Question about Keurig B60 Coffee Maker
Keurig keeps flashing "not ready"
My keurig b60 keeps flashing not ready but the water resevoir is full and I have a k-cup in it, what is it waiting for? I have unplugged and refilled the water and re-entered a new k-cup. Nothing has helped.
SOURCE: My Keurig B60 is suddenly
I solved it by running the machine a couple of times without a K cup in it. The second time through, a few grinds ended up in the cup. After that, the machine works fine.
Posted on Jan 19, 2010
SOURCE: New Keurig B60 stopped working!
I had the same issue. I now believe that there was some "vapor lock" type issue. Mine would say the same thing, and i could hear the pump running, but the water level was not changing in the reservoir. I unplugged it, removed the reservoir, let it cool, then tipped it on its back for a few minutes, then on each side. Truthfully I was trying to see if there was some kink in the tubing. Couldn't find a problem, so set it back up and it runs great again.
Posted on Jan 02, 2010
  • 28 Answers
SOURCE: My Keurig B60 just stays flashing
Try removing the water reservoir tank, the replacing it. Make sure the reservoir tank is seated properly. There seems to be a problem with this model with the water reservoirs not seating properly and causing the unit to stop working or shut off. Hope that helps! Best of luck...
Posted on Feb 07, 2010
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
Posted on Dec 03, 2010
  • 67 Answers
SOURCE: where can i get a cup holder assembly replacement
I know of this great website that sells all kinds of keurig parts the k cup holder will be there toohttp://stores.ilikenew.com
Posted on Jan 27, 2011
The resevoir is full and the unit will not pump. How do I get the water out of the holding tank to de-scale.
shut the pot off and restart . when the ready to brew light start blinking push your desired cup size button
Aug 18, 2011 | Keurig B60 Coffee Maker
Not a full cup, some water goes back into the resevoir. This is the second unit I have that does this. I use spring water, vener tap water.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
,./l
Jun 20, 2011 | Keurig B60 Coffee Maker
Only getting half a cup...water is leaking back into resevoir.
heatman101
Apr 20, 2011 | Keurig B60 Coffee Maker
When ready light is on and k-cup is inserted and handle lowered, pump starts but no water pumped
heatman101
Apr 18, 2011 | Keurig Special Edition B60 Coffee Maker
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
Keurig B60 Coffee Maker Logo
696 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
