Question about Gateway Computers & Internet
Hard Drive Problem
I have an old Gateway PC that I rebuilt. I had to wipe my HD. Now when I install my Windows XP Home OS It doesn't Format it right. Usually It is formated in Local Disk (C:). Now my PC is calling Local Disk (C:); Removable Disk (C:) as a Generic USB CF Reader USB Device. It now writes a new raw volume and formats it as Local Disk (I:) and does not recognize the formating or the file system. I tell it to format it on an NTFS system. Can you tell me how I can fix the problem and get it back to Local Disk (C:)??
  • 849 Answers
Use manage, by right click on my computer, then disk managment
Posted on Oct 27, 2008
I have a old gateway pc and I would like to install a Hard Drive from a Dell pc into it. Can it be done?
Swapping the hard drive from the Dell into the Gateway will not work because the Dell hard drive has been installed with Dell specific drivers and configurations.
When you install the Dell hard drive into the Gateway you need to wipe the hard drive and install a fresh copy Windows XP onto this hard drive and the Gateway device drivers etc.
Oct 29, 2012 | Computers & Internet
I am unable to format the hard drive on my Gateway Laptop. I am trying to wipe the drive by formatting it but no luck so far I try to use the Disk Maintenance program in Windows XP but it doesn'
You can't format the active drive / partition within itself. It's like throwing away your clothes while you are wearing them in public. You just can't do it. Sorry, that's the only analogy that came to mind.
You format it with a boot disk like, an OS installation disc, USB drive with an OS installation, or a boot disc you found online (CD or USB).
If you have none of those, boot to command prompt by pressing F8 during boot. When you get there C:\ Type format c: Thats it. No going back, so make sure you saved and backed up your documents. You also need a way to install an OS, if you intend to do so.
Oct 05, 2012 | Computers & Internet
Have a HP SR1010V, 33GB HD - XP Home. Want to 1) replace HD with a 100-200GB HD OR 2) ADD a 100-200GB HD and 3) ADD a DVD drive. What is best way to copy data to a new HD and to boot the new HD. Rather...
The easiest route would be to install the new hard drive in place of the old hard drive and place the old hard drive below the new hard drive and make it a secondary hard drive or slave drive. Once you have them installed this way you can install Windows XP Home to the new hard drive once you have it installed to the hard drive then you can copy everything from your old hard drive to the new one. Once you have everything copied from the old hard drive you can then format it within Windows to have 33GBs of space to store anything you wish. If you need more detailed instructions don't hesitate to reply.
May 19, 2010 | HP Compaq Presario SR1010V (568656) PC...
How to format hard drive
To format any extended or external hard disk
Right Click the drive (example D:\ )and select the FORMAT Options
Click START to Format the Hard Drive. The time to format depends on size and the condition of the Hard Disk.
Feb 15, 2010 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
I installed a new hard drive in a Gateway 4XL.
See your hard disk Jumper setting it could be wrong change jumper of your hard disk then install the windows.
Mar 07, 2009 | Gateway Profile 4 XLb PC Desktop
Windows XP OS installation
its not a virus as when you format your hard drive it would wipe it out ... how many hard drive do you have ? if you have 2 install a new instalation to the good hard drive and you should get to the part of xp that says do you want to format the partition on this hard drive by pressing ( f ) do this and when your pc has finished re-installing you can click on my computer in your start menu then right click on the bad hard drive and run a full format from there ...
hope this helps ... jedi-inc ....
Feb 09, 2009 | Microsoft Windows XP Professional
I have two operating systems on my hard drive.
You can manually disconnect the IDE/SATA cable temporarily from your motherboard (the one with NT PRO & XP HOME), then you can cleanly install a Windows XP on your new Hardisk. And after installing, you can re-connect the other hardrive on your computer and format it under your NEW Windows XP, be sure to set the BIOS BOOTUP sequence that you boot on the right drive.
-mrsolution
Jun 11, 2008 | Gateway GT4022 PC Desktop
IBM NETVISTA P4 2.4G. no O.S.
If your old copy of win xp is not being used by any other computer then reformat the entire drive with xp. Also make sure that your drive is not divided into 2 or 3 sections. All updated will be available on the windows update site. The reason that I prefer tostart from scratch is Everything is new with no lingering Junk programs in the background. Need help email me at ddugard@cox.net
Apr 13, 2008 | IBM Netvista Intel Pentium 4 2.4GHz /...
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
Computers & Internet Logo
85 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
