Question about Sylvania LC195SLX LCD TV
Sylvania TV LC195slx with vertical green line across the screen
Vertical green line appeared on the screen over the holidays. TV is lightly used in the guest room. Inexpensive TV that doesn't warrant a repair bill, but is their a known quick fix?
SOURCE: Sylvania 6620LCT 20
throw it in the landfill there are no replacement parts.
Posted on Nov 02, 2007
SOURCE: shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Posted on Jan 05, 2009
satavlad
  • 405 Answers
SOURCE: lcd tv screen has two vertical lines on startup
It is not repairable and it will get worth, if unit still under warranty you should get it fixed or exchanged now.
Posted on Nov 11, 2009
Angel Petter
  • 114 Answers
SOURCE: need remote controller code for LC195SLX
try this web site!
http://www.remotes.com/?gclid=CPLN2dnd6J8CFQMsawodNiW9GQ
Posted on Feb 10, 2010
SOURCE: I need remote code for Sylvania LC195SLX for ATT
hi! i have here a couple of codes for your sylvania tv. you could try them 0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161 hope it would help! goodluck!
Posted on Jun 03, 2010
Should the T-CON board be replaced on a Samsung LN40C650 LCD TV to fix the vertical lines problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 08, 2015 | Samsung LN40C560 LCD TV
Green vertical lines across the screen.
Green lines on LCD screens generally means physical damage. Did you drop it or bump it by chance? Physical could also include the cable that you are using. Try using a different cable, or make sure it is connected all the way.
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Mar 05, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Line across the tv no sound no picture
If you look carefully at teh line it should be red, green, and blue close together to appear like a white line. If this is the case, then the vertical circuit has failed. This is often poor solder connections at the vertical IC or a defective IC. Expect a parts cost in the $20 range for this repair.
Dan
May 04, 2010 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No picture just a line across t.v.(sylvania 6427ff)
The vertical IC are blown you gotta change it.Good luck.
May 23, 2008 | Sylvania 6427FF TV
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Television has no picture
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
Jul 12, 2007 | RCA P52937 52" Rear Projection Television
Sylvania LC195SLX LCD TV Logo
67 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
