Question about Canon PIXMA MP610 InkJet Printer
Won't turn on.
I scanned and copied a document. Went to do it again and the printer turned off and won't turn back on. Have tried unplugging it for a minute, then plugged in and tried to turn on. The power light lights for less then a second, then nothing.
  • Vicki Ferrari Apr 23, 2012
    How did your printer problem end up Jason? I left a comment in the wrong box, under solutions, well, it was a solution of sorts. I am interested to hear your outcome. Cheers, Vicki 23/4/12
Did you get it working Jason? My MP610 did the same thing to me this morning... I went through all the rigmarole of moving it, testing it with different power cords and etc... with no success. I left it unplugged completely, tried it again this afternoon and it works. Well, it turned on, copied a piece of paper, I was able to access the ink cartridges and switched it on and off again twice and it worked. Hoping it will stay that way.
I don't know if it happened because I put a CF card in to slot - will try card in another reader first and see what happens...
I would be interested to hear what happened with yours, Jason.Cheers, Vicki 23rd April 2012
Posted on Apr 23, 2012
3 Suggested Answers
SOURCE: 4400F scanner suddenly won't scan
1.From the CanoScan Toolbox, click the Settings button.
2.At the bottom you will see a section that states, "Select Folder Where Temporary Files are Saved:".
Click the Browse button.
3.Browse to a folder, such as C:\Temp, and then click OK.
4.Click OK again to exit the Settings window.
5.Try scanning again
-Or-
From the CanoScan toolbox ,click the settings button ,and press the "Defaults" button in that panel - and then "OK" button
Posted on May 16, 2011
pheireith244
  • 310 Answers
SOURCE: canon mx310 won't scan message reads "the
Please go to Control panel and choose add or remove programme.. kindly uninstall the program i.e. Your printer driver after all re-install the driver... thanks
Posted on Aug 22, 2011
The top left "hinge" won't seat, therefore the top feed can't be used to fax, scan or copy.
It's possible that the hinge of the scanner cover broke. If that's the case, you won't be able to scan from the ADF (Auto Document Feeder). If the printer is still under warranty, please call our technical support team to have the printer replaced.
Aug 10, 2012 | Lexmark Pinnacle Pro901 Inkjet Wireless...
I have a document stuck in the print queue, which won't cancel or restart, help!
Turn off printer for 2 minutes @ least, turn back on, or delete printer and re-install printer. Go to HPsupport website enter your printer model info update drivers.
Jan 28, 2012 | HP PSC 1510 All-In-One InkJet Printer
The light does not turn on when making a copy.
it's clear. that is expose lamp the end.
you have to replace a new
good luck
Dec 11, 2011 | Canon PC-921 Black and White Copier
Why won't my printer scan a document to my laptop?
Make sure the Lexmark OCR scan software is installed on your laptop. The software is available only on the installation disc that came with your printer. If you still haven't installed the software on your computer and you don't have the installation disc, please contact Lexmark Technical Support Center to request for one.
If you were able to scan documents before using your Lexmark printer, it could be just a slight communication issue. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Dec 01, 2011 | Lexmark X5650 All-in-One InkJet Printer
HP Deskjet f4435 will print, but won't scan. Orange light blinks
When I press the scanner button the top power button starts blinking but the machine does not scan. I have not used the scanning function on this machine before. Please help...you may need to reinstall your ..
Aug 16, 2011 | HP DeskJet F380 All-In-One Printer
The scanner won't scan when you press the button. how do i fix it?
Try to remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. Close the cover. Disconnect the printer from the power source. Reconnect after 10 seconds. When the printer turns on, reinsert the cartridges and load some paper. Try to scan again.
Since the scanner hardware is also used for the Copy function, can you try to make a copy and see if you encounter any problem.
May 11, 2011 | Lexmark X2670 All-In-One Printer
My Lexmark all in one won't scan the entire document. No matter what size setting I put it on (I get the 'most' scanned on Automatic, but it is still less than half the page.)
Do you get the same result when making a copy using the Copy button on your printer operator panel? Try to remove the power adapter from the printer.
Wait at least 10 seconds before replugging the power adapter. This will give enough time for the printer to reset itself. When the printer turns on, reinsert the cartridges. Load some paper and try to make a copy or scan again.
May 05, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
How do I copy documents?
Unfortunately you won't be able to copy directly from this machine since it's only a printer. If you have access to a scanner you can use it to scan your document, save it to your machine, and then print it on this device. Otherwise you'll need to purchase a Multi-Function machine that includes a Scan/Copy feature.
May 05, 2011 | HP Hewlett Packard LaserJet 1018 Printer
Canon PIXMA MP610 InkJet Printer Logo
417 people viewed this question
old marine
old marine
