Question about Garden
I have a Balboa VS500Z . The circuit board burned up where the heater buses are located . I replaced the board and the heater . Know when I start the Spa it primes at low speed for about a minute . Then shuts down with code DR or HL .What could this be?
    Scholar:
  • 111 Answers
DR code - Inadequate water detected in heater.
HL code - Hi Limit, Spa over heat. In your case the Hi Limit is preventing the element from burning out.
This means there is no water or not enough water flowing through the heater.
Common causes:
Hi Limit sensor failure.
Blocked suction, skimmer.
Are the gate valves all the way open/up?
Pump is not functioning correctly, impeller/wet end failure.
These are the most common, but there are also other causes.
I hope that helps
Posted on Feb 27, 2012
shaddow4115
  • 105 Answers
SOURCE: When I put power to my unit. A Sn code appears.
If the SnS or Sn Message is Alternating with the Water Temperature on the Display, it is a Possible Sensors Out of Sync Message.
If the SnS or Sn Message is Blinking or Flashing OFF and ON without showing Water Temperature, it is a Verified Sensors Out of Sync Message.
http://service.balboa-instruments.com/ErrorCode/ for code info
Posted on Dec 11, 2009
Ian  Hot Tub
  • 77 Answers
SOURCE: I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
Posted on Apr 01, 2010
SOURCE: Balboa vs500/501/502 gs500/501/502 I just refilled
Hi, I have a balboa 500z series pump. I had to refill the tub today and once the tub was full I restarted the pump only to have the sr display. It states I should reset the pump but, doesn't explain how to do this. Can anyone help?
Posted on Jun 11, 2011
SOURCE: What is the difference between
The Balboa VS500Z supports one two speed pump, an ozone, and 12v spa light and an optional circulation pump.
Whereas the VS501Z will support a two speed pump, a single speed pump or blower, an ozone, a 12v spa light and an optional circulation pump.
Basically the two are very similar except that the 501Z will support an additional one speed pump or blower.
The best suggestion if you are doing a replacement is to purchase one of the Value Pack Retrofit Kits available through Balboa. You basically get everything you need for the replacement, including the topside, cables, and overlay.
You can find everything you need to know about making the replacement on the following page:
BALBOA VALUE PACK VS RETROFIT KIT
Hope that helps!
Posted on Sep 09, 2011
SOURCE: I need to replace my
The best suggestion in this case would be to replace the spa pack and upgrade. this is a really old system. You can replace the entire system for around $500.00 and have the latest working technology along with a new topside panel, overlays, heater, system, etc. The Balboa Value Pack Retrofit kit comes with everything you need along with cables. Since you have Weslo with an oval panel, the best suggestion would be the Balboa 54219-Z Value Pack Retrofit Kit. you can get it online by clicking on the link I have provided.
Hope that helps.
Balboa Direct
Posted on Sep 12, 2011
Where do I find the model number of the Balboa Duplex and where is the heater located?
Hi, on Balboa control systems there will be a metal heater tube either at the bottom or the back of the control box, this tube will obviously join your spas pipework at either end. The part number will be located in the middle of the tube, normally on a silver or white sticker, if you send me a picture of your control box or the heater tube i can direct you to the exact replacement. contact me on our website contact page, www.hottubpartsuperstore.co.uk
kind regards,
Mick
Apr 15, 2013 | Balboa Instruments Pool & Spa
Overheat errors
possible temp sensor bad if ok bad control board
Feb 25, 2013 | Balboa Instruments BALBOA VS500Z PUMP ,...
Spa Heater problems- Balboa VS-501 controls #54356.
Use a high quality external temp probe and make sure the temp sensor in your system is correctly reading the water temp.
If the water is truly 110 then you may need to replace the board completely.
Jun 20, 2017 | Pool & Spa
I have a Balboa WH-R576-DCAH. All controls seem to operate ok but no heat. Both motors seem ok, pulling about 5amps each. Not an expert but was able to manualy close the relay and cause the heater to...
If the pressure switch is jumped properly and you still are not getting a call for heat, then you are having a problem with the circuit board and it most likely is going to need to be replaced.
If the heat light is coming on but no voltage is going to the heater, this would also indicate a bad board.
You can find the 52213 circuit board online at: http://balboadirect.com/52213.aspx.
Hope that helps.
Aug 02, 2011 | Jacuzzi Balboa R574 System for 1 2 Speed...
What is the difference between a Balboa VS500Z and a VS501Z
Hope that helps!
Jul 12, 2011 | Balboa Instruments Duplex Digital Panel 2...
I have been unable to switch operating mode of Balboa spa controller VS500Z from 110 volts to 220. I have 220v appearing at the neutral in that has nothing connected to it. Dealer gives up. Balboa does not...
I had to wire mine the same - found this on their website - check the bottom left corner - you should be all set. Good luck!
http://service.balboa-instruments.com/appnotes/VS5xx_Config_Guide.pdf
Apr 13, 2009 | Home
Garden Logo
480 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
