Question about Husqvarna Garden
Change hydrostatic transmission oil
I'd like to change the transmission oil on my ~4 yr old Rider 155. The oil in the reservoir looks very black. The operators manual says I should top up the level as required with 10-30 oil, but doesn't give any further instruction on oil change. Looks like 2 drain bolts on bottom of transaxle. Any suggestions?
  • SK_Rider Oct 31, 2008
    I removed both drain plugs, drained the oil and replaced with approx 1.7 liters of 10-30 Mobil1 synthetic. Working OK so far.
  • Anonymous Mar 25, 2014
    transmission wont pull some times and is very noisey.can the oil be changed in it and if so what kind of oil goes in it.
  • 4 Answers
We have tractors and, yes any of those drain bolts will work (for best results do both) then after its drained, put the drain bolts back in and top up the level
Posted on Oct 31, 2008
My 1200 riding mower Husqvarna go very slowly I never change the oil on transmission this should be the cause, also I need to know if inside of transmission there is a filter that I can replace
Posted on Jun 25, 2009
Im glad to help
Posted on Nov 03, 2008
What would cause the transmission to stop working when it gets hot and when it cools down works fine
since we do not know what type transmission you have this is tough . but hydrostatics overheat and oil does not pump properly when boiling .
Mar 30, 2016 | Garden
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
How to fill hydrostatic transmission fluid on Poulan Pro
How do I check the transmission
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fill Hydrostatic Transmission in Lawn Tractor
http://husqvarna.custhelp.com/app/answers/detail/a_id/387/~/maintenance---what-type-of-oil-is-used-in-the-hydrostatic-transmissions%3F
Jul 28, 2012 | Poulan Garden
I have a husqvarna rider 155, the transmission loses power after I have ben mowing for an hour
Hi, remove the battery and battery carrier, clean all grass and debris from the hydrostatic drive, cooling fins and fan. Your problem is most likely the hydrostatic drive over heating. Hope this helps, regards Phil.
Jul 04, 2011 | Husqvarna Garden
I have a Husqvarna Rider 155. Does the transmission oil ever need to be replaced? Is there a filter ? If so how do I change it? Where can I get a SERVICE manual?
Not an expert but have a rider 155. After looking at diagram on partstree.com, it does not appear to have a filter. Just a magnetic drain plug. This is the only site I have found for info and parts.
Apr 21, 2010 | Husqvarna Garden
Rider won't move Hydrostatic
IT MAY NEED SOME FLUID IN IT I COULD LOOK AT IT IF YOU WERE IN MY TOWN IM IN TULSA LET ME KNOW I WILL HELP
Oct 11, 2009 | Garden
Looking for when the oil and transmission should be changed on Lt
Hey,
Many manufactures recommend a engine oil change every 50hrs more often in extreme conditions,
Most transmissions are sealed units if this is the case company's recommend not to touch these,
If you have a hydrostatic drive or a Zero turn unit with twin hydrostatic drives the transmission oil must be changed every 500 hours or every year whichever comes first as the hydraulic oil brakes down in time, also at these intervals the hydro oil filter must also be changed...
Brad:)
Sep 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
2,813 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
