Question about PNY Electronics - Others
I want to add a password to one that's already installed.
How do I add a password to open the usb?
  • PNY Master
  • 27,725 Answers
Click start click on computer to open you should your drives
C: usually your hard drive D: or E: your cd/dvd drives if you have 2 and your usb drive possibly E:or F:
Click on your usb drive right click in it select new folder option you can name it
Then put all files or data you want to password protect
Right click on the folder select properties then click sharing tab tick in make this folder private box
Another message might appear you do not have a password on this account click yes
User and password account will open for you to put in place a password
This might vary depending on your operating system in XP
Select properties then security tab at learn about access controls at the bottom of the box
Also another option to change permissions click edit
Then click deny then click apply in W7
Hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/usb-safeguard-free/3000-2092_4-75115673.html
USB Safeguard is a portable software program to encrypt and protect data with a password on your removable pen drives using the AES 256 bits encryption.
The main purpose of using a USB pen drive is that you can bring your data with you wherever you go. But if you lose your USB pen drive your data also lose.
This is dangerous if you have confidential files stored in it. Protect the pen drive with a password. USB Safeguard offers users (novice and expert) a friendly yet extremely powerful security solution that fully protects valuable data stored on USB pen drives.
Also, the program has a useful feature that allows you to enter your email or phone if you lose the pen drive. Free version works only with USB Flash drive of size max 2 GB
hope it helps you
Posted on Feb 26, 2012
Clavier n'inscript pas mon de passe bios
open the computer and find BIOS RESET button or PASSWORD RESET button and reset it! It will eliminate your password so you can add a new one! Or your keyboard is USB some models demand PS2 keyboard!
Dec 27, 2012 | Dell Dimension 3100 PC Desktop
How to add usb ports to Dell 530
Suggest use a USB adapter card.
More specifically a PCI USB adapter card.
Dell Support > Inspiron 530 Series Desktop PC > Owner's Manual,
http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/index.htm
In the list click on - Removing and Installing parts
1) Unplug the computer from power.
[Unplug FROM the surge protector, not the back of the computer. (Power Supply)
Unplugging from the back could lead to a power surge ]
2) Computer on a table open the computer case,
Click on - Removing the Computer Cover - in the list.
3) FOLLOW Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware inside the computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
4) http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/parts.htm#wp1184332
Here you see an illustration of your motherboard. Oriented as it is in your computer case. (Just no hardware components, nor cables are attached)
At the bottom of the motherboard are 2 White long expansion slots.
In the illustration they are labeled by the numbers 21 and 22.
If one of these slots is open, and not being used, you can install a PCI USB adapter card.
This is one example of a PCI USB adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&Sku=S262-2744
At the back of the computer, located towards the bottom, are the Expansion Slots.
Four horizontal slots.
If there isn't some sort of add-on adapter card already installed, all of the expansion slots will be covered with an Expansion Slot Cover.
If there is an add-on adapter card installed of course, one of the expansion slot covers will be removed.
Line up the PCI USB adapter card with the open PCI slot, you have chosen.
Now look at the expansion slots at the rear of the computer.
Notice what expansion slot that the PCI USB card's bracket, lines up with.
Go to the back of the computer, and view the small metal bracket on the bottom right. Loosen the Thumbscrew, and swing the bracket out. (Thumbscrew is supposed to just loosen, not come out)
Remove the expansion slot cover for your PCI slot choice.
Install the PCI USB adapter card.
Note that there is a Locating Lug in the PCI slot, and a matching Locating Notch, on the PCI USB adapter card.
Line them up, then push the PCI USB card straight down into the PCI slot.
Also watch the metal bracket on the back of the PCI USB card.
The 'tang' at the Bottom, slides down in-between the framework.
The top of the bracket has a half-moon notch, that lines up with a small 'dowel' on the computer case framework.
Make sure it is aligned, and the bracket is aligned.
What I am referring to will become readily apparent, as you go to install the PCI USB card.
If there are any other add-on adapter cards, they may try to fall out, when you go to install the new add-on card.
You just have to line them up, so their bracket notches are all on the 'dowels', and hold them in place. Then swing the 'door' closed. Tighten the thumbscrew.
If you have an Add-on card in the way, and by moving it to the other PCI slot, will allow you to install the PCI USB card, go ahead, and move it.
Doesn't matter. BIOS will find it, and assign an Interrupt Request.
There are two other expansion slots above the 2 white PCI slots.
The expansion slot right above the top PCI slot, is a PCI-Express x1 slot.
If this slot is open, OR the only one available, you can use a PCI-Express USB adapter card.
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606149&CatId=511
The last expansion slot you have is above the PCI-Express x1 slot.
This is a PCI-Express x16 slot, and is ONLY used for a graphics card.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 13, 2012 | Dell Inspiron 530 Desktop Computer...
Forgot password
  1. Download a software called Active Password changer.
  2. Install it in another system and insert a CD/DVD or a USB Pendrive to the system.
  3. Open Readme File in the Installation directory of the software and follow the instructions to load the inserted CD/DVD or USB with the software..
  4. Boot your system with the removable device (CD/DVD or USB) and start the password removal process.
  5. The rest of the steps will be explained in detail by the software readme file.
  6. your password will be removed
May 20, 2012 | Computers & Internet
I bought the store model laptop, how do i reset it to factory settings
i assume by saying there is already a password on the laptop, you're referring to a windows password, when the computer boots start tapping f8, you will be presented with a boot menu including safe mode, start windows normally etc... there should be an option for 'repair your computer' arrow down and hit enter. once windows recovery console loads click next a couple times and then you'll see another menu. the new menu should have a bunch of repair options one of which is restore to factory default. click that and follow the prompts. once it's done you'll have to go in and remove all the bloatware installed by the store.
Feb 10, 2012 | HP Computers & Internet
I can't access my yahoo messenger account and i already tried to uninstall it and installed the latest yahoo messenger but to no luck. i entered my right id and password and i open my mail and its...
1. Delete Temp files and cookes @ IE - Tolls - Internet Options
2. Download and run "Spybot Search and Destroy"
3. Make sure to uninstall all Yahoo Messager files in ther control panel - "programs and features" or "Add and remove programs" before installing a fresh copy
4. Click forgot password, have them E-mail it to you and change it if you are given the option
5. If all else fails, reinstall OS, guarantee to work then.
Jun 28, 2011 | Computers & Internet
Is it possible to install a bluetooth device on a computer apart from usb
If you have a laptop computer, then the only way to add Bluetooth is with a USB adapter. There isn't any other place to add anything. On a desktop machine, you can install an internal Bluetooth card in an open PCI expansion slot on the motherboard or use a USB adapter.
May 17, 2011 | Compaq Computers & Internet
How to add songs in ipod
Assuming that you already have itunes installed and your iPod isn't sync'd with your library:
1. Open up itunes
2. Plug the ipod usb cable into the computer's usb port and plug your ipod in at the other end.
If you don't know which is the usb port on your computer a symbol next to it should look like this:
http://www.dailycupoftech.com/wp-content...
3. Wait for your ipod to show up in itunes
4. Select the songs you want to put on your ipod and drag them over into the "Music" folder on your ipod and wait for it to load.
5. When you are done, make sure you eject your ipod
There's an eject sign next to where it should show "(Your name)'s iPod"
That should be it
Depending on what kind of iPod you have there MIGHT be a different way to do it but I know this way works with the iPod mini, nano, and video.
If your iPod is synced to your library all you really have to do is plug it in and it adds all of the songs in your itunes library to your ipod.
http://support.apple.com/kb/ht1351
Hope I helped
May 13, 2011 | Sony Network Walkman NW-E503 MP3 Player
What is the administrator password of hp t5740?
If you have lost windows password, the best thing for you is creating a password reset disk.Actually,when you add a password to your pc,the first thing you should do is creating a disk in case you lost the password.But how to make a password reset disk after you have lost the password ? Follow these
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Key
Then let's begin
Step 1.Login to a PC which can link to internet,Download and install the program in that PC
Step 2.Run the program and burn to CD/DVD OR USB flash drive
Step 3.Turn to your locked PC,insert the newly create CD or USB to your drive.Reboot the Computer and then follow the instructions,it is very easy to use.
Jan 25, 2011 | Computers & Internet
My usb drive is very low iam already install all drivers
You need a small file from BIOSTAR that adds USB 2.o support. Go here :http://exehub.com/biostar-g31d-m7-motherboard-drivers-specs/ and go to the bottom file,download it and install it and you'll be good to go :) cheers.
Oct 24, 2010 | Biostar G31D-M7 Motherboard
My dell 922 aio will copy and scan but will not print
you need to install driver on the computer
go to start>printerandfaxes
add printer
pls add printer depends on usb or network
if you are already installed
check the printer faxes
any message below like door open
if like this you have to close door
check the correct driver installed or not
Oct 31, 2009 | Dell 922 All-In-One InkJet Printer
Electronics - Others Logo
98 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
