Question about KitchenAid Kitchen Appliances - Others
Kitchenaid kmtt200ss0 stopped working when lever pushed down, worked fine for several years
2 Suggested Answers
mcdevito75
  • 1970 Answers
SOURCE: lever stopped working
mcdevito75 here, Sounds like the return spring on the laver is mis-aligned, see any appliance repair shop in your area.
Posted on Jun 28, 2010
Kitchenaid mixer stops working after just a few minutes of use.
Probably a model number and a better fault description would help. Does it turn off like a switch or stutter & run down. What's required to make it start up again?
Jan 06, 2017 | KitchenAid Food Mixers
Right control lever stopped working.
You need to list the model# series. and year of your unit.
May 12, 2014 | Garden
Sudden electrical failure
if you want to find the fuse justfollow the line cord it will lead to he fusesbut dontforget to power off breakers ok, o avoid shock
Feb 04, 2014 | KitchenAid Dishwashers
Kitchen aid 2-slice toaster stopped working. It is plugged in to a good outlet.
The wiring is probably the problem. Check the connections. And then the elements . It may be burned in two.
Jan 27, 2013 | KitchenAid KPTT780ER 2-Slice Toaster
Kitchenaid dryer drys fine the first load then it gets louder the next load then stops working
Sounds suspiciously like worn support roller shaft bearings. When they get bad sometimes the rollers just wobble on the shaft and eventually, if the dryer isn't shut down and repair quickly, the shafts will become severely worn and will need to be replaced as well as the rollers. It will most likely have to be disassembled before a good estimate can be made.
Dec 24, 2011 | KitchenAid KEYS750LQ Electric Dryer
I have a Craftsman 19.2 charger that stopped working...
OK, I had trouble with craftsman 19.2 charger stopped working. I took them a part and found there is a lever looking plastic piece that turns the switch inside the charger. The lever gets pushed by a battery and it pushes the switch. Well, over the years of use, the tip of the lever got rounded on mine and not be able to push the inside switch in all the way. So I just super glued a little plastic on the lever piece and put the battery together. It's been working fine ever since.
Sep 17, 2009 | Craftsman Drills
Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
Aug 16, 2009 | Kohler Toilet - One Piece with Ingenium...
The lock don't work properly
That lock mechanism has one additional adjustment hole. You have to disassemble the mixer. I recommend returning it if you can. If not, see my posts on "removing the motor cover" and that adjustment must be made on the inside. You will also be able to inspect the lock itself to see if the tooth is busted off. Good luck.
Jan 14, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Dec 31, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen Appliances - Others Logo
65 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
