Question about wimp.com
Problems opening wimp videos - wimp.com
I was so tired of my machine wimping out with tough fabrics so I bought a kenmore 117-552. The bobbin is not hooking on to the needle. Any ideas? Please help!
Try a brand new needle.
Otherwise, the machine is probably out of time and needs to be adjusted by a service technician.
Jul 09, 2017 | Kenmore Sewing Machines
I WANT TO BE A VIP
at the moment you are just wimp... google it!
Jan 01, 2015 | Computers & Internet
Leaky gas tank
find a real mech. yours is wimp
my guess. is , he is ill equipped.
and he make, big money on all high hour jobs
why would he avoid big money.????
Jan 22, 2014 | 2001 Acura 3.2CL
My handycam Sony Hi8 DCR-TRV140E shows blank black screen when I look through and when I press recording button..how to fix it and enable it ?
I know this is gonna sound funny, but your gonna have to trust that I am actually a video camera technician and know what I'm talking about. The Iris in your camera is stuck. turn your camera on and hit the bottom. dont go nuts...but don't be a wimp either. It is very common on these cameras. if it keeps doing it, that means you need to have the iris replaced. Considering the camera is quite old, there probably arent a lot of service centers that will do it for you. I can if you want me to...just message me..i work in oklahoma so you would have to ship it...
Aug 02, 2012 | Sony Video Cameras
1994 waverunner fouling plugs with oil after just a short time.Can you block the oil pump and just mix the oil and gas. They cant look at this for about four weeks.
Sure, If you want a quick fix just put a vacume cap on the pump inlet and oil tank then your gonna run about just over 3 oz of oil per gallon of gas. (comes out to be about 40:1)
Aug 28, 2010 | Yamaha 12V Air Pump
How do you get the driver1s side panel to go on straight the seal at top wont seat right
The easiest way I found is with a little elbow grease that is this work is not for little wimps . Slide the top of the panel into the grooves first then proceed around the perimeter with a large hammer banging in all the clips
Jul 02, 2010 | 1998 Acura CL
Check engine light
this happened to me. 99% of the time my check engine light, when it came on, meant my 02 sensor. the last time it came on, my car was sputtering and going bonkers! i freaked out and took it to my honda specialist, crying my eyes out. i'm a wimp. anyway, it was my idle air control valve. VERY cheap fix. you'll still have to have the codes on it but that could very well be it. I have a 1997 accord, basically the same car.
good luck!
Apr 02, 2009 | 1994 Honda Accord
Virus on mp3 player
PEOPLE - Stop using the freaking WMP any #, it's a 'wimp' alright...
Just REFORMAT YOUR SANSADISK/CLIP PLAYER THEN RELOAD IT USING SIMPLE DRAG AND DROP TECHNIQUE, IT'S INTUITIVE - DON'T MAKE IT HARDER THAN IT IS, IT'S JUST A LITTLE TINY COMPUTER; BEST OF ALL IT DOESN'T EVEN HAVE WINDOWS OS IN IT!!
Jan 05, 2009 | SanDisk Sansa Clip MP3 Player
Driver for sansa e270 for win xp os
Install Windows Media Player 11. The Sansa drivers, and MTP system, are part of WiMP10 / 11. Windows XP "out of the box" has WiMP9, which may be your problem.
The Sansa can function as a flash drive in MSC mode, but your files transferred in MTP will not be available on the PC side.
The Sansa does not require specific drivers from SanDisk, as it's integrated into WiMP.
Go under menu, setting and change the device to MTP or playforsure..
Let me know if that works
Please rate accordingly
Thanky you
Computerrep
Oct 31, 2008 | SanDisk Sansa e270 MP3 Player
wimp.com Logo
66 people viewed this question
Top wimp.com Computers & Internet Experts
David Payne
David Payne
Are you a wimp.com Computer and Internet Expert? Answer questions, earn points and help others
