Question about Gateway One ZX430001e
Gateway zx4300 has blinking lines
Screen is flashing white, then lines color; red, blue, green, and purlpe
2 Suggested Answers
kamal1984
  • 1383 Answers
SOURCE: blank screen
When u power up the computer press "del" or F2 key then check your harddisk is detected or not.
Also load optimal defaults settings.
then restart the computer press F8 key then enter in enable vga mode.then change screen resolution to 1024*768.
Please let me know.
Posted on Jun 06, 2009
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
I am looking for a diagram for the wireing harness on a sony cdx-c5000x.
yellow 12v constant, red 12v switching,black ground,white left front +, white/black left front -, gray right front +,gray/black right front -,green left rear +, green/black left rear-,purple right rear +, purlpe/black right rear -,blue power antenna,blue/white amp remote
Sep 22, 2010 | Car Audio & Video
Wiring diagram for sony xplod car cd player
yellow 12v constant red 12v switching black ground white left front + white/black left front - gray right front + gray/black green left rear + green/black purple right rear + purlpe/black
blue power antenna + blue/white amplifier turn on +
Sep 02, 2010 | Car Audio & Video
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
How do I get rid of purple and green wiggly lines? The black screen that appears when switching between channels was green a couple of weeks ago, that problem stopped after I unplugged the set for a while....
You have a bad LCD control board,It overheats and causes colored lines,screen to darken,or the color go floresent. Also check the power supply for bad caps.
when you have it apart.They usualy go bad on these tv's. It will cause the tv to take longer to come on.Or you have to hit the power button several times to get it on.
Oct 26, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Help with kogi F9AH screen
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Nov 23, 2007 | GVision F9AH-TG Television
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
Gateway One ZX430001e Logo
223 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
