SOURCE: Remote Control Codes for Phillips TV using Jumbo Remote Control
TRY THESE CODES FOR PHILLIPS:
062 204 184 208 205 206 207 004 288 003 008
068 075 086 087 141 189
SOURCE: Old Samsung Tv Problem CT-5029v - Channel Auto Program
You might try a oneforall remote instead of a whatever :) They support a lot of old and new tv's.
SOURCE: direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
SOURCE: time warner cable, LG TV. volume control
if they are the only buttons that do not work i would say the pcb needs to be cleaned
