Question about Refrigerators
Crosley cs21b5d meat keeper freezing - Refrigerators
2 Suggested Answers
kingmzzz
  • 5 Answers
SOURCE: About once a week the
There is air getting into the freezer from where the ice and water come out. The problem is probably the solenoid that controls the flapper for your ice. Open your freezer and try and look through the flapper and see if its open. If it is check and see what the problem is. If the solenoid is corroded and looks bad replace it. If the mount where the flapper goes is broken replace that.
Posted on Dec 30, 2011
Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
Bottom freezer fridges are especially susceptible to
  1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
    • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
    • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
    • Replace plate and allow 24 hours for inside temp to stabilize.
    • Adjust top temp setting if needed to maintain safe temp level.
    • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
  2. Airflow blockage through the crispers and meat keepers.
    • Remove crispers and meat keeper as well as glass cover shelf.
    • Find cooling passages between crispers and at midline of meat keeper.
    • Remove any buildup of air blocking debris.
    • Wipe up fridge box floor beneath meat keeper.
    • Reinstall glass shelf, meat keeper, and crispers.
    • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
Mar 16, 2015 | Amana Refrigerators
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
The refridgerator side of the unit is not staying cold enough. It is running about 48 degrees. This happened about 2 months ago, and I cleaned the coils and turned the refridgerator side of the thermostat...
If your model is the GS5SHAXN it has an electronic control for the temperatures. Not the typical thermostat. If it malfunctions either complete failure or an unstable control of temperatures. The part number is 2255233 at one place and part number 1016379 at another but the basic OEM number is the first one 2255233. I am going through some repair manuals to see if its possible something else might be causing this. I will return as soon as I can to see if that is the only reason that may be causing this. But with electronic controls I believe that it may be 48 degrees in the fresh food compartment is not safe. These controls are located in the fresh food section and connect with the temperature control. I'll be back soon, Sea Breeze
Nov 14, 2009 | Whirlpool GS5SHAXN Side by Side...
Meat keeps freezing in my meat drawer.Any thoughts on how to adjust the settings
There may be a separate control for the meat drawer down where the drawer is. If not, you use the fridge temp control. Make sure the vent between the freezer and fridge is opening and closing when you adjust the temp.
Oct 17, 2009 | Kenmore Refrigerators
My Frigidaire refrigerator side by side is freezing drinks.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Frigidaire FRS26H5AS Side by Side...
Water is not cooling
Hi: This Wide by side is like all other side by sides as to how it stores the water. Storage will be behind the crisper or meat keeper in the form of a coil of tubing or a bladder to store the water. Pretty simple. The length of tubing running from the storage to the dispenser will not be chilled. Some refrigerators do this better than others. Try setting the ref. or meat keeper a little colder. Watch your vegetables so they don't freeze. Rare, but it's possible... Older homes (before dispensers,) when fridges just had ice makers, would tap into the hot water line for ice to freeze faster and be clearer. I know this sounds crazy but it's true. I lived in an older home and in the winter the hot water would always freeze first. I know this solution sounds lame but there really is nothing much to go wrong with the water chilling. Pull your meat keeper out and look at the reservoir and see how cold it is. Good luck, Jeff
Jun 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Vegetable & Meat Tray Freezing on refrigerator
you have the freezer set too low. set it at -02 degrees and then turn up the adjustment for the meat tray and the humidity up on the vegetables. let me know if this helps.
Jan 08, 2009 | Kenmore Refrigerators
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
May 21, 2008 | Frigidaire FRS26ZSG
Amana bottom freezer model #BX21TW purchased in 1996
this particualr refrig is notorious for this. check your controls ( your freezer control as well set to 4 max) any higher and the refrig is running longer, generating more cold then needed, behind the left hand crisper is a few slots( the fresh air return) by default the coldest spot in refrig, i usuallly would reccomend to my cust not to keep high water or thin walled vegies in there such as carrots cukes tom and lettuce, perfect beer and fresh /frozen defrosting meat to be though, if you ever looked at the newest bottom freezers they've pushed up the drawers and added a deli pantry, running the width of frig
Feb 27, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
