Question about Kenmore Dryers
Kenmore 3397244 G is not heating
Still works, just doesnt heat up nor dry clothes. have no clue what to do and low on money
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite HE4-lots of heat, clothes not drying
Poor drying problems with dryers generally are attributed to clogged ducting. You have probably heard this before, but the first (and least expensive) fix for any dryer with long dry times is to check the air movement. As well know, dryers require good air flow to ensure proper drying. Now, when you said the air movement is strong, were you checking it at the air vent exhaust outside, or were you checking on the back of the dryer? An easy way to tell if there's a clog in the ducting, or a clog in the dryer is to run one load with the dryer vent disconnected from the back of the machine. Only run one load like this. Not a good idea to blow hot moist air into an enclosed area of your home over a period of time because it can cause mildew problems. If the dryer blows freely and your clothes dry faster, you know you need to check the ducting from where it connects to the wall to where it ends at the exhaust vent. Often it is not enough to just clean the lint trap and the outside vent. You need to check what's in between them as well. Mice and birds are notorious for building nests in dryer vents and clogging them up. Now...if the dryer is blowing poorly at the exhaust port on the back of the dryer, you will need to remove the door kick panel under the door and remove the vent duct housing to get to the blower fan. Make sure you unplug the dryer before attempting this. There are live voltages present even with the dryer turned off. Lint can get trapped in vent housing and restrict the movement of the fan, which, in turn, will cause poor air movement and longer dry times. Last of all, take a temperature reading at the exhaust port on the back of the dryer. A good temperature reading is roughly 140 degrees F. If the temperature is too low, you may have an operating thermostat or high limit thermostat malfunctioning. Check your vent ducting, first and let me know if you need further assistance. I hope this helps you.
Posted on Aug 04, 2007
SOURCE: Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Posted on Oct 29, 2008
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
localwonder
  • 6784 Answers
SOURCE: kenmore elite , no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jul 27, 2009
milten1
  • 1304 Answers
SOURCE: my kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Posted on Oct 05, 2009
My dryer doesnt heat. I checked the voltage, and ran through all the diagnostic tests to try to get an error code. Everything works fine when in the test mode. Figuring that all was well i went back to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 17, 2011 | Kenmore 84072 Electric Dryer
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
My kenmore Electri Dryer is humming while drying.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.hope this help you out sincerely D.Jones
Jun 08, 2010 | Kenmore 64672 Electric Dryer
Gas Dryer drying clothes cold, no heat...
if it heats for a while and then no heat you have bad gas coils,when the coils are on there way out they work until they heat up then they cut out,see if you have heat when the dryer is cold,if it is change out the gas coils
Jan 25, 2010 | Kenmore 63942 Dryer
Dryer end cycly without cloths drying. Doesn't
IF DOESNT HEAT UP ANYTING CHECK THE THERMAL FUSE AND REPLACE IT IF NECESSARY!!!
IF IT DOES HEAT UP A LITTLE IS NOT THE FUSE!! IT COULD BE THE EXHAUST PIPE (DUCT) CHECK THAT IS NOT BLOCKED OR CLOGGED!!!!
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
It doesnt have any heat
Make sure it's not on air fluff. Other than that it could have a bad element or a tripped safety fuse. Make sure your vent is clear regardless.
Aug 06, 2009 | Kenmore Dryers
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Dryer spins fine but no heat
First and most importantly you have to be sure the venting is completly clear of debris and lint. Then remove and inspect the heating element and all thermostats with a multi-meter. Unless your familiar with this type of procedure you might consider calling a technician. Your wasting too much energy and money drying clothes for 2 hours. Technician much cheaper in long run. Good Luck tatau.
Dec 09, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Dryers Logo
681 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
