Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Replaced starter gear then torqued to 5 lbs,fired up,fine? replaced primary and now wont start?
Experts, I recently replaced my starter jackshaft gear on my 2000,fatboy in an attempt to remedy my starter failure, I replaced the worn gear that showed signs of several missing teeth with a new gear,Then tested it and everything seemed fine so i replaced my primary cover,tightened everything to specs,replaced primary oil went to fire up motor and got a high pitch zing sound? I repeated process 3 more entire times and every time was the same?It starts with primary cover off only?
  • 216 Answers
Well, first off....Dont try starting it anymore without the primary, it can damage the gears. The problem you describe is common with custom builds. I'll assume you purchased the correct stock jackshaft for your model and installed the lock plate and everything else correctly. You can tighten the jackshaft bolt to 7-9lbs. Your last step is putting a wrench on the assembly and pulling it out and turning 1/4 turns to make sure its not binding, as a last resort you can bevel the jackshaft bushing on the out primary so it goes in smoothly - thats what I did on mine and it works like a charm. Good luck
Posted on Oct 27, 2008
  • Mel Jacobson
    Mel Jacobson Oct 28, 2008
    BTW - Harley will tell u a spinning starter that doesnt engage is cause by the jackshaft not put together right, or a bad armature or idler gear or a faullty starter clutch
    fyi
    Problem Solver:
  • 3 Answers
Put new clutch now starter barely hit gear after bikes starts it a 98 custom softail thank EZ
Posted on May 07, 2009
How to change my starter? I have a 2004 HD Dyna Low Rider
Hi Hannah, start by disconnecting the battery, negative cable first. Then drain primary oil and remove primary cover. Bend the locking tab back that secures jackshaft bolt and while holding pinion gear unscrew and remove jackshaft bolt, locking tab and thrust washer. Then remove rear exhaust pipe to gain acess to starter. Disconnect all wires and cables from starter. Remove chrome starter end cover. The two bolts that hold the starter motor to the engine case are 5/16" allen heads. Now my memory is a little fuzzy since I have been out of the business for several years, but if you can procure a long straight ball head allen key or socket I think it will allow you acess to the bolts without removing the oil tank otherwise you have to remove the tank. Once you get the two bolts out you can remove the starter. Replace starter in reverse order, tighten starter bolts to 20 foot lbs. of torque jackshaft bolt 100 inch lbs. of torque. primary cover bolts 10 foot lbs. of torque. Good luck
Apr 04, 2015 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
Which way does the jackshaft coupling go in a 95 herritage softail
The jackshaft must be installed back onto the starter shaft prior to installing the jackshaft with the shallow side of the coupling going/facing towards the jackshaft and also facingthe jackshaft splines. Remember to reinstall the coupling retaining ring if it was removed. ALSO, be sure to install the coupling on the starter output shaft with the counter bore facing the jackshaft. THEN put the spring inside the coupling and install the pinion gear on the shaft put the lockplate and the thrust washer on the bolt and put the bolt in place in the jackshaft. If you removed the retaining ring put it back on shaft and then slide the jackshaft assembly back into position in the inner primary. In order to hold the lockplate and thrust washer in place be certain that the lockplate tab is properly in the keyway. THEN, having aligned the lockplate tab and thrust washer properly in the slot with the jackshaft keyway screw the jackshaft bolt into the starter shaft and while holding the pinion gear in position tighten the bolt to 84-108 in-lbs (9.5-12.2 Nm) and bend the locking tab against bolt head.
Jun 22, 2014 | Harley Davidson FLSTC Heritage Softail...
Whitch way does the jackshaft coupling go
Jun 22, 2014 | 2000 Harley Davidson FLSTC Heritage...
How do you Replace starter drive on 1984 harley fxr
Sorry 1984 is back beyond my expertise and/or knowledge but later model years jackshaft might be somewhat similar:
Disconnect the negative battery cable. THEN remove the primary cover. (If you are only going to service the items from the bolt through to the spring it is not necessary to remove clutch but if it is desired to replace the coupling and/or the retaining ring it will also require starter removal. So, bearing that in mind, if necessary, next remove the clutch assembly. THEN while holding the pinion gear in place remove the jackshaft bolt, the lockplate and the thrust washer and remove the jackshaft from the inner primary as an assembly. THEN remove the pinion gear from the jackshaft and then remove the coupling and the spring. The spring and the retaining ring are inside the coupling. Replace the retaining ring if deemed necessary. ALSO if the coupling is forced through the primary case oil seal you will necessarily have to replace the seal as it will be ruined. THEN remove the coupling from the starter shaft and if needed replace the retaining ring. The jackshaft must be installed back onto the starter shaft prior to installing the jackshaft with the shallow side of the coupling going/facing towards the jackshaft and also facingthe jackshaft splines. Remember to reinstall the coupling retaining ring if it was removed. ALSO, be sure to install the coupling on the starter output shaft with the counter bore facing the jackshaft. THEN put the spring inside the coupling and install the pinion gear on the shaft put the lockplate and the thrust washer on the bolt and put the bolt in place in the jackshaft. If you removed the retaining ring put it back on shaft and then slide the jackshaft assembly back into position in the inner primary. In order to hold the lockplate and thrust washer in place be certain that the lockplate tab is properly in the keyway. THEN, having aligned the lockplate tab and thrust washer properly in the slot with the jackshaft keyway screw the jackshaft bolt into the starter shaft and while holding the pinion gear in position tighten the bolt to 84-108 in-lbs (9.5-12.2 Nm) and bend the locking tab against bolt head. THEN reinstall the clutch assembly etc. and the primary case etc using new gaskets as required etc., refill the primary with oil, reconnect the negative battery cable and check to be sure you have not forgotten anything.
CAUTION
May 13, 2014 | 2000 Harley Davidson FLSTC Heritage...
My outer primary wont stop leaking on my 1974 shovelhead.
Hi Anonymous, check the mating surfaces for cracks, deep pry marks ect. use silicone to fill any serious imperfections and weld any cracks. The surfaces should be clean of all previous glued on gaskets. You can use Gasket Cinch if you want to hold the new thick silicone bead impregnated gasket in place. Make sure all mating surfaces are clean and dry and install primary cover. I would do the same with the inspection and derby cover, someone makes silicone beaded gaskets for them also. Then in a criss cross pattern starting in the middle and working your way out ward torque screws to 5 ft lbs. then repeat the sequence to a final torque value of 10 ft lbs. This procedure is imperative to insure proper clamp load on the primary cover. Fire up the bike and ckeck primary vacuum it should be 25 inches of water vacuum with the vent line pinched and the engine running at 1,500 RPM. If you get zero on the gauge you got problems. Usual suspects are: broken or cracked engine case lip, bad motor sproket, inner primary, or starter jackshaft seal. And my personal favorite cracked inner primary just below the starter jackshaft cause by a loose chain. Good luck
Aug 13, 2013 | 1993 Harley Davidson FXR Super Glide
Removing the starter from a 2001 softtail
To remove the starter from your Big Twin, first disconnect the negative battery cable and drain the oil from the primary. Remove the outer primary cover and take the small bolt out of the starter jackshaft. You don't necessarily have to remove the starter gear and the jackshaft but you may be able to work it out without moving the clutch assembly out. If you want to move the clutch assembly out, take the snap ring out of the clutch adjuster screw plate in the front of the assembly. Inside the hole is the mainshaft nut. It has LEFT-HANDED THREADS. You can get the nut off if you have an air wrench or a primary locking bar to keep the engine from turning while trying to get the nut off. The nut torques to 60-80 foot pounds of torque. Once you get the nut off, you can slide the clutch assembly outwards enough to get the starter jackshaft and gear off without having to remove the primary chain or the engine sprocket.
Go to the other side of the bike and take part or all of the exhaust system off to allow you to get the starter out. In the case of a Softail, remove the top bolts and the rubber supports that hold the oil tank in. You do not have to disconnect any of the hoses. All you need to do it to raise the tank just a bit to get to bolts that hold the starter on and to get it out. Take the nut off that that connects the battery cable to the starter and unplug the small single wire from the back of the starter. The nut is a 14mm nut. Take the two large socket head bolts out that holds the starter on and remove the starter. There is a coupling that connects the starter to the jackshaft. Mark the coupling which way it goes or remember that the counter bored end goes toward the jackshaft.
If you want an exploded view of the starter and jackshaft, visit
http://www.bikebandit.com and look up your bike or one close as the starters are the same.
Good Luck
Steve
Sep 15, 2011 | 2001 Harley Davidson FXSTD - FXSTDI Deuce
How do I replace stator
To remove the starter from your Big Twin, first disconnect the negative battery cable and drain the oil from the primary. Remove the outer primary cover and take the small bolt out of the starter jackshaft. You don't necessarily have to remove the starter gear and the jackshaft but you may be able to work it out without moving the clutch assembly out. If you want to move the clutch assembly out, take the snap ring out of the clutch adjuster screw plate in the front of the assembly. Inside the hole is the mainshaft nut. It has LEFT-HANDED THREADS. You can get the nut off it you have an air wrench or a primary locking bar to keep the engine from turning while trying to get the nut off. The nut torques to 60-80 foot pounds of torque. Once you get the nut off, you can slide the clutch assembly outwards enough to get the starter gear off.
Go to the other side of the bike and take part or all of the exhaust system off to allow you to get the starter out. In the case of a Softail, remove the top bolts and the rubber supports that hold the oil tank in. You do not have to disconnect any of the hoses. All you need to do it to raise the tank just a bit to get to bolts that hold the starter on and to get it out. Take the nut off that that connects the battery cable to the starter. Unplug the small single wire from the back of the starter. The nut is a 14mm nut. Take the two large socket head bolts out that holds the starter on and remove the starter. There is a coupling that connects the starter to the jackshaft. Mark the coupling which way it goes or remember that the counter bored end goes toward the jackshaft.
Sep 13, 2011 | 2000 Harley Davidson FXSTB Night Train
I need step by step instructions on removing the starter from a 1997 flstc
Disconnect the battery, remove the negative 1st...Remove primary cover...Hold pinion gear in place and remove jackshaft bolt...
Remove rear exhaust pipe...Remove allen screw end cover... Remove starter mounting alan head bolts and washers....Disconnect positive battery lead and solenoid wire from starter....Remove starter...
Note: you might need to loosen the oil tank mounts to provide clearance for starter removal...
Install new starter in reverse order...Torque specs...
Starter mounting bolts - 13 - 30 ft-lbs
Jackshaft bolt - 7 - 9 ft-lbs
Jul 17, 2011 | Harley Davidson FLSTC - FLSTCI Heritage...
Starter makes grinding noise.... Can you help me? 1997 heritage softtail.
The first thing I'd check is the jackshaft and the ring gear on the outer clutch hub. Disconnect the battery. Drain and remove the outer primary. Inspect the ring gear and jackshaft looking for "roughness" on the teeth of the two gears of broken teeth. If you find any, you'll have to replace the parts.
If those parts look good, your problem is probably the "starter clutch" inside the starter. This is the one way bearing type device that allows your starter to turn the engine over but then freewheels the starter once the engine does start. This part can be replaced without having to purchase an entire starter but you'll have to disassemble the starter to replace it.
Good Luck
Steve
Aug 09, 2010 | 2000 Harley Davidson FLSTC Heritage...
Starter on 2000 fatboy. cant get starter past oil bag.
Your starter is connected to a jackshaft Assembly behind your primary cover. A long 1/4" bolt attaches them together. You need to remove the bolt. There is a coupler that joins the starter to the jackshaft that may fall out behind you primary, don't lose it and make sure it is put back on in the right direction when reassembeling. The torqe on the jackshaft screw is minimal (like 7 to 10foot lbs) and don't forget to use some blue locktite on it.
Aug 04, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
357 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
