Question about Canon PIXMA iP1600 Printer
Installing the printer paper
How and where do i place the printer paper
    President:
  • 1,901 Answers
Surface to be printed on (glossy or matte) facing you.
Posted on Oct 27, 2008
  • Wayne Mineard
    Wayne Mineard Oct 27, 2008
    Why inappropriate? Curious.
Error code e1 showing at xerox pro 420? solution..
rror codes If the printer's front panel displays a message Error XX, find the error code in this table and follow the instructions for resolving the problem. If problems persist, check the Xerox web site www2.tek.com/TekSMART/ or contact service.
Error User Corrective Action Error 01
  • Remove and re-install the black Toner Cartridge, then turn the printer off and on.
  • Replace the black Toner Cartridge, then turn the printer off and on.
Error 02
  • Remove and re-install the cyan Toner Cartridge, then turn the printer off and on.
  • Replace the cyan Toner Cartridge, then turn the printer off and on.
Error 03
  • Remove and re-install the magenta Toner Cartridge, then turn the printer off and on.
  • Replace the magenta Toner Cartridge, then turn the printer off and on.
Error 04
  • Remove and re-install the yellow Toner Cartridge, then turn the printer off and on.
  • Replace the yellow Toner Cartridge, then turn the printer off and on.
Error 05, 10, 11,12, and 13
  • Turn the printer power off, then on.
Error 20
  • Remove and re-install the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Remove and re-install the Main Charge Grid. Turn the printer off, then on.
  • Remove and re-install the Transfer Kit. Turn the printer off, then on.
  • Remove and re-install each of the Toner Cartridges. Turn the printer off, then on.
  • Replace the Main Charge Grid. Turn the printer off, then on.
  • Replace the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Replace the Transfer Kit. Turn the printer off, then on.
  • Replace the Toner Cartridges. Turn the printer off, then on.
Error 21, 22, 30,and 32
  • If a problem persists for Error 30, clean the sensor. See Cleaning Phaser 750 Printers.
Error 33
  • Check for jammed paper throughout the paper path (especially in paper feeder).
  • Remove and re-install the paper feeder and Transfer Kit. Turn the printer off, then on.
Error 40, 41, 42,and 43
  • Check for jammed paper in the Fuser. Re-install the Fuser. Turn the printer off, then on.
  • Make sure that you have the correct Fuser for your local printer power supply:
    110-Volt Fuser Part Number 016-1839-00
    220-Volt Fuser Part Number 016-1840-00
  • Replace the Fuser. Turn the printer off, then on.
Error 50, 51
  • Turn the printer off, then on.
Error 52
  • Remove the Duplex Unit (if installed).
  • Check for paper under the Upper Tray.
  • Turn power off, then on.
Error 53
  • Open left door and remove any jammed media.
  • Tun the printer off, then on.
Error 60
  • Remove the media from the Multi-Purpose Tray. Turn the printer off, then on.
  • Reinstall the media. Make sure you do not overfill the tray.
Error 61
  • Remove and re-install each Toner Cartridge. Turn the printer off, then on.
  • Replace each Toner Cartridge. Turn the printer off, then on.
Error 62
  • Check for jammed paper throughout the paper path (especially in the paper feeder and Fuser).
  • Remove and re-install the Fuser. Turn the printer off, then on.
  • Slide out and re-insert the paper feeder. Turn the printer off, then on.
Error 63
  • Remove and re-install the Imaging Unit. Turn the printer off, then on.
  • Replace the Imaging Unit. Turn the printer off, then on.
Error 70, 71, and72
Error 73
Error 74
Error 80, 81, 82,83, and 84
  • Make sure that all four toner cartridges are installed in the printer.
Error 01p through
Error 47p
  • Make sure that installed memory DIMM(s) are compatible with printer's image processor board and that they are installed in the proper slot(s).
  • you can helpful
Oct 09, 2014 | Xerox Phaser Office Equipment & Supplies
My printer will not load paper.I install paper and hit ok,but it will not pull paper in.
first check the printer for bits of papper use a low pressure vaccum or blower to clean the papper then remove the printer tray and install them properly then switch off the printer and remove the usb cable and the power cable wit for few minutes an place them back then switch on the printer and the computer
Jun 02, 2011 | Epson Stylus NX300 All-In-One InkJet...
I don't know how to install the paper
Place the paper in the tray on the bottom of the printer. When a printer says "Install the paper" It doesn't really mean to install per say.. just means to put paper into the tray.
Mar 29, 2011 | Computers & Internet
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
32T-26.eps
1 Move the paper lever to the position marked "REAR."
32T-11.eps
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
32T-27.eps
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
32T-29.eps
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
32T-29A.eps
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
lever.
32T-29.eps
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
32T-31.eps
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
32T-12.eps
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
guide.
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
32T-15.eps
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Printer not catching paper
You may have to clean the pick up rollers with alcohol or put a new roller in your printer.
If you have a printer with a tray, make sure it is set correctly for the paper you have installed.
It will try to grab the paper a number of times and will usually give you a paper jam error after a number of tries.
Jul 13, 2010 | Dell 922 All-In-One InkJet Printer
Laser printer shows light in error led ,no printing what is the reason
Error means the printer can see a paper in the paper tray side, it thinks there is a paper in the exit side, or there is paper near the toner cartidge. tr removing and reinstalling the cartridge. Look for paper, check the printer cartridge is properly installed and the paper tray is in the right place and loaded right. The owner's manual shows how to clear paper jams.
After this, you need the help of a printer repair shop.
Mar 21, 2010 | Konica Minolta PagePro 1300W Printer
The printer keeps saying paper jam. I am using 65 pound paper and I changed the setting to card stock. Is there a trick to loading the paper?
I believe that if the printer is having problems picking the paper up it could be due to the pick up roller not having enough strength to pick up such a heavy paper. What you can do is make sure that the printer has the latest firmware installed as well as that the paper is properly placed and adjusted in the tray.
Jan 23, 2010 | Lexmark C510 Laser Printer
I installed a new cartridge and the printer CARRIER JAMMED
Jam means there is somthing stuck at the exit of the paper, it should be paper stucking there, could be small you donot recognize it. check the enterance and the exit of papers place .
Thanks for using Fixya
Oct 12, 2009 | Dell 924 All-in-One InkJet Printer
Installing paper
The printer loads paper from the installed paper tray or the manual feed slot.
For ordinary tasks, though, you would use the paper tray. This is located in the bottom front of the printer and looks as a kind of drawer. Pull it open to feed the paper.
You can download the User's Manual for your printer from Brother:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
I am assuming you have a printer
Aug 26, 2009 | Office Equipment & Supplies
I have a Canon Pixma MP145 showing error E2. There's paper in the printer. After I turn it off then back on when the cartridge gets over to the right hand side (at the end of the back and forth thing it...
E2 – No paper, Paper does not feed error.
How to correct, fix: If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Jun 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
old marine
old marine
