Question about Canon BJC S500 InkJet Printer
Black not printing after new cartridge - Canon BJC S500 InkJet Printer
    Top Expert:
  • 1,575 Answers
Hi
Try re-installing the cartridge again.Make sure no wrapping material is left on cartridge before installation.Make sure the cartridge fits in place correctly.
Posted on Feb 21, 2012
How to change the ink cartridge
Follow these instructions when you need to replace print cartridges.
• Everyday printing: Use a black cartridge along with a tri-color cartridge.
• Color photos: Use a photo cartridge along with a tri-color cartridge.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge towards you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,
store the black print cartridge in the print cartridge protector or an airtight plastic
container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do
not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad
electrical connections.
8. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into
the empty cartridge slot. Make sure you push the print cartridge in firmly until it snaps
into place.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Jun 30, 2011 | HP PhotoSmart C4385 All-in-One Printer
I bought a new ink cartridge, but cannot find my manual. How do you change the cartridge???
Changing an HP Ink Cartridge
  • 1
    Open the lid of the printer. Depending on the model, there will be two cartridges on the right, one for black and one for color.
  • 2
    Find the cartridge that is running low on ink. The black cartridge will be in black, the color cartridge will have a patch of color (usually green) on it.
  • 3
    Pull down on the black clamp that is holding the cartridge in place and slide out the used cartridge.
  • 4
    Open the package of the new ink cartridge. Remove the protective tape and slide the new cartridge into the printer.
  • 5
    Snap the black protective case back into place and close the lid.
  • techbelkin
    Nov 11, 2010 | HP Officejet 5610 All-In-One InkJet...
    1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
    Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
    http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
    Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
    Printer wont print black.already replaced with new ink but still wont print black
    did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
    May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
    Black cartridge prints light gray
    Sounds like the print head is failing.
    May 19, 2017 | Kodak Office Equipment & Supplies
    IP90 stopped printing black
    if ink is ok than have to change print head for black cartridge
    Dec 16, 2008 | Canon PIXMA iP90 InkJet Printer
    Hp officejet 6110 not printing with black ink
    Hi lilacky-
    Here are some HP support links that might be helpful... and a couple questions to consider.
    Q: Is your new cartridge one of these listed below?
    "The HP Officejet 6100 series and HP Digital Copier Printer 410 products use the print cartridges listed below:
    * HP 56 black print cartridge
    * HP 57 tri-color print cartridge
    * HP 58 photo cartridge (replaces the HP 56 black print cartridge for six-ink photo printing)" info from: Installing a Print Cartridge
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&lang=en&rule=12548&product=79477 Is your new cartridge a refilled cartridge? Some times those have special challenges. Has your cartridge been sitting a while in the box, maybe in a warm spot? Some times even new cartridges dry out a little. Was your old cartridge low or completely gone? Just as a test, if you put it back in your printer does the old cartridge work? Any printer error messages? Can you print a test page or an alignment page for your black cartridge? These might be too many questions but here are some HP support links with some How To information for getting more answers. Please let me know if any of these are helpful. see also: Slow or No Response from Printer
    http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=11882&lc=en&dlc=en&cc=us&lang=en&product=79477 -JW
    Oct 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
    Ink cartridge light keeps blinking
    you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
    Jul 07, 2008 | HP DeskJet 940c InkJet Printer
    New cartridge problem
    Machine needs both cartridges working to work
    Nov 26, 2007 | HP PSC 1315 All-In-One InkJet Printer
    Canon BJC S500 InkJet Printer Logo
    37 people viewed this question
    old marine
    old marine
