Question about Technics Audio Players & Recorders
Are optical units same in slpj 37 and 44
Want to fit slpj37 pickup into slpj44
Jensen DVD will not play dvds it say no signal and disc error.
It sounds that the optical pickup unit is faulty. Put a disc cleaning disc into the set, and play it once. If the fault is with dust or dirt, it will be cleared out. If not, replace the optical pickup unit.
Nov 26, 2012 | Jensen Q2749J 27" TV
I can not play blueray disc
If it plays DVD discs but not blue ray the issue may be with the optical unit inside the player--Blue Ray is more complex and a problem usually with the optical pickup will show up there first, possible dirty or failing optical pickup in the unit.
Oct 23, 2012 | Televison & Video
Cleaned the scanner eye on my dvd player and it still doent play.
Replace the flat ribbon cable that connects the optical pickup unit to main board first. It this do not help you, replace optical pickup unit.
Jun 05, 2012 | Mintek Televison & Video
Coby TF-DVD 8503 will not turn on, if on video skips and turns off
Optical pickup unit might be faulty. Try by cleaning the optical lens, by inserting a lens cleaning disc into the player and play ti at least 2 times. If this do not belp you; optical pickup unit [Laser reading unit] should be replaced.
Jun 05, 2012 | Coby Televison & Video
Sony cd player cdp-ce275 hangs on all disc shuffel. how to fix
The fault is with its optical pickup unit. Insert a lens cleaning disc into the player and play it for at least two times. This must rectify the the problem if the fault is with dust of dirt. If not, replace the optical pickup unit.
May 27, 2012 | Audio Players & Recorders
Err disc
Clean the optical pickup unit by inserting a lens cleang disc into it. If this do not help you, the optical pickup unit need replacement.
May 26, 2012 | Televison & Video
Will not read cds are in
Clean the optical pickup lens by inserting a lens cleaning disc into it. If it do not help you, replace the optical pickup unit.
May 22, 2012 | Audio Players & Recorders
Spins CD says loading for about a minute then stops spinning and says no disc.
first of all check for the dirt or dust on the optical unit lens, secondly check for the breakage in the ribbon type connector, which connects the optical pickup unit to the main board, if broken replace it and if still the problem persists then replace the optical pickup unit
Dec 07, 2010 | Dynex DX-PDVD7 Portable DVD Player
Night owl nocc3 looks like a star field inside
it sounds like the light "pickup" at the front is not working,, was it stored with the front lens cap fitted and in the dark? if not you may have bamaged this "pickup" it could also just be dirt on it,,you can undo the front lens and clean the "pickup" if the unit is turned off and you use a soft lint free cloth
Jul 31, 2010 | Night Owl Optics Cyclops Compact NOCC3...
Dvds wont play
sounds like the optical pickup is faulty in your DVD player, have you tried the DVD in another unit?
Jan 16, 2008 | Televison & Video
48 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
