Question about Bosch Axxis WTL 5410 Electric Dryer
Where is air inlet on bosch dryer
Where is the air inlet on my bosch dryer? I see an opening on one side, but when the dryer is running, air is blowing out from this opening. There is a duct connected to the back of the dryer that goes outside the house.
SOURCE: bosch exxcel tumble dryer blowing
Remove smallish cover in center of back, 2 self tappers. Press RED reset button till it clicks, located just left of center at the back.
Posted on Oct 16, 2008
SOURCE: Bosch Dryer doesn't dry clothes
With the dryer not connect to the external venting turn the dryer on and see if there is air coming out ot the vent from the dryer. Is this flow of air strong or weak?
If weak then there could be a problem inside the dryer some where. Perhaps the fan is not operating properly. Just my thoughts.
You say you have check the beginning and end of the duck vent pipe. How about seeing if it venting duct is clear from one end to the other.
Good luck
Posted on Jun 11, 2009
tony2155
  • 64 Answers
SOURCE: Bosch condensation dryer model WTL5400vc. lint filter alarm
bad sensor or dirty
Posted on Jun 23, 2009
ftw1952
  • 10319 Answers
SOURCE: why does my bosch dryer wta 2910 only blow cold
If the exhaust vent tubes have never been removed and thoroughly cleaned in years this will cause the sensor to keep the heat off in your dryer. If clean the moister sensor is at fault
Posted on May 02, 2010
sonicboomele
  • 1557 Answers
SOURCE: my mom's bosch nexxt dryer
in 99% of the case if the unit is running correctly but not heating the heat element is blown and will require replacement.
have a great day
sonic boom electronics australia
Posted on Jan 04, 2011
When The door is open continues to run on my Bosch Axxis Clithes Dryer WTA3510US
the door switch contacts are welded together,normally it switches when the door is opened to light the interior drumm light and to the dryer circuit when the door is closed,but these contacts cant due to being stuck
Nov 15, 2012 | Bosch Axxis WTA 3510 Electric Dryer
Ir 185 starts but runs at full rpm and doesnt produce any air
Read before doing any Work!! I worked on more electrical than engine powered units. However it sounds like the load valve is not supplying the correct amount of air to the inlet valve.I would remove the air filter at the inlet valve. depending on the type of inlet on the unit it may be air to open or air to close. there should be a line (probably 1/4 plastic) running to the inlet valve. With the unit running if it's air to close and you have the line off the valve will probably open. If the inlet opens be prepared to shut the unit down ASAP before you lift a safety. It May not fully open but enough to make some air.if this happens fell the end of the line removed. you should fell some air coming out of it. If so replace the load valve. It will be the valve the line runs back to. I should have gotten you to check the inlet valve to make sure it moves freely by hand before starting the unit.then do the above. If it's air the open you can test by using an air tank and observing the inlet valve. if it's air to open start tracing back to the point you find air . you will probably find the load valve controlling the air going to the inlet which is again probably bad. Again my expertise is in the electrical side but the above will get you started in the right direction. even though it engine driven the airend is the same as electrical. they just go about the controls differently. please be extra careful while trouble shooting this.
Nov 14, 2011 | Ingersoll Air Tools & Compressors
Bosch wta3510us vented stackable dryer. I have reset the High Limit Thermostat and the unit is producing heat and air, although I'm not sure of the temperature of air flow. The unit came with the...
Go to www.repairclinic.com and enter wta3510us. You will be presented with a list of common replacement parts and may be able to view a generic Bosch video showing disassembly. This may help you figure out what's wrong and what has to be fixed.
Feb 28, 2017 | Bosch Axxis WTA 3510 Electric Dryer
I HAVE A LEAK AT THE WATER-INLET SYSTEM, THE LEAKING OCCURS WHEN THE THE DISHWASHER STARTS. THE VENT HOLES ON THE TOP OF THE INLET SYSTEM WATER SQUIRTS OUT DURNING THE FILING PROCESS.
its just the air-gap on the inlet system,sometimes a slug of debris gets near the air-hole in the side of this gap and redirects the water flow,just easily run a screw driver of the right size down the water tube and then try filling it again and see if this helped
Mar 07, 2011 | Bosch 24 in. SHU5305UC Built-in Dishwasher
The lint filter light continues to come on and shut off the dryer even the the filter is clean
check the inlet filters first and then the out let hose the dryer needs to breath in a lot of air so if any of the inlets or out let pipes are blocked that could put this light on
Aug 27, 2010 | Bosch Axxis WTA4400 Dryers
Is it possible to re-configure the rear vent on a Bosch dryer
Most dryers have that option but not on the left side. You will need to cut a hole in the left side dryer housing. Then you will need to dis-assemble the back panel of the dryer and disconnect the vent pipe connection inside the dryer. Then run the moisture vent into the dryer housing from the left side opening and connect it to the venting system inside the dryer. You might not be able to put the opening in the same spot as the right side so you should do a visual inspection inside the dryer before making the opening to verify nothing is in the way.
Jan 22, 2010 | Bosch Dryers
After sitting idle for several days, dryer makes a noise at beginning of the cycle when drum stops and starts. Noise no longer occurs after second load dries.
Not sure if your problem has been corrected yet, but the biggest most important task that must be addressed constantly with these machines is lint build up. So I would check your lint trap (change it before or after each load), check your heat exchanger/air inlet on the lower right hand corner of your machine, and then your condensation hose - to make sure that this is clear of blockage. Also, your machine should be in a vented, open area where it gets lots of air. Adequate ventilation is another important feature that affects these machines. So basically, I'd give it a little tune-up/clean-up and see how it runs. Hopefully, this has already worked for you. Good Luck!
Jan 16, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Water builds up behind heat exchanger
I don't know if there is a cure for this. Bosch never answers my calls or my e-mails, but I have found that by blowing in the hose to disengage the lint collecting there and then sucking out the line will remove nearly all of the build up amd drying will resume.
Jul 08, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Bosch axxis WTL lint indicator problem.
I have been struggling with this lint filter problem big-time. After reading the previous user's comment that his mesh holes had become clogged, I took a closer look at my filter and noticed that the tiny holes in the mesh were, indeed, clogged up. In fact, when I initially ran water on the filter it pooled up on the mesh like a solid plate...pretty good sign that air wasn't able to pass through the filter properly.
I used a soft toothbrush and soap to clean the filter, and when I ran water to rinse it off it the water passed right through the mesh. I popped it back in and, voila...That fixed it!!
Mar 08, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
166 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
