Question about Sony KV-27V26 27" TV
TV power supply problem
Ceramic capacitor blew apart with a loud snap on the "G" power supply board of my Sony KV-27V26. Since there isn't much left of the capacitor, I'm not sure what rating of capacitor I need. It's the capacitor at position "C613" of a Sony G power supply board. Will just putting another capacitor on really help, or is it probably another problem that blew it in the first place? I've looked around and can't seem to find any sources that still stock Sony "G" power supply boards, any help telling me where I can find a new board, or which capacitor goes in the C613 location on the board is much appreciated; thanks in advance.
    President:
  • 1,348 Answers
.01 mf 2000 volt. in flyback circuit .it is a timing capacitor. the red high voltage block is bad and that took out the capacitor. also check the horizontal output transistor...it is probably shorted.
Posted on May 13, 2009
SOURCE:
While watching my LG 55LW5600 this morning, loud popping sounds came from the TV followed by heavy smoke. What happened?
The tv power supply board,have blown capacitors components parts most likely.Don't tries to repair this power supply board though,because a loud poping sounds and heavy smoking have many more other components dies also just not easy to be seen as capacitors parts.The tv power supply board that the board,where the tv power a/c cord plug into it.Take the tv aparts.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 13, 2011 | LG 55 55LW5600 3D LCD TV
Set is about 2 years old. Powered up and heard a loud snap/pop noise and unit went out. Will not come on Can you help?
U have a soldering iron,desoldering pump or desoldering braids,solders.U understand basic electronic and can u do basic soldering?Yes,take the tv aparts,take out the power supply board,that the board,where the power a/c cord plug into it.That the power supply board,most of the times those parts call capacitors are dead,these capacitors are alway bulges up on it tops or puffing up on it tops.These capacitors are dead,must be replaced.These capacitors are dying or already dead capacitors,that why they are bulging up on it tops or puffing up on it tops,after u replaced these capacitors ur tv will power up again and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 28, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My Sony Trinitron does not turn on. Stand by red light blinks 7 times. How do we fix this problem??
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helpout in solving the problem
Oct 02, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Tv blew up
Power board probally have burn capacitors.Take the tv aparts,check for puff up or burst open capacitors.Know how to solders? Replaced these capacitors well get ur power back.Or replaced the whole power board buy it at Shopjimmy.com,Ebay.com.
Jan 24, 2010 | Hitachi 60SBX78B 60" Rear Projection...
My TV had a problem which is shown as TV timer LED indicated 5 time blinking-COLOUR GOES WRONG.TV model SONY TRITRON KV AR292M61.
Know how to solders?Take the tv aparts.Check the power supply board,for bad capacitors like puff up or burst open.Replaced these capacitors.Well get ur power back.Or buy a refurbish power board at Shopjimmy.com,Ebay.com for the replacement.
Jan 22, 2010 | Televison & Video
Trying to identify a capacitor on the power supply board
IF you have the G BOARD part #A-1316-367-A it's:
1-162-133-00 CERAMIC 390PF 10% 2KV
IF you have the G BOARD part #A-1316-422-A it's:
1-161-754-00 CERAMIC 0.001MF 10% 2KV
Jan 04, 2009 | Sony KP-53S65 53" Rear Projection...
Sony kv 29x5d
Please mention correct model number to check C633 value.
My system recognise this model as incorrect.
Jun 01, 2008 | Televison & Video
Sony kv xj29m50 no picture.
If I understand you correctly:
The horizontal output transistor in your TV blew.
You replaced it with a BU2520DF.
I'm not sure what you mean by "change to dynamic mode".
Dynamic what?
Usually, horizontal problems in TVs are caused by bad capacitors in either the sync circuit, the driver circuit, the geometry circuit or the output circuit.
When I repsir problems like this I use an oscilliscope to find which stage is not working properly, then start substituting the capacitors in that stage until the problem is solved.
Look for large orange or blue ceramic or polyprop capacitors with bulges or cracks in them.
Look for electrolytic capacitors with bulging tops or shrunk cases.
Check and make sure no resistors are brown, they may be blown.
Use an ohm meter to test low value resistors in circuit.
If you don't have an oscilliscopw, that's about all you can do.
Jan 31, 2008 | Sony KV-XJ29M50 29" TV
Tv repairing
You still have something open in power supply. Look for a fuse resistor or bad relay.
Sep 23, 2007 | Sony KV-27S22 27" TV
Resistor on power supply board
Dear Biigjohn, First, first C613 means that it is a capacitor, not a resistor.And It seems to be a electrolytic Capacitor.If it has burst, then it's can will be inside. just search. the details of the Capacitor will be on it. most likely it will be a 10mfd 160V capacitor. Check and replace.
Aug 14, 2006 | Sony KV-27V26 27" TV
Televison & Video Logo
144 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
