Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Lenovo IdeaPad Y530 - 40512SU
I don't see this this product as choices to choose.. so I just chose any just to get this through.
I bought brand new today at Circuit City Lenovo IdeaPad Y530 - 40512SU , charged battery, installed Windows Vista, touched button on top left (thought it was the off/on button).. Lights went out, closed lid.. stored away for 4 hours. Went to use and it was burning hot.. now screen is dark, but computer is running.
  • ddemails Oct 31, 2008
    We took it back!! THANKS FOR YOUR HELP...It was the back light buned out...
  • Lenovo Master
  • 19,396 Answers
Ensure that you did not press the conbination of keys that switches to the external screen, on thinkpads this is Function key , plus one of the numbers.
Check if the computer is in sleep (hybernate) mode, in this case you should be able to wake it up with the start button, or on some model with the wake up button.
IF you still cannto restart the computer, then it is probably frozen, remove battery and try to restart the laptop in this way.
After restarting check the power settings (you find them also on display properties/screensaver, or in the control panel). set the computer not to turn off.
If the computer screen does not turn on again doing the above, or there is no way to wake it up when it goes in standby, then the unit may be faulty.
If the computer is new, in this case, better getting a replacement or a repair.
Posted on Oct 27, 2008
Format laptop and re-install OS
You can download a Windows 7 one key program to do this from Lenovo support. Choose 32 or 64 Bit version and Read the text about loosing data and drivers first.
Laptops and netbooks IdeaPad Series laptops IdeaPad Y560 Lenovo Support SG
Dec 11, 2014 | Lenovo IdeaPad Y560 Laptop
Power save mode on the Lenovo IdeaPad
if you right click on desktop and go to properties or personalize depending on what o/s you're using then choose screensaver and adjust the time.
if you want to change power options it's control panel then performance and maintenance then power options.
Oct 09, 2012 | Lenovo IdeaPad S10e Netbook
I just bought my Lenovo IdeaPad Z560 0914-3ZU from TigerDirect 3 weeks ago. I set my password to something I always use. I tried to get in the next time and the computer does not recognize my password....
No worries, you should still be able to get onto your computer. It will just take a little elbow grease.
Alright, so the first thing you need to do is turn off your laptop and then the steps will follow as such:
1. Turn the power on your laptop on
2. Press the F8 key on your keyboard as your laptop starts up
3. You will notice a few choices available to you at the menu that will come up, choose safe-mode with networking.
4. Your screen will fill with all kinds of writing indicating that it is loading files. Don't panic, this is normal do no turn off the laptop.
5. It will bring you to the login screen of windows, here you will want to choose Administrator. No password should be required(if we got lucky with this)
6. Once windows has fully loaded, go ahead and click start, then control panel, then find user accounts and family safety.
7. once in here, there should be an option to edit your account. Go ahead and make the changes necessary to your password.
8. once this has been done and everything is has been applied, go ahead and restart your computer.
if you follow these instructions, you should be able to get your account back up and running no problem. i wish you the best of luck.
Aug 19, 2011 | Lenovo IdeaPad Z560 Laptop
Download webcam drivers
Download Here
For complete and updated driver just follow the link
*Brand: Notebook
*Family: IdeaPad Y510
*Operating System: Your Operating System
*If the driver for Windows 7 is not available you can use the Windows Vista Driver. Just make sure to check the version of the OS for Win7 32bit download Windows Vista 32bit Driver for Win7 64bit use Windows Vista 64bit
*You can also use Option 3: Lenovo Smart Downloading
*After Installing the driver press F5 + FN to enable the wireless switch
Thanks for using Fixya
Jul 19, 2010 | Lenovo IdeaPad Y510 Notebook
Lenovo netbook wont turn on. It is brand new, and ...
hi! just a tip if its a brand new one try to isolate the problem check if it can actually run by removing the battery just by the ac adapter if still doesnt work then probably you have to charge the battery first if it still doesnt charge then probably there is somethin wrong with the power board. i suggest you call your lenovo tech support for further assistance. hope this would help goodluck!
May 20, 2010 | Lenovo IdeaPad S10e Netbook
My Ideapad Y430 is not booting up ! It just hangs on startup and there is no action. I booted in Safe mode, restored the system to an earlier date - but the problem persists. help please ....
If you can boot into safe mode, then you can run a repair. If you have Vista, then just boot from the cd and choose repair from the choice menu. You can also run repair from xp, when it gives you the choice menu of three things to choose from, choose to install windows, then the next thing, it will find your current windows installations and ask if you would rather repair the current one, choose yes and see if windows will fix itself. If that doesn't help, run the disc again and get into the command prompt and try fix the master boot record or fix boot. When the command prompt comes up type in FIXBOOT, there is also the command FIXMBR. click ok, restart and see if the machine boots up. Otherwise try to run diagnostics on windows from safe mode if possible.
Aug 29, 2009 | Lenovo IdeaPad Y430-5242U Notebook
Lenovoy430 ideapad drivers and os
All the drivers needed for your computer are here
http://www-307.ibm.com/pc/support/site.wss/product.do?doctypeind=9&template=/productselection/landingpages/downloadsDriversLandingPage.vm&sitestyle=lenovo
Operating systems are here
http://www-307.ibm.com/pc/support/site.wss/product.do?brandind=17&familyind=0&operatingsystemind=49979&template=%2Fproductselection%2Flandingpages%2FosInstallationLandingPage.vm&validate=true
Jul 01, 2009 | Lenovo 3000 Y410 Notebook
Lenovo Ideapad Y510 NVIDIA Driver for WindowsXP
go to lenovo or ibm webpage and select drivers download, chose your model and your operating system and download the display driver make sure it says nyvidia display driver . this will fix your problem.
Best Regards
Mar 19, 2009 | Lenovo IdeaPad Y510 Notebook
Lenovo IdeaPad Y530 - 40512SU screen is dark
Have you installed the Lenovo EnergyCut drivers? Without it, laptop may not work properly and turns extra hot. Try letting it cool down before you try again.
Oct 27, 2008 | Lenovo IdeaPad Y530 Notebook
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
406 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
