Question about Fuji FinePix J10 Digital Camera
My battery np-45 won't charge. the light in the charger lights for a few seconds and then goes out.
Do i need a new battery or a charger?
SOURCE: Fuji Fine Pix Z5 battery won't charge
My sister's Z5 was having the same problem. I realized she had the battery in upside down. There are no guides on the battery to insure that it goes in the right way.
If the battery is in correctly, and it is still not charging, I would call Fuji to get it repaired.
Posted on Apr 12, 2008
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
Posted on Sep 26, 2008
SOURCE: Camera Won't Charge
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Posted on Oct 03, 2008
SOURCE: FUji FinePix s1000fd, camera will
I have same problem as edmoze mentions above - batteries went dead. I first tried to use regular Duracell AA and it would still not come on. Went to internet & it recommended getting the Duracell rechargeable NiMh which I did. Got the charger & last nite they charged overnight. Today the camera did come on & I was able to download what I had taken. But what concerns me is that the low battery light is still flashing after a night of charging. What's up? Should I expect this kind of battery problem to continue? Seriously considering getting a Nikon Coolpix.
Posted on Sep 08, 2009
  • 244 Answers
SOURCE: fujifilm finepix v10 does not turn on. when
Fuse F351 has possibly blown on the board. It is a 2.5A 32v UL type surfacemount fuse which is soldered to the board. The fuse has a coded letter on it for identification. Recomend you find someone who knows electronics to repair
Posted on Jan 03, 2010
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Why will the battery not charge?
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 27, 2012 | HP G60-120US Laptop
I have a Dell Inspirion 1525. The Battery would not charge and the light would flash orange. I bought a new one and upgraded from a 6 cell to a 9. Now it says plugged in but not charging and the batt light...
Firstly, i suggest you try to use the charger with a similar laptop to see if it will charge it.
If it does, it means the charger is still very much good.
And as for the battery you change, it will be better for you you to check the voltage rate on your charger and the voltage rate on the battery because it is very possible, the voltage rate of your charger might not be able to power your new battery.
The voltage of the new battery might be higher than what the battery could power, so you might need to get the same voltage rating of charger for the new battery.
**** you can still test the charger with a similar laptop to be sure the charger is still good.
Take care.
Apr 19, 2010 | Dell Inspiron 1525 Laptop
Dc1804f charger
If you have tried discharging the batteries prior to charging them already with no result and from what you describe in your post, then I would have to say the charger has issues. Go to HD or Lowes (not sure if Lowes carry Makita) but another charger and test your battery again. If you get the same fault, there is an issue other than the charger, if not you need a new charger anyway. If you get the same fault with the new charger, you can always return the new one. Short of opening up the charger and using a volt meter, this is the easiest way to test to pinpoint the real problem. I hope this helps and good luck!
Nov 06, 2009 | Makita 18V LXT Lithium - Ion Cordless...
I had the same problem of the battery charger blinking...
You can fix this! If the battery is really low it won't communicate witht the charger... thus the blinking red light. Charger says - I see you are trying to use me, but I don't recognize this battery. The battery needs a little shot of charge so it can communicate with the charger. Put the battery in and take it out quickly a few times. This will give it the little boost it needs to be able to talk to the charger. Then, you will find, you can charge!
Sep 09, 2009 | Casio Exilim EX-Z57 Digital Camera
I cant charg my psp i cant find my charger
When you say you can't cahrge it, do you mean on your PC, PS3 or with the charger? I don't think the PS3 charges the PSP, I have no idea about the PC, but if the PSP doesn't charge using it's charger, it is either the battery, the charger, or the psp charger outlet. If it is the battery, buy a new one. If it is the charger outlet, it is a good idea to have 2 working batteries and to buy an external charger at game crazy, game stop, or from sony. This way, you can switch out batteries while playing, like me :). If it is the charger, buy a new one.
I would suggest first trying to buy a new battery. If it works, you are good to go and your old battery was broken, otherwise your charger/ charger outlet is broken. Buy an external charger. Then, you will be able to charge the batteries while one is in the PSP.
A new battery and an external charger cost about $70, but it is worth it. I hope i helped.
Sep 05, 2009 | Sony PlayStation Portable (PSP) Console
Fuji FinePix J10 Digital Camera Logo
175 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
