Question about Can You Imagine Plasma 360 Plasma Light with 8 Inch Globe Ball
Poor thing no longer turns on.
We bought 4 of these. The first two broke. The third didn't turn on. A fourth turned on at first then was put away in its packaging so it couldn't break. It was removed from its packaging a few months later. Nothing. Is there something I can do?
Stop buying them.
Posted on Jan 26, 2013
Bike will not turn over, security icon flashes alone with the turn signals. Battery test OK.
Have you used the new PIN to manually disable the security system?
Do not turn handlebars, straddle seat or lift motorcycle off the jiffy stand. During a PIN disarm, if the security system detects motorcycle motion the system will activate.
Turn ignition to IGN.
If armed, the odometer window display will read: ENTER PIN and the security lamp will be flashing at a fast rate. The headlight will not be on.
Press and release the left turn signal switch.
In the odometer window, a flashing 1 will appear.
Increment the digit by tapping the left turn signal until the odometer window displays the first digit of the PIN.
The first digit in the odometer will be the first digit in the PIN.
Press right turn switch 1 time.
The first digit is stored and the next digit will flash.
Increment the second digit using the left turn switch until the digit reaches the second digit of the PIN.
The second digit in the odometer will be the second digit in the PIN.
The second digit is stored and the next dash will flash.
Increment the third digit using the left turn switch until it reaches the third digit of the PIN.
The third digit in the odometer will be the third digit in the PIN.
The third digit is stored and the next dash will flash.
Increment the fourth digit using the left turn switch until it reaches the fourth digit of the PIN.
The fourth digit in the odometer will be the fourth digit in the PIN.
The fourth digit is stored and the next dash will flash.
Increment the fifth digit using the left turn switch until it reaches the fifth digit of the PIN.
The fifth digit in the odometer will be the fifth digit in the PIN.
The fifth digit is stored. The security system indicator lamp stops blinking.
Smart Security System is disarmed.
If a mistake is made while entering PIN, turn the ignition Switch to OFF before entering the last digit and then start the procedure from the beginning.
If the procedure fails to disarm the security system, wait two minutes before attempting another PIN disarm.
The security system will remain disarmed until the ignition is turned to OFF.
Apr 04, 2014 | 2005 Harley Davidson FLHTCUI Electra Glide...
Samsung dlp hl55679w
It sounds that the light engine has the fault. Contact the authorizes service center for Samsung.
Jul 21, 2013 | Televison & Video
1997 honda civic died on the road wont turn over
Start with the battery unless fairly new & have that tested
Next turn key on & listen for fuel pump
It may run but not have pressure or volume
Check fuel pressure at motor with a gauge
Any light on dash & you checked for codes
didn't you? What are they?
Turning over & Starting are two different things,
don't use them together,different systems there
Oct 03, 2012 | Honda Cars & Trucks
1999 CHEVY LUNINA WON'T START BATTERY AND
Check the dash once you turn the key to the run position the passlock runs a security check using a set resistance value through the chip in the key. If the security light begins to flash the reading it received was incorrect or it didn't get a reading at all. You can try reseting the value it is looking for by turning the key to start then releasing it. After 10 minutes turn it off then cycle it start again leaving it in on for 10 minutes then back to off then one more time. After the third cycle has completed for a total of 30 minutes. You should be able to turn the key on and start the vehicle. If the light continues to flash their is a problem with the chip in the key or the connections within the ignition its self. Both are common but a Pass Lock Relearn as described above will usually adapt to the poor connection values. Hope this helps.
Aug 28, 2011 | 1999 Chevrolet Lumina
How do i put the code in on my blaunpunkt freiburg cd34
Blaupunkt Freiburg Code Entry
Turn on the radio, the display will show 'CODE'
Press preset [ 1 ] repeatedly for the first digit followed by [ station + ] Press preset [ 2 ] repeatedly for the second digit followed by [ station + ] Press preset [ 3 ] repeatedly for the third digit followed by [ station + ] Press preset [ 4 ] repeatedly for the fourth digit followed by [ station + ]
Finally press the [ station + ] button to save.
Jun 28, 2011 | Car Audio & Video
My whole system is working, but when I turn the volume up on my radio past4 my subs go out. What could be wrong?
The most likely solution is that your voltage is dropping too much and the amp is going into protect mode to save itself because of the lack of power. Double check fuses in the amp first and then on the power cable and third make sure all the connections are solid, i.e. ground and power wire. Another thing might be to check that you didn't switch the polarity by connecting negative and positive wires to their opposites.
Apr 19, 2011 | Jl Audio Car Audio & Video
Timer alarm volume is down
iam sorry to tel you there is no way of turning it up you would have to get a new timer
Paul http://www.apart4u.co.uk
Mar 04, 2010 | Ovens
Mitsubishi Lancer 2004 Radio Code Not Working
Use the first four radio station preset buttons to enter the code.
1: Push radio preset#1 until first digit of your code appears.
2: Push radio preset#2 until second digit of your code appears.
3: Push radio preset#3 until third digit of your code appears.
4: Push radio preset#4 until fourth digit of your code appears.
5: Push either tape or cd button.
What to do if your radio says OFF instead of CODE
(Courtesy of mittech)
If your radio says OFF it means you entered the wrong radio code three times. To get it to say CODE again do the following.
1:Turn the key to on or accessory.
2:Push the power button so that the radio display says OFF.
3:Let the car sit for 1 hour.
4:The radio display will go blank.
5:Turn the radio on and it will say CODE again.
Sep 04, 2009 | Infinity Reference 1211a Car Audio...
The blower on my spa will not turn on
If you've made no changes to the wiring from when it worked correctly, then it can only be the switch. Get a new one, switch off the breakers, and wire it in according to the instruction that come with it.
Apr 30, 2009 | Intermatic PART - AIR SWITCH 4 FUNCTION...
Can You Imagine Plasma 360 Plasma Light with 8 Inch Globe Ball Logo
41 people viewed this question
Top Can You Imagine Toys Experts
ray gallant
Are you a Can You Imagine Toy Expert? Answer questions, earn points and help others
