Question about Takamine Music
I need cp-100 replacement under saddle pickup for a takamine eg531sc
My email is rcbradley@ymail.com my phone # is 541-551-0586
My Ibanez acoustic electric has very weak volume and makes a constant white noise hiss when plugged into an amp or sound system. Batteries are new as is the pre-amp and under saddle piezo. Ideas?
It will be either the saddle pickup or the guitar pre amp. If you unplug the pickup and the hiss is gone, there was your fault. Otherwise fit a known good pre amp.
Feb 02, 2017 | Ibanez Music
Takamine TP4T Preamp blinking
It does sound to be fried but, you really don't have to replace it with the same exact model, look for an upgrade, I'm sure that manufacture and many others have one better. If it were my guitar, I would definitely think of it as upgrade time. The pickup is probably ok knowing that it can handle heat better due to its location and materials.
Mar 09, 2014 | Takamine 1 NEW Takamine EG350SC G-Series...
I need a new tuning peg
You will have the best luck with the OEM, I would contact them.
http://www.takamine.com/
They have good online documentation, I think you will find them to be very helpful.
Apr 01, 2012 | Takamine G Series EG5013S VFT OM Maple...
Where to buy TP4T pickup
You can try repair it. They are pretty basic. I would look for poor solder connections, and reflowing all solder joints in it would be prudent.
The hum is likely from a gain stage with a bad solder joint on the input isolation capacitor. Also check other wires and check for bad solder connections on the pickup connections as well. It can even pick up hum through a bad shieid/ground connection in the jack on the guitar
Mar 29, 2012 | Takamine 1 NEW Takamine EG350SC G-Series...
Hi ive had a fishman pick up installed under saddle of my accoustic guitar its fine but something is wrong becuase wen im slapping the strings and tapping guitar the sound goes very quiet for around 1...
It is possiblle that the sudden pulse from the pickup due to tapping is saturating the input of your amplifier, and that is what actually kills the signal. Try this into a different amp as a test. Once you do the test I can offer some suggestions to try.
Apr 23, 2011 | Fishman PRO AG-094 Under Saddle Acoustic...
I've got Takamine JJ 325 My problem is backround noise - What can i do ?
Acoustic guitars pickup noise almost like a microphone. You have to prevent the sound from reaching the guitar or get a solid body guitar.
Apr 11, 2011 | Takamine JJ325SRC-12 John Jorgenson...
Hi! My TP-4T preamp on my Takamine EG124C works only when tuner is ON. After tuner automaticallt turnes off, the sound stops. Please help!
Hello,I am a guitar tech in Nanaimo,BC,Canada and have run into this problem before.Simply replace the Takamine output jack [where the guitar cord goes into] 3 screws and solder,and it will work fine again.The jack has a switching mechanism in it and when it fails it shorts the output out.The jack is available at most Takamine dealers or Allparts http://www.allparts.com/SearchResults.asp?searching=Y&sort=7&search=jack&show=20&page=5
Mar 06, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
Problem with the pickup sound on the 'g' string on my epiphone les paul standard
Hi ! Must be a problem with either the nut or the g-saddle in the bridge of the guitar.
Good luck , Stefan from Sweden
Nov 10, 2008 | Epiphone Music
Music Logo
273 people viewed this question
Top Takamine Music Experts
armandog07
armandog07
Ted Maxwell
richie46
Are you a Takamine Music Expert? Answer questions, earn points and help others
