Question about Numonics Digital Pen
Looking for old model numonics digital pen . with old style flat connection
Was for ol digitizer table numonics . CNT/OPD-I . year 2000 Two button digital pen .
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
I cnt unlock my kosaco tablet.it will come on but i cnt do anything else
This sounds like a digitizer failure. The only possible fix, aside from replacing the screen/digitizer (which is usually cost prohibitive on android tablets), is to do a hard reset. Since you did not mention the model, go here Support Manuals (http://www.kocaso.com/manuals/) and select your model. Find the reset button location and use a paper clip to insert and press the button. If the tablet reboots and the screen is still unresponsive, you will probably need to contact the manufacturer.
May 01, 2014 | Tablets & eReaders
Help! I have aZS3 panasonic camera and items such as ballons or peoples hands are very very blury..someone did change some of the settings on the camera....now some of the pictures look ok...as long as...
Most cameras have a reset button that you need a pen to push, Look around the batterys or remove the batterys and behind them should be another "Watch" style flat button battery for holding the date and time romve it and wait a min then put back in and it's memory cleared.
Mar 15, 2014 | Panasonic Cameras
NEED WIN 7 DRIVER FOR GTCO CalComp Drawing Board III
Drivers for GTCO, GTCOCalcomp or Calcomp digitizers for Windows XP, 7 and 8 can be downloaded from this url:http://www.interworldna.com/GTCO/gtco-drivers.php
If you are trying to use your digitizer with AutoCad these drivers will not work and you will need to buy a driver from VTABLET.com (They provide a 30 day free trial/demo) only works with serial RS232 interface. If your digitizer uses USB then you will need an interface kit for your specific digitizer to convert it to RS232. Most new digitizers come with USB, some have serial but require you to buy an interface kit. Contact your Digitizer supplier.
If your digitizer is a GTCO, GTCOCalcomp, Calcomp or Summagraphics brand, try these guys: http://www.interworldna.com
They do not know about any other brands. Wacom contact Wacom, Numonics contact Numonics. If you have Mutoh or Science Accessories or any other brand you are on your own as those manufacturers have all gone out of business as far as I know.
Dec 06, 2013 | GTCO CalComp Drawing Board III 34180...
I have a older model Samsung flat screen.That has pen stripped lines going down the screen.How do i fix it?
Its going to most likely be a board that process's signal and digital information---if its real old (over 3 years) the board may not be available or may be expensive.
If I was you I would GOOGLE the model number with the word "parts" or circuit boards and get an idea of what is available for it and at what price.
Mar 17, 2012 | Samsung Televison & Video
I have a roper dryer but don't know what year it was made. the model number is REX4635EQ2 the Ser. number is MK0775343. What year model is this?
The second digit/character (K) indicates the year and the 2-digit numbers (07) immediately next to it indicates the week the dryer was made. The year code K is 2000 and your dryer was made on the 7th week of the year 2000 or February 2000. Click on the link below for the table of year codes of Whirlpool and Whirlpool-made appliances.
Determining the Age of Whirlpool and Whirlpool-made Appliances
Mar 30, 2011 | Dryers
Dvi port specification
The DVI [Digital Visual Interface] is a standard for high-speed, high-resolution digital displays.
Below is a 24 Pin DVI Female connector seen at the Computer. The connector diagram and pin-out table show a DVI-I Digital and Analog [RGB]; 29 pins [modified D style] connector. A DVI-D Digital only connector with 24 pins [modified D style] looks about the same with out the 4 analog 'C' pins.
The DVI interface is found on a number of devices including TVs, Computers, Monitors, and Video cards.
Digital Visual Interface [DVI] was developed by the Digital Display Working Group (DDWG).
Note that the Digital Display Working Group disbanded around 2006, so don't expect an up-grade for DVI.
Digital Video Broadcasting/Digital Audio-Visual Council (DVB/DAVIC),
developed by DAVIC [inactive] and DVB [dvb.org].
Adopted by European Telecommunication Standards Institute (ETSI) and
International Telecommunication Union (ITU)
DVI has a number of different types connectors:
DVI-D Digital only connector; 24 pins [modified D style];
DVI-A Analog only; [modified D style], I don't think this is part of the standard
DFP Digital Flat Panel, Digital only connector. Pinout is listed on the DFP page
Styles of DVI Connectors
Jan 13, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Noise coming from tank
Yours is a DOT type tank (portable not fixed)
What is the noise? Is it gas coming from the tank to the burner? Hissssssssssss Are you properly connected? Is this a OPD equipped tank? Is there a hole or crack in the hose letting the gas out before it gets to the burner?
Do not examine it with a match!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If your tank is very old, you may not have a OPD equipped tank (is the handle three sided?) Yes = OPD No = old style. Only OPD equipped tanks can be filled in the USA. Old style tanks can leak if not properly connected.
New OPD tanks will not let gas out unless there is something properly connected to the tank. You are NOT fooling around with the 80% valve are you? If you are - STOP. (small screw on the right hand side of the connection fitting.)
If there is any fault in the equipment, connector, regularor, hose or any fitting - get it fixed! One gallon of liquid propane becomes more than 350 cubic feet of highly combustible gas. If it leaks out and gets ignited, at least it will be quick! Dont become the entertainment!
Any parts that are questionable ... replace them!
Please seek additional assistance from your professional propane supplier.
Thanks for your interest in FixYa.com
May 31, 2010 | Weber Genesis Silver B Grill
I can't get the gas to flow on certain propane tanks and when I do it's not as hot as it should be. I have already replaced the regulator for th same problem. Multiple bad tanks??I have a Lynx L42PSFR-1
Nope
If you have old style tanks ( pre OPD valves) and an OPD style connection they sometimes have problems
If you have new style tanks the male fitting must extend far enough in to the tank fitting to press open the OPD valve Meaning the fitting needs to be tight.
I have had several tanks that would not work
Look inside the tank valve and you will see a small brass ring with 2 slots cut in it
These after repeated fillings will work loose
With a small screw driver you can gently tighten this ring
If it still does not work right take the tank to a good propane shop and they will have the proper tool to tighten this ring
The ring backing off will not allow the valve to completely open
Mar 07, 2010 | Grilling
GTCO Calcomp Drawing Board III connects but won't function...
I HAVE CALCOMP DRAWING BOARD II BUT MISSING ALL CONACTION FOR IT ( CHARAGE , POINTER , 1/O )
PLEASE WE NEED PAY THIS CONACTION FOR RUN
MY EMAIL SAYEDTEBBIN@YAHOO.COM
Jan 06, 2009 | GTCO CalComp Drawing Board III 34180...
Numonics Digital Pen Logo
101 people viewed this question
Top Numonics Computers & Internet Experts
David Payne
David Payne
Are you a Numonics Computer and Internet Expert? Answer questions, earn points and help others
