Question about Dean Guitars Dean Vendetta 1.0 Electric Guitar with Floyd , Classic
How to change strings on vendetta - Dean Guitars Dean Vendetta 1.0 Electric Guitar with Floyd , Classic
The strings on most floyd rose tremelo systems require a small allen wrench(hex head) to loosen the pressure on the bolts holding the **** end of the string in. should be easy access from the top of the guitar. hold the guitar up to your face, **** end first and look up the body towards the neck. there should be six different screw ends visible. loosen counter clockwise. you have to trim the ball end off of a new set with wire cutters in order to replace.
Posted on Feb 20, 2012
  • trace Apr 12, 2014
    i guess they censor the word "ball"?
I need a wiring diagram for a dean vendetta guitar
Go to either Fender, Gibson, or another guitar company, and look up wiring diagrams. Anything with 2 humbuckers and a switch is wired essentially the same.
Aug 28, 2011 | Dean Vendetta XM Electric Guitar
Ive got a dean vedetta guitar with floyd rose pickup... every time i tune it, it goes off in a while... also my string levels are very high which makes it difficult to play... i dont have much knowledge...
Some tuners have a weird mode that one presses the button once and the tuner will pass the audio until it times out, then tuner and audio stop. Two presses kills audio while tuner works for a time period and then goes dead. A third press enables audio to pass for normal playing. These are confusing compared to other type built in tuners. If you have one of these read the CONFUSING instructions carefully...
May 07, 2011 | Dean Vendetta XM Electric Guitar
I have a dean vendetta xm and it wont make sound through an amp they wiring is correct (checked through diagram provided by dean)
can be a number of things . i'll do my best with a check list. 1. Are they active pick ups.? (they need power source , usually 9 volt battery). 2. Check your cords. 3. check your amp. ( what i do, if you can, use a guitar that you know works. and check cords and amp with that. or try your guitar thru a different amp).AND THAT'S IF,. as you say your wiring is correct , and you've eliminated that part of it .I'd start with that
Jan 20, 2011 | Dean Vendetta XM Electric Guitar
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
The wiring is messed up the volume knob does not work right
If nobody has changed the wiring in this guitar, suspect either a broken wire or possibly a cracked resistance element in the volume pot. This can happen if the knob on it takes a blow.
Aug 28, 2010 | Dean Vendetta XM Electric Guitar
How to higher the bridge in my dean vendetta
Here is a link with all the info:http://www.fretnotguitarrepair.com/Electric_Guitar_Intonation.htm
Apr 01, 2010 | Dean Vendetta XM Electric Guitar
I need to wire the input on my vendetta
The positive wire is usually white and the ground is black. The ground goes on the tab that connects to the barrel that the guitar plug fits into and the positive is the tab that connects with the tip of the plug.
Jul 30, 2009 | Dean Vendetta XM Electric Guitar
Dean Guitars Dean Vendetta 1.0 Electric Guitar with Floyd , Classic Logo
213 people viewed this question
Top Dean Guitars Music Experts
Ted Maxwell
adam adms
adam adms
Geoff White
Geoff White
Are you a Dean Guitars Music Expert? Answer questions, earn points and help others
