Need wiring schematic for sany 1350w/120v heater blower motor
the dr
  • 447 Answers
SOURCE: Furnace Blower Motor Specs
That information is usually on the data plate on the furnace and on the motor itself. All you need to know now is the HP. Other than that a universal consolidator motor is an easy fix too. It can handle 1/6-1/3HP.
Posted on Dec 18, 2007
mick-40
  • 94 Answers
SOURCE: need diagram
Hi pgarrity,hope this helps my friend good luck,this is simplified :)38282e1.jpg
Posted on Nov 11, 2008
  • 261 Answers
SOURCE: heater blower motor wiring diagram
replace the bolwer motor relay mounted on the fire wall the relay is stuck in the on poition.
Posted on Dec 07, 2008
SOURCE: locating heater blower motor resistor
the resistor is behind your glove box. open the box and push in the sides to release it and let it hang down...the resistor is right there. I didn't try to replace it, a friend did it, but the part was under $20.
Posted on Feb 01, 2009
  • 18 Answers
SOURCE: Heater Blower won't work
There was a bulletin reguarding water contaminating the blower motor, which overheats the blower resistor and renders it inoperative. The fix was to replace the blower and the resistor and seal the culprit hood cowl screw at the base of the windshield, which is the second screw from the passenger side. They say water drips off of it down into the fresh air opening.
Here's what I'd do: Assuming your switch and blower motor is good, replace the blower resistor. Remove the blower motor and see if it spins without any excessive drag. If it's okay, reuse it. If it's dragging, it will overheat your new resistor in a short period of time and you'll be back at square one. The blower resistor is mounted to the front of the case with 2 screws to the left of the blower motor. Remove the glove box and you'll see it.
The Hood cowl screw is straight down into the cowl, the second one from the right side, about 10-12 inches from the right fender. Pull it out, put some sealer on it, and reinstall it.
Posted on Oct 02, 2009
Where is the Heater Blower Motor Relay on a 1997 Camry ?
why not post symtoms? is cab heater blower dead on HIGH??????
there are 5 fuses, just related to heat.
the blower relay is in the engine bay box 1 , far end marked HTR.
on high the relay coil 1 and blower pin 1 are grounded
the relay closes, if and only if the 10 amp heater fuse is good.
the relay then outputs 12v to blower in 2 and the motor RUNS.
that is it.
alldata.com read there.
or buy FSM for full facts. and schematics.
Jul 14, 2014 | 1997 Toyota Camry
Fuse blows on heater. i replaced resistor, relay, and rotory dial switch on control panel. also unplugged blower motor but fuse still blowed
You very likely have a short in the wire between the fuse and the blower motor. You will also need to determine whether the fuse for the blower motor also powers another item in the truck. A wiring schematic should tell you. (For example: Know that sometimes, if the radio has been changed from the factory model, the newer model/style radio has been known to be added in to another location, such as the heater blower fuse.)
An auto accident can sometimes cause the short, if a wire gets pinched somewhere.
Is it possible, but very difficult, to replace the wire from the fuse to the blower motor, or to run a substitute wire.
Be blessed.
Dec 21, 2013 | Chevrolet Silverado 1500 38945-87 Tonneau...
WH40 water heater timer: Does black wire from service box go to terminal #1 and black wire to water heater to terminal #2? Does neutral (white) from service box go to terminal #3 and neutral (white) to...
WH40 is 240Volt timer.
WH40 will not work with 120V circuit.
See WH40 wiring illustration at following link:
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
There are two hot wires in 240V circuit because every circuit requires two wires to complete the circuit.
Hot wires from breaker connect to terminal 1 and 3.
Notice that small white wires are also connected to terminals 1 and 3.
Small white wires power clock motor located on back of mechanism, so this says power from breaker box must arrive on terminals 1 and 3. This insures that clock motor runs continuously.
If clock motor only runs when manual override switch is clicked ON, then your Hot and Load wires are reversed.
Bare ground wire connects to green ground screw.
Wires going to Load (water heater) connect to terminals 2 and 4.
FYI: Terminal A is not used unless circuit also has a Neutral wire,
See basic water heater circuit Diagram #2:
http://waterheatertimer.org/240-v-water-heater-circuit.html
Terminal A is also used if you want to convert WH40 to 120V timer by replacing 240V clock with 120V clock.
How to convert Intermatic 240V timer to 120V timer
http://www.fixya.com/support/t7353947-intermatic_timer_wg
Dec 24, 2010 | Electric Intermatic Inc Wh40 Water Heater...
Need a fuse box diagram for 95 honda civic heater/AC blower not working
1f56e01.jpg this is the blower motor wire schematic. if the blower motor is getting power. your problem is most likley the power resistor.
Mar 01, 2010 | 1995 Honda Civic
What wires on the blower are power need to know what colors to hook up to run 120w
The wires to your blower are connected at the control board. To hook up a 120V to the furnace, on this model, is located on the left hand side of the burner section. There is a black and white wire in a small 2"x 3" box. The control board selects which wire to power the motor depending on what mode you are in.
Oct 03, 2009 | Goodman GMS90703BXA Heater
Elec dryer, no heat case
check your center NEUTRAL connection to the element,sounds like your losing it somewhere,certain units rely on the neutral to operate the element on certain cycles to dry, the neutral carries the imbalance current load and the wire gets hot and will get brittle and break
Sep 24, 2009 | Dryers
Whirlpool LER8648PW1 turns but no heat
the wiring schenmatic is located inside the console area. but real simple, youll need to check(with wires off) continuity throiugh all of you thermostats, in particular, the one at eh botom and top of the heater pan, as well as continuity throughthe heater itself
Jan 23, 2009 | Whirlpool LER8648P Electric Dryer
How do you wire a transfomer and relay together on a central air.(bryant)I took the wires of and now witch wire goes were.I going to change the two.HELP ME
This may be somewhat difficult depending on the year make and model. I will try to help without this knowledge.
There are 2 sides to the transformer. Read the label to see which is which. One side is labeled 24 volt and the other side is labeled 115 volt.
The 115v side will probably only have 2 wires. A white wire and a black wire. The white one will connect to the common or neutral system. If there is a circuit board it will plug on to the 120v Common terminal (probably marked L2). If the air handler does not have a circuit board, the white wire will connect to the other white common wires by a wire nut.
The Black (hot) 120v wire will connect to the 120v L1 terminal on the circuit board. If there is not a circuit board, read the schematics to find out where to wire nut the black 120v wire to. It will obviously be connected to a 120v incoming hot center after the blower door switch.
The 24volt wires will connect in a similar fashion to the circuit board. T1 will connect to the 24v hot terminal on the board. The T2 will connect to the 24v common terminal. If there is not a circuit board you will need to read the schematics very carefully before proceeding. It may be a good idea to add a 2amp fuseable link on the 24v T1 wire just in the case we are wrong.
The 24v hot wire may be wired in multiple ways without a circuit board. One way is to be wired to the Limit side of the Fan/Limit switch (located on back wall of the burner compartment just above the gas valve. Another way is wired to the gas valve. Please read the schematics located on the blower door. I hope this helps at least a little. Let me know please. Thanks.
Aug 14, 2008 | Heating & Cooling
Furnace blower motor
I would check the "G" wire at the Thermostat and make sure that it has a solid connection. The other end screws on to a terminal in the furnace. Check this connection as well. This green(G) wire is what activates the 120v relay on the circuit board. You can test this by turning the thermostat to the off position and then jumping the 24v R terminal with the 24v G terminal at the furnace. if the fan comes on then the problem is in the thermostat wire or the thermostat itself.
Jul 08, 2008 | Goodman GMS90703BXA Heater
Ice Dispenser motor/Dispenser light
I assume that the problem is that the ice dispenser is not working. If you have put 120v onto the auger motor and it won't go, then obviously the motor is faulty. Reconnect the motor to the wiring harness and put your tester on the white & blue wires. Push the door switch so the fridge thinks that the door is closed and push the ice dispensing lever. If you get 120V to the motor and it won't go, replace the auger motor.
Nov 01, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Heating & Cooling Logo
253 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
