Question about HP Vs17 17" LCD Flat Panel Monitor
All of a sudden by screen background is pink/purple - everythin has a rosy glow - is my monitor kaputt?
I think there was an instantaenous power outage - lights flickered, all computer LED's went out for a second but came back on by themselves. Everthing seemed to be normal (the computer did not shut down duing the flicker, but now my monitor has a pink overtone on evert¡ythink. I've tried resetting to factory settings but the problem presists. Any Ideas?
thinstatic
  • 50 Answers
SOURCE: Flickering Monitor
Dear Thunderforce -
I've run across this issue quite a few times with LCDs, and generally there are two possible causes: Either the Power Supply is bad(best case), or the LCD's Inverter is bad(worst case). Most LCDs now use a standard computer/monitor power supply - usually a thick cable, with three prongs on the male end and three slots or holes on the female end, same as would be used to give power to the computer. If you have an extra cable, you should try testing it with the LCD. If the screen works, fantastic, chalk it up to a broken power supply.
Otherwise, you'ld have to open up the display to replace the Inverter board. The LCD will have three or more circuit boards in its casing; One that handles input, one that handles power, ocasionally a separate board for video logic, and a slim board that connects the other PCBs to the screen itself. This slim board is the Inverter, and will have to be replaced.
The issue at this point is cost of repair vs. cost of replacement. An LCD inverter can cost anywhere from 40-140 bucks(on average) even on Ebay. Most big-name computer stores offer a comparable LCD for around the same price after rebates, or on sale. Second hand, I've even seen a few 17" LCDs for as low as fifty bucks.
Hope this helps!
-thinstatic
Posted on Jun 11, 2008
myjosh007
  • 530 Answers
SOURCE: HP Pavilion F1703 Monitor Screen Flickers
hi im josh in cebu phils. may i help you friend? just try this solutions i arranged for the people who needs help.just try friend.
Monitor Problems:
THE COMPUTERS SEEMS TO BE WORKING, BUT THE SCREEN IS BLANK.
- Check the monitor if turned on.
- Check all the LED power on the monitor, if it has one.
- Adjust brightness and contrast controls all the way to the maximum.
- Check the video cable from the monitor to the computer to be sure if it is properly connected.
- Check the power cable. If it is connected properly at both ends.
- Try different monitor on your computer. If it does not work, the display card is likely at fault. Replace the display card.
- Try your monitor on a different computer. If it does not work, replace the monitor or have it repaired by a trained technician.
COMPUTER BOOTS, BUT DISPLAYS “JUNK” ON THE SCREEN
- It may be that the display card is defective. Try a different card. If it works the first card may be bad.
- Try the suspected bad card on another computer. If it displays the same thing it is conclusive that the card is bad.
DISPLAY IS DIM, OVERLY BRIGHT, OR BLURRY, OR UNPLEASANT.DISPLAY IS OFF CENTER. LEFT OR RIGHT SIDE OF MONITOR IS OBSCURED.
- Try adjusting the control knobs located on either the front or back of the monitor. It maybe necessary o open the monitors casing to get the proper adjustment controls. In this case be very careful because there are high voltages in the monitor.
THE VIDEO DISPLAY FADES AND BRIGHTENS, OR IS WARY.
- The voltage may be fluctuating due to so many appliances or electric devices on he same branch circuit.
- Turn off other appliances and peripherals, such as printers, external modem, refrigerator, microwave oven, transformer, etc. and see if that solves the problem. If the problem persists, try swapping out the display cards. If changing the monitor solved the problem, repair or replace the monitor.
IMAGE IS NOT STRAIGHT ACROSS THE SCREEN
- If the monitor is still under warranty, bring it back to the dealer for adjustment. If the you want to do it your self, bare in mind that this is potentially dangerous procedure because it must be done while he monitor is on and there is very high voltages around the picture tube.
WARNING: THIS IS A DANGEROUS PROCEDURE!!!
- Open the monitor casing and loosen the clamp holding he coils around he picture tube. You can loosen them (usually there’s a wing nut) and a rotate the coil assembly until the picture strengthens.
good luck hope i helped you.
Posted on Mar 06, 2009
micromend
  • 748 Answers
SOURCE: HP vs15 monitor Flickers then blacks out.
Hello
This monitor has 5 capacitors in the power supply that age prematurely. I can repair this for $50.00 +parts + shipping. Or you can take it to a local repairperson.
Posted on Jul 28, 2009
budmrtn
  • 11361 Answers
SOURCE: HP f2105 monitor going into sleep mode on it's own
Does it do the same when you use this monitor with other PC, new VGA cable, just need to narrow down the problem first before start taking the monitor apart.
See pictures of what usually goes bad (mostly failed capacitors) with monitors:
http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further
Posted on Apr 04, 2010
budmrtn
  • 11361 Answers
SOURCE: HP Pavilion f1703 Monitor flickers on & off
Clean and resolder all four round inductors, check the caps, replace them if they have bulging tops (even slightly bulg). Check the transistors (c5707) for shorts. See pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 25, 2010
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
Was cleaning my mouse and the screen is now having a pink/purple background. How do I fix to go back to the great colors showing as before
This is probably to do with the cables coming loss, push thecables at the back of the monitor into their housing, see if than changes the coulors.
The cables may also be loss at the back of the machine,check this by pushing the cable that runs from your monitor into your PC backinto its housing.
Mar 02, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
Plugged in a new cpu and the background is pink. I have tried to solve with appearances and no luck. I have another flat panel and plugged it in and get the same pink background. I think I am in a *****...
I think youa are using a VGA Connector, check if there is any bent pins. Reseat the VGA Cable once or try out with a diffrent cable. If that also does not work, then its a issue with the monitor.
Thanks and Regards
Mar 26, 2010 | Envision EN-7100e 17" Flat Panel LCD...
Screen returned from supplier background bright pink, how do I change to white background.
To check if the video card or the Sharp LCD monitor is faulty, connect a different monitor to the computer. If this monitor displays a normal image then the video card is OK and the Sharp LCD monitor's back-light is faulty. Send it back to the supplier to have it fixed (they should not have reurned it to you in this condition).
If the other monitor also displays a bright pink background then the video card is faulty and needs to be replaced.
Nov 19, 2009 | Sharp Computers & Internet
My monitor suddenly altered the colors on the screen; white background now appears slightly pink, green appears black. How can I make adjustment to correct the color?
your monitor is either going bad or your display setting are messed up.use the buttons on the front and mess with color option if that don't work then you need a new monitor
Aug 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Screen is bright neon pink!
Did you also replace the power inverter when replacing the screen???
Feb 13, 2009 | Acer Aspire 5610-4648 Notebook
Monitor shuts down and glows pink
You could try updating the drivers for your monitor and for you video card. It sounds like their could be a hardware problem. When something warms/heats up the connection is made. A pink glow isn't a good thing. Make sure you check all cables and even try to adjust the actual monitor settings Your heat settings for the colors may be out of whack. Last question? Does slapping it a little help? Good Luck. Let me know what happens. Tim
Feb 19, 2007 | Samsung SyncMaster 750S 17" CRT Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
112 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
