "Thanks exactly what i was after,thanks again."
SOURCE: McCulloch,Mac 3200 Chainsaw fuel lines...........
retgmdI need the same, did you ever find one?
Posted on May 27, 2010
How do you get to the oil filter and how do you clean it and change it.
How to clean the chainsaw's air filter - YouTube
? 3:11
https://www.youtube.com/watch?v=wozSufvtbfE
May 30, 2012 - Uploaded by iScaper1
Tips for removing and cleaning the air filter on a Stihl MS250chainsaw. ... A very dirty air cleaner, a little maintenance can help them live longer ... Poulan Chainsaw Review- Should youbuy one? ... chainsawbars.co.uk - cleaning the air filter andchanging spark plug ... Get video URL at current time.
Mac 3200 chainsaw oil tank repair - YouTube
? 3:21
https://www.youtube.com/watch?v=XXlm-o8sD6A
Jul 17, 2012 - Uploaded by conan6868
Repairing oil tank. ... Could You Fix This Mini Mac Chain Saw! ...The chainsaw guy takes the McCulloch Mini Mac ChainsawChallenge 9 23.
Mucculloch 3516 chain saw assembly - YouTube? 49:25https://www.youtube.com/watch?v=Xm4YL3pDG8cJan 20, 2014 - Uploaded by Dragracer64In this video I take a box of dirty chain saw parts that has been sitting in my attic for about 12 ... Is there supposed to be a filteron the line in the chain oil tank? .... How to replace MCCULLOCH chainsaw MAC 3516 fuel line.How to replace MCCULLOCH chainsaw MAC 3516 fuel line ...? 1:32https://www.youtube.com/watch?v=GMjXYKza-NYJan 13, 2013 - Uploaded by Lambda ITCMCCULLOCH chain saw MAC 3516 chainsaw fuel line replacement. Three fuel lines. 1) First line in the tank ...
Dec 27, 2015 | McCulloch Garden
Oil level in motor of 3200 mcculloch chainsaw
This a 2 cycle engine where fuel oil is mixed with the gasoline. The mix is 40:1. If you attempt to run straight gas in this engine you will destroy it as would using regular oil.
The oil tank on this saw is for the lubing the chain and needs topping off every so often as you use the saw so that the chain stays oiled.
With the original McCulloch manufacture being out business parts are very hard to come if you can even find them.
Dec 03, 2014 | McCulloch 3200 Bar & Clutch Cover
Mcculloch chainsaw mac 3200 manual
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jun 15, 2012 | McCulloch Garden
After fitting new oil pump on chainsaw,why is it stiff to pull the cord and not start
Hello Richard,
Have you tried it with the spark plug removed just to determine if it is high compression causing tightness?
Before assembly, were you able to turn the oil pump by hand just to ensure it was rotating properly and not binding?
If all else fails, you may be able to download a service manual from the manufacturer by clicking here:
User manuals
Feb 18, 2018 | McCulloch Garden
Where to get a coil for 3200 mac chainsaw
Try the manufacturer or I recommend contacting your local authorized service center for assistance.
Contact us
User manuals
McCulloch Service
Mar 05, 2012 | McCulloch Garden
I need a pdf parts manual for a mcculloch 3200 chainsaw where can i find it
Contact us
User manuals
McCulloch Service
Dec 27, 2011 | McCulloch Garden
I NEED A ASSEMBLY DIAGRAM FOR A 3200 SERIES MAC CHAIN SAW.
I cannot find any 3200 series IPLs. Individual models can be found here:
McCulloch IPLs
This isn't very detailed I'd use the individual drawing.
https://www.dixiesales.com/ipl/327/Chainsaws_32cc-35cc.pdfIf this is a Chinese Mac (MTD) they are very difficult to work on. Most saw shops will not repair one. GL
Lou
Oct 23, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Aug 23, 2009 | McCulloch Garden
Mcculloch 484 chainsaw,with manual oil pump that does,nt work
Aug 16, 2009 | Garden
Need a manual for McCulloch mac 3200 chainsaw
MS1432 seems to be a good match for the mac 3200 (at least the Mac 3200 I just aquired from Pawn Xchange is identical to the MS1432 that was swiped from me last year by an *EX* friend) - PDF here:http://lawnandgarden.manualsonline.com/manuals/mfg/mcculloch/ms1432.html?idRes=5629277
(Yeah, I know, this is an old question but, it may help the nest person needing a manual)
Apr 04, 2009 | Garden
Garden Logo
451 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
