Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
How do i fix a duet dryer that takes too long to dry
My duet dryer is taking twice as long to dry as it should
I pulled apart the back of my dryer to access the heating element. I noticed I have a break in one of the coils. So, that means I need to buy a new one. The thing I noticed is that only of of the terminals at the bottom of the heating element has a plug on it. There are no additional wires inside the dryer that could have come off so I am a little confused as to if i new coil will work.
I watched a video online and it clear shows both terminals being connected. Anyone have any advice?
Posted on Feb 21, 2012
the dr
  • 447 Answers
SOURCE: whirlpool duet electric clothes dryer
The vent is clogged.
Posted on Nov 23, 2007
SOURCE: My whirlpool duet dryer is taking 3 cycles to dry????
have you checked your lint trap to make sure that it is clean after every load? Also the lint vent to the outside may be clogged and will not let the dryer vent like it should. This is dangerous. So check and replace if needed.
Posted on Dec 29, 2008
  • 262 Answers
SOURCE: dryer not drying
look at the vent outside and see if it closing or even has a cover this allows cold air inside the dryer and cause it to take longer to dry
Posted on Jan 09, 2009
aasc
  • 1606 Answers
SOURCE: My whirpool dryer (Duet) seems to always take (2)
Your dryer may be pushed too far back , causing the vent hose to kink , behind the dryer . Also , check the outside vent airflow , and check the lint screen holder , for any peeled off lint , which could also be blocking the outside air flow .
Posted on Oct 25, 2009
Testimonial: "Thanks.......I will check all those items"
  • 128 Answers
SOURCE: I have A whirlpool duet dryer and it is getting
I would check behind the dryer to see if the vent is crushed. Everytime you lean against the dryer there is a chance of crushing the elbo on the back of the dryer restriction air flow. Very common problem.
Posted on Dec 29, 2009
My Kenmore 6.7 cu ft he2 Super capacity electric dryer is taking twice as long to dry. no error codes
It sounds like a connection problem with one of the heating elements, or perhaps only a clogged input or output hose from the dryer. Either of these could cause the problem...also, a burned out electric element.
Jan 15, 2013 | Kenmore Dryers
Dryer takes twice as long to dry clothes.
Did you check the outside vent? Those get clogged as well.
Oct 27, 2012 | Whirlpool LER7646J Dryer
In the last few months (5 yr old machine) the dryer takes forever to dry normal loads. I usually have to run it twice to get permanent press type clothing dry. Is this normal wear on the machine, or is...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Apr 03, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Why is my whirlpool duet gas dryer is take too long to dry? even the bed sheets.
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Dryer Maintenance
heatman101
Jan 14, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
My clothes are leaving the dryer with streaks (maybe 4 or 5 inches long) that appear to be burn marks. Closer inspection of the inside of the drum shows that the back "wall" of the drum is off-center...
I have the same problem and read somewhere to replace the felt belts. We have done this twice and still getting the brown marks. I have found using Goo Gone and/or Dawn dish soap and scrubbing with a brush will take most of the mark out, re-wash and HANG to dry. I'm still looking for a permanent solution to this problem, as much as these dryer cost and you can't dry white clothes???
Jun 28, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 | Dryers
Whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Mar 03, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Dryer not drying
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal De
