Question about Troy Garden
Briggs straton 6.75 starts to die..if i open the fuel cap it runs again. also wont start when hot. twenty minutes or so it's fine again.
    Sergeant:
  • 316 Answers
Hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a clogged vent, this is a small thing but a big problem,,hope this helps, ``
Posted on Feb 20, 2012
  • 110 Answers
SOURCE: lawnmower with 5 hp briggs ad straton
It sounds like the choke is comming on or you are prinming it again? Dont prime a warm engine
Posted on Nov 17, 2009
Biggdex35
  • 333 Answers
SOURCE: 7Hp OHV Briggs & Straton Craftsman Front Propelled Smokes
Sounds like it is the valve seats. However normally it will stop smoking after is runs for a while if that is the problem. Does it run good? Because if it isn't the valve seats then it is the rings. Or a big scratch in the cylinder wall. Then most of the time it will loose compression. If it isn't smoking real bad then you can get an additive to put with your oil that will make it stop, maybe? It is about ten dollars and you can get is at most autoparts stores. It will just take a couple ounces of it. Follow the directions for how many qts of oil you have. After you change the oil in the motor take a magnet and run it through the oil and see if there is pieces of the rings in it.
Posted on Jul 12, 2010
SOURCE: i've been trying to start
I had the same problem. It turned out to be a blocked carby and the way to fix is as follows;
- remove air filter
- start mower (assuming it now starts)
- place open hand over carby hole and then remove. The force of the spinning blades will **** through the blockage.
You may need to prime it first.
Hope that helps.
Posted on Apr 02, 2011
  • 5370 Answers
SOURCE: It will start and almost
First confirm that Oil, gas, spak plug and air filter are good. Also check the bowl bolt. The jets feed through the center of this bolt, there is a tiny hole in the center, that feed from two more holes near the base of the bolt head.If the hole is clogged or plugged it will not let the engine to start and run.You can use a small jet drill to clear the hole. The brass jet on the bottom center of the carburator float bowl gets clogged with sediment.When you take it off a bread tie wire & come carburetor cleaner are all you need to clean the jet. Take care when putting on the bowl as the sealing gasket (large o-ring) must seal perfectly otherwise the primer bulb will squirt fuel out of the bowl instead of priming the carb .A 5/16", 3/8" & a 1/2" socket (& ratchet) carburetor cleaner & bread tie or garbage bag tie wire are all you need to complete the repair. It helps if you drain the gas tank before you begin. Or you can just pinch off the line with a vice grip. ---------- Drain the float bowl - it's possible that a drop of water has found it's way in, blocking the jet. While the bowl is off, check that there is a decent flow of fuel.
These engines are prone to breaking the inlet pipe that runs across the top of the cylinder from the carb to the inlet port. This will cause similar symptoms of it is cracked.
--------- This should help.Keep updated.Thanks.Helpmech.
Posted on Apr 07, 2011
al_kupchella
  • 843 Answers
SOURCE: trying to replace the pull cord on a toro m#20028
Yes, its most likely spot-welded, that's not mean to be taken apart there. You have to remove the larger cover that includes the part that is spot-welded on. But first you will probably have to remove some large plastic parts. Just hunt for the screws, there will be several. Some might be hidden under labels. Good luck, Al K
Posted on Jul 06, 2011
After hot engine wont start and smells like gas
Most likely causes are bad engine coolant temp sensor OR leaking fuel injectors. Bad engine coolant temp sensor will give computer false reading and computer provides wrong air fuel mixture. Leaking fuel injectors will load the engine with raw gas--just like flooding it. Try pushing the gas pedal to the floor and holding it there when cranking when hot. That forces the computer into "clear flood" mode and it shuts off the injectors. If it starts up with pedal down, that would be a sign of leaking injectors.
Jul 21, 2017 | 1999 Dodge Intrepid
Engin runs fine for about twenty minutes then quits. oil level is full
try and run it with a loose gas cap the vent could be clogged then check for spark when the engine dies or even better get a inline spark tester then you can see it when its dieing
Jul 12, 2012 | Garden
Cub cadet dies 20 minutes after starting
Slacke off the fuel filler cap when it starts to die, if it picks up again the fuel tank breather is blocked.
Apr 13, 2012 | Cub Cadet Garden
1995 Buick regal sputter stalls in hot weather
how do I change a fuel pump on a Buick electra park avenue?
Jun 12, 2017 | 1995 Buick Regal
MTD Briggs and Straton 22" Mower Wont Start Brand
You probably have dirt in the carburetor. Or, you may have water in the fuel. As long as you have spark, then there is nothing else that it could be. Unless you have taken it apart already; have you done this?
Jim
Aug 16, 2011 | Mtd 22" Yard Machine Push Mower
Briggs and stratton 6.5 Ohv dies after running for about 10-15 minutes. I let it sit awhile then runs again. This is a vertical shaft lawnmower engine.
This is a classic symptom of a blocked fuel cap vent. Next time it dies, remove the cap, wait 30 seconds or so (for carb to re-fill), then try to re-start. If it works, replace the cao.
Aug 07, 2010 | Briggs & Stratton Garden
Engine hesitates and dies when hot, restarts fine, then dies agai
Check the fuel pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Craftsman Garden
MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Jul 15, 2009 | Mtd Garden
Garden Logo
353 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
