Question about Maytag Dependable Care LAT9706
Lat9706 leaks We have a Maytag Clothes Washer model LAT9706AAE and we seem to have water leaking. The input hoses are OK and the drain hose shows no sign of leakage. The tub fills OK. Is it possible that the tub is overfilling or splashing out when it spins Water seems to come from under the unit but not a flood of water.
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
Amigaman
  • 248 Answers
SOURCE: Washer leaking water from bottom
Probably a main tub seal, big job!
Posted on Nov 16, 2007
AlmostBob
  • 550 Answers
SOURCE: Maytag vaccuum line, drain washer and reset
This is not so difficult as it looks
turn off the taps
unplug the washer
open the back of the control panel
pull off the pressure line
blow in it till bubbles are heard in the tank, the line is now empty you dont have to blow very hard
cap the line with your thumb
quickly reattach the line to the level sensor without letting air escape
close the panel
plug in
pressure sensing will be correct if no air escaped
Posted on Sep 11, 2008
  • 57 Answers
SOURCE: Water will not stop filling tub.
the problem is that your pressure switch is not working properly. if you take the screws out of the back of the head you will find the pressure switch. first unplug the washer then undo the hose from pressure switch. blow trew the hose, then blow into the pressure switch if you hear the pressure switch click then re assemble and try again put on small load and watch if fills almost to the top or over flows replace pressure switch
Posted on Feb 25, 2009
  • 1341 Answers
SOURCE: Maytag Washing Machine Model LAT9706AAE Won't
Check at the back of it,the rubber belt may have become loose or sometimes slips off it course and may need re-fixing....
Posted on Jun 26, 2009
My Maytag Washer model GTW460ASJ4WW empties as soon as water IS INPUT
Is water leaking on the floor? Do you hear it running in the drain? Drain hose should be as high as washer top, otherwise water will siphon out, if pump is running might electical issue. Try that first.
Sep 27, 2017 | Maytag Washing Machines
Maytag clothes washer Model LAT6910AAW. leaks at the last cycle when the rinse water is drained. it may be the drain pump, except it doesn't leak when the wash water is drained (2nd cycle)
If your machine has a tray that you put softener in, softener is the last thing added at rinse time. If it is plugged or has a leaking supply hose, this would cause water paddles and appear to be related to the drain cycle.
Feb 17, 2017 | Maytag Washing Machines
Water leaking from my Maytag Neptune model FAV6800AWW Serial number 15646382GA Leaks during wash cycle imediately and during complete cycle. Enough water to saturate 2-3 towels and clothes come out...
Could be a Tub Seal leak my 1st choice. Could also be a leak caused by a cracked outer tub, issues from the hoses from the drain line connections to the drain pump, drain pump and or drain line.
Are you going to try to DIY the fix?
Sep 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Old admiral clothes washer leaks at front
Troubleshooting Water Leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Step 9: Check the water pump, using the procedures that follow.
Aug 25, 2009 | Maytag PAV2300 Top Load Washer
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer Maytag
To get access to internals you have to remove back panel of machine and then other 3 sides that then exposes the parts you need to get to eg. drainage hose,s
Apr 20, 2008 | Maytag Dependable Care LAT9706
Leaking, not found in owners manual
If it leaks during drain or spin cycle, it means that your exit hose has come loose or has a break. This can be replaced easily.............
Jan 02, 2008 | Maytag SAV515DE Top Load Washer
Maytag Performa Washer
when you put the drain hose on the floor the water will ALWAYS drain out. When the drain is in the proper location (above the height of the tub) and the water is still leaking, if its leaking as it fills you might have a loose hose,or a cracked water inlet valve. If after the water is in the tub and its still leaking you have a bad seal.
Jul 03, 2007 | Maytag Performa PAV2200
Washing Machines Logo
54 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
