Question about Food Mixers
Thunderbird mixer arm 40
Hobart
2 Suggested Answers
Cuisinexpert
  • 61 Answers
SOURCE: oil leaking from hobart d300 mixer
DEFINITELY contact the manufacturer (Hobart) on that one. Sounds like you're having some sort of an internal problem with it (something might be cracked), and in this situation, the best way to go is to contact the manufacturer rather than try to repair it yourself. If you're still under warranty, and you try to open the machine up to fix it yourself, you could wind up VOIDING the warranty, and if you're out of warranty, most repair places won't touch a machine that you've messed with already--too much of a liability.
Just give Hobart a call, and they should be able to help you (if you're in warranty, sometimes even for free!). Their phone number (according to their website, www.hobartcorp.com ) is 1-888-4HOBART (1-888-446-2278)
Good luck! :)
Posted on Aug 27, 2009
I want to know if the mortar mixer D 300 Hobart make a changefor the gear because my speed number one doesn't work
Of course there are spares for Hobart mixers. They have been supplying spares for these machines for many, many years. We have an A20 (which is slightly smaller) and this, although it is about 40 years old, it is still supported.
Jan 23, 2015 | Hobart Food Mixers
Where do I drain the oil in a 60qt. thunderbird mixer
If you are referring to the transmission, I believe it's a sealed unit.
  • 3-Speed gear box
  • Transmission: Wide-faced, hardened alloy steel, helical gears fully sealed in transmission lubricant with heavy-duty ball bearings and clutch combine for highly dependable, quiet operation.
  • Jun 12, 2014 | Thunderbird ARM-01 Planetary Mixer
    I bought a used Hobart A200 20 quart stand mixer that hesitates or 'gets stuck' when mixing dough or other thick (hard to mix) material. When running without a load, or only a light load it doesn't stick...
    First of all, I want to say that it is common for people to overload the A200 mixer when mixing dough. The owner's manual gives an extensive chart for various substances typical of what people may mix. Depending on the consistency of the dough, the maximum batch size varies, but as an example: 9 lbs. max with 40% absorption ratio thin pizza dough, 1st gear only, 5 minutes maximum mix time. I remember this particular batch size/specification because as a technician who works on these mixers frequently, I had a customer attempting to mix 20+ lbs. of that 40% pizza dough for much more than 5 minutes and didn't understand why the mixer would stall and why his mixer was so hot he could nearly cook eggs on it's transmission case. So, a word of caution (9 lbs. at 40% A.R. is approx. 7 lbs. flour, plus the water) about overloading these. If used to mix reasonable batches, they are excellent mixers and will last a lifetime (I regularly service 40-50 year old A200 model mixers that run very well).
    If you don't hear any grinding when it's stalled (which would indicated stripped gears, damaged keys, etc. in the transmission) I would say you are overloading it. Many people want to say the motor is weak when the mixer stalls, but unless the motor has been repeatedly and severely overheated to the point of shorting some of the motor's windings, that's not the case. I suggest finding the recommended capacity chart from Hobart and abiding by it and you'll love your new mixer for years.
    Jan 04, 2011 | Hobart A200 Stand Mixer
    Need to know the part number for a dough hook for a hobart a200c stand mixer. What number would be stamped on the hook?
    A 20 qt "E" dough arm is S-23467. A 12 qt is S-62886.
    A 20 qt "S" sweet dough beater is R-8022.
    Jan 05, 2010 | Hobart A200 Stand Mixer
    Trying to locate a wire whisk for my Hobart D-340
    Bill. Whisks are not interchangable for different bowls. Try ebay to locate one.
    If this solution has assisted you, please rate it. ricardok45
    Mar 20, 2009 | Hobart D340-6009 Mixer
    Hobart model a200t not working propery. Just hums when turned on
    take top front cover off see if motor is spinning when turned on? hum can come when motor is running or transmision jammed or motor has issue like capsitor bad or start switch inside motor bad.
    Jan 03, 2009 | Hobart A200 Stand Mixer
    Bought Hobart D300-T at auction
    i have another for sale - working 1500,00 cdn
    Oct 19, 2008 | Hobart D300 Stand Mixer
    Hobart A200
    Hi I work on these all the time, sounds like a tooth from the one of the gears has sheerd off so making the gear rings rotate when they should sit solid in its casing..... you need to open her up or get a tech to look at it £150 is an approx fix
    fritz
    Jul 26, 2008 | Hobart A200 Stand Mixer
    Need cast iron bowl holder assembly for Hobart A-200
    if your looking for the bowl yoke goto hobartcorp.com or call 18884hobart for the part number and price.
    Dec 30, 2007 | Hobart A200 Stand Mixer
    Food Mixers Logo
    103 people viewed this question
    Top Food Mixers Experts
    eyecam
    Are you a Food Mixer Expert? Answer questions, earn points and help others
