Question about HP Computers & Internet
HP Laptop has been turned off at power point,a few times, now will only boot up to 80 percent. how can I fix this problem.
  • 849 Answers
Seems, operating system go bad, re-install windows.
Posted on Oct 27, 2008
As you your battery life of your notebook ? The main problem with laptops is often the battery , after a year of heavy use loses almost 50 % of the power . How can I prevent that ? Have you could keep a...
I have some tips to keep your laptop battery live longer
1.don't undercharging and overcharging,laptops battery can reach 100 degress Fahrenheit and such heat can damage your battery. slowly but sure
2.ideally,you should try to keep your battery charged from 20 percent to 80 percent. i know it's inconvenient to unplug the charger before it reach 100 percent,but try to keep it charged near 80 percent
3.try to charge your battery constanly,and unplug it when you think its almost fully charged,overcharged can heat your battery and damage it
4.keep your laptop as cool as possible,don't try to charge the battery when the computer is turned on,even if the battery is going to 0 and you still need to use it,just shut down the laptop first and charge it,at least until the battery is charged 20%,unplug the charger and turn it on
Well,there are many other tips to keep your battery alive,but i only have those 4,thanks for using fixya
and good luck with the tree-planting project,i love environment very much
Aug 29, 2012 | Dell Latitude D630 PC Notebook
Why my r430 not charging up to 100 percent? only up to 80 percent then stop
Its a feature of the laptop, you use it plugged in more than battery power right? If you go toStart Menu/Programs/Samsung there should be a program called "BatteryLife Extender". Click on it and you can choose to either let it charge to 80 percent or all the way to 100. However, if you use it plugged in mainly then I would recommend leaving it only to 80 percent to avoid possible discharging of the battery from constantly charging. Hope this helps.
May 06, 2012 | Samsung R430 Notebook
My aspire 5740 showes 81% available but not charging, checked all power lines etc on balanced power. Bought laptop 3 weeks ago till today it charged up
Dont be panic. Your laptop has absolutely no problem.Your manufacturer had set a 80-20 policy for the laptop battery charging such that the battery wont be charged to 100 percent but it will charged only upto 80 percent. The makers of the lap are doing this because to give good life to the battery.You can change it by going into the power options inside control panel.
Mar 23, 2010 | Computers & Internet
HP Pavilion DV6700 won't boot
Possibly overheating? As you say that when you press and of the F-Key option nothing is happening, and also the fan is running at full power, if the fan is louder than usual, then it could be overheating in the air vents which you can find either at the sides, back, front and underneath the laptop, try getting the compressed air, and giving the air vents a blast to get all dust out. Or a vacuum. Do it whilst laptop is turned off though!
Jan 26, 2010 | HP Computers & Internet
When i try to boot my laptop the percent hits 90 and freezes
boot into safe mode, (repeatedly press F8 at power on)
Then try a regular boot.
if that doesn;t clear the stuck driver, then you may need to look at the system restore option
in safe mode, you can reset the computer back to the last few days.
look in accessories\system tools\system restore
Jan 05, 2010 | Acer Aspire 3000 Notebook
My compaq laptop won't turn on
Remove the battery and use the A/C power adapter ....
The power supply is not powerful enough to charge the depleted battery and also power up the laptop at the same time. Your power supply is probably 40 watts... a 65 or 80 watt A/C power adapter is best, but you don't really have to buy one.
After the laptop has started and Windows has settled, put the battery back into the laptop while the laptop is still powered on and running.
Let the battery charge up for a few hours.
Hope this trick works for you!
Sep 18, 2009 | HP Compaq Presario V2000 Notebook
Hp Laptop Wont Boot
Hey dear,
Your operating system got crash. Use backup CD.
Turn on yr lappy. manually open the cd rom from right side of leptop. Put CD in. then wait for few seconds. u will see the screen then follow the instruction and re install the entire windows.
Sep 13, 2009 | HP Pavilion dv6000z Notebook
Laptop won't turn on and charging light is not orange when plugge
I had the exact same problem. Here is the fix: remove the keyboard, battery and CMOS battery then press and hold the power button for a min. Plug just the power in then try to turn it back on. If it doesnt remove more perhiprels such as DVD, memory, hard drive then do the power button hold cycle again. After it turns on, remove the power then add the perhiprels you need to boot to BIOS, i.e; keyboard & memory. Go to BIOS then plug in the battery while the laptop is running. Unplug the power to see make sure laptop runs on the battery. Turn off then add the rest of perhiprels then plug it in power again before closing all up. If the orange light problem comes back repeat above! OR you can take it to your HP dealer to have it fixed under warranty if you are lucky. Then never buy HP ****!
Hope it helps...
Mar 14, 2009 | Computers & Internet
My hp laptop will not boot up
Check the power supply for power. Replace if necessary. Also check the motherboard for proper operation. If no fans come on or only come on for a few seconds then you have a bad motherboard
Feb 14, 2009 | Computers & Internet
Battery not charging
do a complete discharge by setting your power options to allow that to happen from the control pannel then recharge and see what happens.
Often this fix it.
Good thing to do to extend battery life esp if the laptop is pluggin alot.
Jul 18, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
