Question about Toshiba 46SL417U LCD TV
Toshiba 46SL417U TV green lights blinks 3 times will not come on
SOURCE: No Picture on Toshiba 42RV530U
I had a similar problem to this yesterday. Tv is same Toshiba model as you mentioned about 4 months old. In my case, after the TV working perfectly following installation, the standby LED on the front (the one that is red on standby and green when on) went to a flashing orange (after switching on from standby) and the picture disappeared although the sound remained OK. I was unable to get any response from the setup or menu on the remote, otherwise I would have tried resetting the TV. Regardless of how much switching off/on (including disconnecting the powerlead and leaving for few minutes), disconnecting all peripherals, etc., nothing helped. I looked up Toshiba's web site and under support they basically suggest switching off the TV and restarting using the onset buttons (not the remote) and pressing the menu button (again the one on the set (not the remote) and if you could get the menu box to appear then reset to default settings. I tried this but the results were the same. I therefore thought the TV was defective. However, after much frustration I did the following (I think): 1) Disconnect everything from the TV 2) Powered up from the mains switch whilst keeping BOTH the startup and menu buttons on the side of the TV pressed down. The result in my case was that the standby led and one of the two beside it flashed green simultaneously. However, when the buttons were released, the TV started up the same (flashing LED orange and sound no picture). 3) Pretty well defeated at this point, after doing the procedure at (2) several times with the same results, I somehow thought of pressing the standby button on the remote either whilst the two buttons on the set were depressed or just after they were released. I am afraid I cannot remember which and cannot replicate the problem as I don't know what caused it in the first place. 4) The TV then started normally ( no reception as I had not aerial connected, etc.,) but I was able to gain access to the screen menu/setup buttons via the remote which were in French rather than English. However, after reconnecting everyrthing the TV has worked fine (obviously after resetting the language via the menu). I am sorry I cannot be more precise but I hope this might be of help to someone with a similar problem.
Posted on Dec 22, 2010
  • 3 Answers
SOURCE: My toshiba 42lx196 tv has
main power board needs to be replace
Posted on Jan 27, 2011
Ecollier2012
  • 3459 Answers
SOURCE: HI I have a 32xv515dg LCD-TV. It
This is a common problem an a failry easy DIY fix.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Posted on May 01, 2011
budmrtn
  • 11361 Answers
SOURCE: My question is that my toshiba tv 37inch tv, stop
It may be in safety down mode due to shorted circuits or failed power supply. I would start at the power supply section first by looking for any caps with domed/leaky tops, burnt components, etc.
Please read my guides first;
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 26, 2011
SOURCE: tv will not turn on
Your main power board located in the center where your power cord will plug into is going bad, actually it's just a relay. I have the same problem, tv works for hours til relay overheats, then tv shuts off and tries to restart, hence the clicking and the 3 green flashes, mine will actually restart after 15-30 minutes. search online for the board, ranges anywhere from 150-280. I haven't found anyone to sell just the relay. I am trying tv with rear panel removed and cover removed from relay to see if relay will not malfunction? Board is a simple plug and play, just remember to have the tv unplugged.... you can actually remove the rear panel while on it's stand, just don't remove the screws holding the base onto the tv.
Posted on Nov 18, 2011
I have a 2011 Toshiba 55 55SL417Uand the picture wont come on the green flashes 3 times pauses 3 flashes pause over and over
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 21, 2015 | Toshiba 55 55SL417U LCD TV
No remote control will work my toshiba 46sl417u ?
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 04, 2014 | Toshiba 46SL417U LCD TV
You turn on the TV, the green light flashes 3 times, then flashes three times again. It turns on great picture, you can open the menu, change sound up or down or mute it. Then about 15 seconds later you...
have you had the freeview board off and used tv with it not on. sometimes the built in free view board can fail and use the processor speed up. so no menu etc also will affect the inputs..
Oct 01, 2013 | Toshiba 46SL417U LCD TV
Toshiba 46sl417u what does the T-con board control
This board takes the video signals from the signal board and converts it to the correct format to properly let the panel present the picture. It acts like a buffer that also corrects for gamma and sometimes controls the back lighting for dynamic contrast.
Sep 29, 2013 | Toshiba 46SL417U LCD TV
How do I get a eeprom i.c for my Toshiba 46sl417u
contact to Toshiba . or local spare / component market in your city .
Sep 02, 2013 | Toshiba 46SL417U LCD TV
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
Toshiba 51H94 wont power. The light blinks green 3 times/sec
This problem was resolved by doing the following: turned power off to circuit; unplugged tv; removed back "grate" and vacuumed out dust; vacumed fan on right back side; spun fan manually a bit; jiggled fan connection near power cord; plugged back in and it worked. I suppose there was a loose fan connection, and the TV wouldn't power on without a functioning fan.
Aug 03, 2009 | Toshiba Televison & Video
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 46SL417U LCD TV Logo
1,021 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
