Question about Whirlpool Refrigerators
Freezer works well but frig does not cool
Model # ET17CKXJWoo Type 17TFA Serial# VSK2075530 mfg 05/00
  • 65 Answers
SOURCE: Whirpool frig. freezer works frig doesn't
access to the evaporator fan is in the freezer behind the rear wall.
Posted on Feb 18, 2008
capsman
  • 111 Answers
SOURCE: freezer works but frig is not cooling
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Posted on Aug 01, 2008
  • 62 Answers
SOURCE: Freezer works but fridge does not cool..please help
Ther are several things that can cause this, one a bad evaparator fan or an defrost problem. Look on the back of the freezer wall and see if there is a lot of frost. If there is then it's a defrost problem and the part most likely is a bad termination thermostat also known as a bi-metal. If there is not a lot of frost, check to see that you have air going to the refrigerator section. If not then it could be the fan.
Posted on Aug 30, 2008
rockitman187
  • 2559 Answers
SOURCE: freezer works but frig is not cold
That could be it.
Posted on Jul 16, 2009
  • 4793 Answers
SOURCE: I have a Kenmore Elite fridge mfg in 2001, when
try this. switch off unit,do a full manual defrost,no hot water.clean out all vents/drains.then switch back on making sure all door seals flush with cabinet.poss cause unit is working overtime.......
Posted on Feb 22, 2010
My older model kenmore side by side refrig. is not getting the frig or the freezer cold model#9545510 serial #SD4123102 mfg. date 10/94 please help is there something i can try first before getting a...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 17, 2011 | Refrigerators
Kitchenaid frig model kbfa25erwh. Frig is not working but freezer is ok. Any suggestioms
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | KitchenAid Refrigerators
Frig doesn't cool. Freezer works fine. freezer
You have solved your problem :D You need to get that fan blowing. The vast majority of the time that is all you need. Other times, there can be another part controlling the operation of the fan (ADC - Adaptive Defrost Control). Post the model number and I will see if you have one of these ADCs in your appliance :D
May 31, 2010 | Whirlpool Refrigerators
Refrig compartment does not cool on my new Kemore Frig.
Check and make sure the fan in the freezer is running. if not possible bad fan. If fan is running, check to see if you have any ice built up on back freezer wall. Normally frost type ice. If so, you may possibly have a bad defrost bi-metal mounted in the freezer section. Next could be a defrost timer control. Model number usally will help more in getting it right.
Feb 28, 2010 | Kenmore Refrigerators
I have a Kenmore Elite fridge mfg in 2001, when its running it makes a sound and the light in the freezer goes dim everytime it makes the noise and the food in the freezer seems like its starting to thaw,...
Feb 22, 2010 | Refrigerators
Frigidaire frig model FRT18SGAQF Serial BA44035278. Freezer works fine frig does not cool. Both have own temp control. How do I repair.
First your Model# is FRT18S6AQF :)
Now you need to open the freezer section back wall to see if it have frost all over if not :( its a sealdsystem problem... but if you have frost see if the fan working , if not your fan is bad , beside that there ar 2 othe unit that need to be check
Defrost heater kit and the Defrost thermostat you can by them at sears part if they bad any other Q? visit my company web site :) www.911servicetoday.com
Dec 30, 2009 | Refrigerators
Frig does not stay cold enough
you are either low on coolant or the fan inside the freezer compartment is stuck or defective.
Mar 25, 2009 | Kenmore 55203 Side by Side Refrigerator
Quit, but has power 106.56563400
is the compressor hot? if yes, unplug , let it cool, and replace relay assy.
Oct 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Hi Guys, I have a GE Profile Frig: PSF26NGTDBB Serial # SL416129 This AM the softdrinks seemed a little warmer than usual. We checked the digital temperature inside the frig compartment and the freezer...
HI thanks for your question. the problem is either that the fan in the freezer is not working, or the fridge is frosting up, or the coils at the back of the fridge are dirty. first clean the coils .it could be you problem. thanks the appliance doc please rate my answer . thanks.
Oct 09, 2008 | GE Refrigerators
Refrigerators Logo
53 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
