Question about HP DesignJet 1050c plus InkJet Printer
HP Designjet 1050c plus freezes during print
Printing freezes around 75% of the print job. I've replaced the print head and cartrigdes, but still no help. I am running windows Xp sp2.
  • Anonymous Jan 16, 2009
    I have the same issue with some PDF's. I usally try a smaller PDF file and try again with success. May be a memory issue. Not sure how to bump up the memory on these things, if it a memory chip I can buy at a retail store. Of couse my belt just disentegrated so I am trying to contact my supplier to replace it.
  • alxnpi Jan 19, 2009
    I've done that but still get the same problem. However, I did get a Hard Disk Failure Warning from the Plotter
  • 72 Answers
Try setting up spooling on pc not printing directly to printer that may help you.
Posted on Jan 16, 2009
0b000d 00000012
Hello. 0B000D error during start-up indicates a 24VDC failure. This is generally caused by a failed DC power supply. There are 2 types of power supplies - 1 for the 1050C series and 1 for the 1050C Plus series. They can both be found at: HP Designjet 1050C 1055CM repair parts
Oct 11, 2013 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c plus InkJet Printer hangs up on axis test and ink droptest also paper axis test
Take print out of configure page, check the usage of paper axis, spit on,carriage,service station, and others includes FW.. identify which was crossed beyond 100%,replace them..update FW..confirm once be fore replacing the spares...
Oct 05, 2011 | HP DesignJet 1050c plus InkJet Printer
Why has my hp designjet 1055cm has started printing everything with a red tint
Check helth condition of print heads, per form align print heads if nozzles are clogged replace print heads & cleaners..
Sep 09, 2011 | HP DesignJet 1050c plus InkJet Printer
We installed the HP designjet on a pc windows vista and we can print everything we want to, the printer is also installed on a mac osx 10.6 snow leopard but there we have some problems for printing our...
HP Design Jet 1050C Plus is supported by MAC OS 10.6. If you are having problems with printing, it is recommended that you may update the drivers of your printer. Click here to download the latest drivers.
Good Luck!
Hope this helps!
CreativeTECH
Dec 15, 2010 | HP DesignJet 1050c plus InkJet Printer
Cyan color not printing but ink indicator high
You probably have a bad trailing cable or bad carriage. Start by replacing the cable first. Parts available at: http://www.lpscomputer.com/p-2296-c6074-60418-designjet-1050c-1055cm-trailing-cable.aspx
Feb 19, 2010 | HP DesignJet 1050c plus InkJet Printer
Printing is getting jammed in the left corned, then cancells.
Try removing the screws from the back door on the Ink Supply Station (sometimes they catch on the carriage - the printer does not need the screws) Look under the carriage belt to see if there are rubber bits. The belt may be disintegrating and need replacing. Parts available here: http://www.lpscomputer.com/c-736-designjet-1050c-belt.aspx
Jan 30, 2010 | HP DesignJet 500ps (42 in.) InkJet Printer
SYSTEM ERROR CODE 04C300 C8CC0000 THEN STOPPED PRINTING MIDWAY THROUGH JOB iT SAYS TO HIT ENTER TO CONTINUE BUT GOES INTO A LOOP OF ERROR CODE /HIT ENTER, ETC
This is an IO error. Remove the back cover and disconnect the cables to the HDD and remove the JetDierct card. Print the internal test page. If it prints OK, install the Jet Direct card. Print again. Prints OK? Replace the HDD (or run without it). Does not print OK?
Replace the JetDirect card. Parts available at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Dec 16, 2009 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050C stops printing - no error message
check all connectors on main pca. check trailing cables on carriage assembly. main pca may be bad.
Sep 08, 2009 | HP DesignJet 1050c plus InkJet Printer
Hp Deskjet 1050C Plus- Print head error
It is not unheard of to have a bad print head out of the box. I suggest you remove all the print heads and clean the ribbon connectors in the carriage that connect to the print heads. Clean the connectors on the print heads also.
If that does not clear up the problem, you may have a bad trailing cable (carries all the signals to and from the print heads) or a bad carriage.
Download Service Manual: www.lpscomputer.com/ec/manuals.htm
Jun 09, 2009 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
396 people viewed this question
Seeker5211
Seeker5211
