Question about Frigidaire Affinity ATF8000FS
Clean filter on the frigidaire atf8000fs1 - Frigidaire Affinity ATF8000FS
ATF8000FS1 washer is stuck in pause. Any suggestions?
Hi friend, thanks for your inquiry!
If your washer continues to display an error code of "PAU" it could be an issue with your door lock but if the door strike is not sitting properly within the latch your washer will continue to provide the error code "PAU". Additionally, if your control panel is registering that the door is closed you may continue to experience the "PAU" code. I would recommend having a professional come and properly diagnosis your washer to prevent any unnecessary part purchases. I hope this is helpful. -OOS
Oct 12, 2014 | Frigidaire Affinity ATF8000FS
Error 66 on frigidaire affinity washer ATF8000FS1
Hello Jacqueline Sanchez, thank you for your post!
I understand that your Frigidaire washer is showing you an "E66" error code. I show that "E66" stands for the heating element relay failure, which means you could be experiencing an issue within your heating element or main control board. I would recommend performing a reset to your appliance which you can do by flipping the circuit breaker for roughly ten minutes. If that does not correct the issue I would recommend having a technician come out to properly diagnose and repair your appliance. -Matt
Aug 16, 2014 | Washing Machines
ATF8000FS1 will not start and flashes error and no spin
Hello Tim Houk - Is the washer making a humming noise? If so, either the drain hose or pump is clogged and needs cleaning. Will the drum manually rotate (when it is not in use)? If it does not, then the drum could possibly be unbalance and/or have a broken shock/bearing. Verify that the door is securely latching or it will also prevent the washer from starting. I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 31, 2013 | Frigidaire ATF8000F Front Load Washer
Cleaning the filter on frigidaire ultraquiet dishwasher
Hello Friend,
I see that you are wondering how to clean the filter on your Frigidaire dishwasher, model# FDB1050REC. The inside of your dishwasher is self-cleaning with normal use. If needed, clean around the tub gasket area with a damp cloth.
The filter is self-cleaning. A glass trap located in the center of the filter is designed to collect pieces of broken glass, straws, bones, and pits. To remove this glass trap, grasp the handle, lift out, empty it and replace it. Hope this helps.
-Best Regards-
WP
Feb 14, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
I have an ATF8000FS1 front loading washer. after wash cycle(when water drain out) It smell like sewer! I leave the door open after use and when not in use. How to solve this problem ........ Please let me...
I recommend purchasing "Affresh" for front loading washers. It is used to clean and freshen up your washer. It can usually be found at any major brand grocery store
Sep 12, 2011 | Frigidaire Washing Machines
The door on my fridgidaire atf8000fs1 sags so it doesn't shut correctly. I've had to order a new door striker since the last one broke off. How do I adjust it so it hangs correctly?
Frigidaire washer door sagging so strike and door lock not lining up correctly. After a period of time front load washer doors tend to start to drop below normal position. The glass in the front doors are very thick, heavy and only supported by plastic inner frame. This combined with continued opening and closing will over time make your front load door start to sage. Fortunately Frigidaire makes a door shim kit for this problem.
After you have ordered and received the shim kit part #137309800. Start with removing the three screws holding the door to the machine. Lay the door face down on a soft surface as to no scratch the front of the door and glass. Remove the screws securing the outer frame and with a very small flat screw driver shim it between the inner and outer panels. Make sure to note the position of the frame and glass. Next remove the inner plastic frame, you should have access to the hinge at this point. Install the shim kit according to the instructions that come with the kit. Reinstall the hinge, inner frame and screws. Install the door back onto the washer, your door strike and lock should line up in the correct position at this time.
i got this answer at http://www.appliancerepairquestion.com/2013/04/frigidaire-atf8000fs1-washer-door-not.html
Jun 19, 2011 | Frigidaire Affinity ATF8000FS
I have a frigidaire front-loading Affinity model #atf8000fs1 washer with the stack kit placing the dryer on top. During the spin cycle, it dances frantically and when I canceled the cycle and opened the...
Go to www.repairclinic.com and enter atf8000fs1. You will see a list of common replacement parts (including the gasket) and may be able to view a generic Frigidaire video showing disassembly.
Apr 16, 2017 | Frigidaire ATF6000ES Front Load Washer
I have an affinity washer, stackable, model atf8000fs1, it runs for 15 minutes and quits, help
sounds like it has a bad timing cycle when it reaches that point the catch for the next cycle don't engage if this is the case the timer will need replacing i suggest contacting a service dept hope this helps
Aug 30, 2010 | Frigidaire Affinity ATF8000FS
Frigidaire Affinity ATF8000FS Logo
66 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
