Question about Microwave Ovens
Door handle ge advantium microwave sca1001fss01
SOURCE: Broken handle
1) Have to remove the door first; top of the oven there are two screws closest to the door, take those out. and the door should lift out
2) flip the door on the table with the handle side down. starting on the handle side there are three clips (top, middle, and bottom) between the outside casing and inside trim. Using a thin screwdriver gently twist starting at either the top or bottom to pod the two casings apart. work your way around the door.
3) You should see one of the screws that hold the handle on (top) but the bottom screw is under the metal casing so you need to remove the screws around this casing as well to get the other handle screw off.
Once you start you will see it isn't as bad as this sounds. I bought the handle for $40.
It is a shame that this is so cheap and breaks off this easily. Surprisingly we have had ours for at least 6 years before the handle broke and we have 3 girls opening and closing this all the time so I guess I was one of the lucky ones.
Hope this helps and good luck
Posted on Jan 19, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Advantium 120 door handle breakage
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Aug 03, 2008
highspeedsan
  • 61 Answers
SOURCE: The door handle on my GE Profile ADvantium 120 Microwave is broke
appliancepartspros.com. part number AP3187809 $56.40 plus shipping
Posted on Apr 27, 2009
jsrock516
  • 5911 Answers
SOURCE: how to remove door from ge advantium 120 microwave
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements (if required) may be purchased at the websites listed in the link I provided.
The door handle is a simple repair that can be done with the door in place, or removed. And, you do not have to uninstall the oven if this is an over the range model.
It would help, however, to know the number of the microwave oven you are referring to. All ovens are not designed the same and are assembled in different ways. What I have provided you with is the basic information that applies to most ovens. If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Posted on Apr 28, 2010
  • 186 Answers
SOURCE: Problem with the GE Advantium
sounds like the magnetron. Youll have to have a technician replace it. if you have a warranty just call the company and they should take care of you.
Posted on Jan 29, 2011
Where can I download a manual for sca1001fss01
Try manuals on line .com or manufacturers website.
Feb 15, 2015 | GE Advantium SCA1001SS Convection /...
How to remove the outter door frame on the GE Microwave
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
I need a new door for a GE Advantium SCA1001FSS01 - GE no longer makes, any chance another model door will fit?
This one from a Kenmore model made by GE might work: WB56X10400. Cosmetically different but looks similar otherwise. Browse pictures of microwave doors on Repairclinic website. You might find another one that is a closer match. Beware though, if door doesn't fit and close properly you run the risk of dangerous radiation leakage.
Sep 02, 2014 | Microwave Ovens
Problem with the GE Advantium (model sca1001fss01) Convection / Microwave Oven Everything works except the microwave. It makes a sound like its working, table turns, but does not heat or cook.
Jan 29, 2011 | GE Advantium 120 Convection/Microwave Oven
Handle broken off the door of a black advantium 120
The handles are usually held on by two screws which are usually visible on the back of the door. The handle itself should be available at some of the parts suppliers who sell on the internet.
Oct 09, 2009 | GE Advantium 120 Convection/Microwave Oven
Replace handle on adeantium sca1001fss01
you have to take the door off and pop out the plastic molding around interior of door. You can do this by sliding a screwdriver around the edge until you can get your fingers in. Be careful because there are some small plastic tabs that will break very easily. Next, remove screws on the backing of the door. There are similar tabs holding the backing on even after the screws are removed. I used a pair of insulated pliers and used the handle to pry the tabs back. Be careful because the tabs will break easily. Then the screw handle is exposed. Pretty easy huh?!!!! I just comleted this process and am looking for a handle. I am sure I will have to super glue some areas since I broke the tabs off.
Good luck
Jun 01, 2009 | GE Advantium 120 Convection/Microwave Oven
Apr 27, 2009 | GE Advantium SCA1001SS Convection /...
Oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Apr 15, 2009 | GE Advantium SCA2000B Microwave Oven
How do you replace the handle on my advantium 120 oven
If it's just the bottom one and you don't want to disassemble things to reconnect things right, drill a pilot hole in at an angle through handle and door to permit screwing in a wood screw to fix it up.  Brutish, yet sexy.
Dec 13, 2008 | GE Advantium 120 Convection/Microwave Oven
Aug 01, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
