Question about Toshiba Satellite U305-S7448 Notebook
Webcam Can i take pictures on my Toshiba laptop webcam? I don't think there is a program for it.. but it does work with MSN. Help?
  • omir Nov 20, 2008
    Im using M305-S4820Toshiba but i can't use my built in camera for taking a pictures and my microphone when i'm using my yahoomessenger... i hope you can help... I had chicony usb 2 camera... thank you
I have a new webcam - mikomi DC - 7130 & its installed on my laptop but will not show up on my msn, can anyone PLEASE help?
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Feb 18, 2010 | Intel Easy PC Camera Webcam
How do activate the webcam on this acer laptop it says it has one built into it but i cant get to come up
Acer uses its own program called Crystal Eye to run its webcam. If you don't have it, go to Toshiba support drivers and put your model of laptop in the search box and then pick your operating system and it will give you a menu of the available drivers and applications for your system. You need this program to work the integrated webcam.
Jan 05, 2010 | Acer Aspire 3610 Notebook
My bulit webcam is apperaing fuzzy and i have not a clue why. how do i fix it and what is the proper program to use it? the model of my computer is toshiba satelie L350D
Sounds like it is dirty and needs cleaning. It is new? Be sure to remove the plastic cover. If not, use a qtip with alcohol to clean it.
There is no proper program to use it. You can use it with MSN messenger, Yahoo messeger, etc. Just be sure to get the drivers installed.
Nov 26, 2009 | Toshiba Satellite L350-ST3701 Notebook
My acer webcam works on msn, but not for leisure use.
Get the software here >>>>>>>>
http://www.versiontracker.com/dyn/moreinfo/win/143652
Regards.
Aug 21, 2009 | Acer Extensa 5620-4677 Notebook
Problems with web cam on Toshiba netbook nb200
update the program ...if the webcam works fine on other IM programs ..it means that the msn is the problem ...
Jul 24, 2009 | Toshiba Satellite A205-S4617 Notebook
My webcam won't work on msn
download the new windows mesenger here http://messenger.live.com/ this would be easyist to fix the problem. or 1. Navigate to the following folder:
Windows XP/2000/Vista (32-bit): C:\Program Files\McAfee\SiteAdvisor
Windows Vista (64-bit): C:\Program Files (x86)\McAfee\SiteAdvisor
2. Right-click on the file sasets.ini and choose Open With, then select Notepad.
3. Locate the section titled [msnmsgr.exe].
4. Change Enabled=1 to Enabled=0.
5. Click File and select Save.
6. Close sasets.ini and restart your computer for changes to take effect.
Jun 11, 2009 | Sony Computers & Internet
My logitech webcam only works for msn only and not for yahoo im
you also need to set it up in your yahoo program
do you know how to do that
each webcam program needs setup seperately
Jan 23, 2009 | Logitech Webcam
Webcam not workin on msn but workin on the notebook how do i get it to show up on msn messenger
Can you see an option of Live Update on the Acer? you will need to run that, download all updates, reboot & it should work ok for you then. Hope that helps. Merry xmas.
Dec 10, 2008 | Acer Aspire One PC Notebook
Toshiba Satellite A 215 - Webcam Doesn't Work
sir my all softwares r installed properly & im using vista stater. my web cam is not able 2 b detected
Jun 30, 2008 | Toshiba Satellite A135-S2276 Notebook
I can't get my camera to work with my messenger program, can you help (AOL, Yahoo, MSN)? cant get web cam to work on yahoo mess says webcam not connected
Ok, a few questions for you first...
  1. Has the cam ever worked?
  2. Does it work in any other software?
  3. Make and model of webcam.
Let me know. Thx! =)
Mar 26, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite U305-S7448 Notebook Logo
85 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
