Question about Roper Dryers
My dryer only works in one cycle
My dryer has five cycles but only works in one of them.
2 Suggested Answers
mrfixit3667
  • 262 Answers
SOURCE: Hotpoint nvl333gyoww gas dryer's timer stopped
the timer : if you use time dry the timer should always move and complete the cycle. if you use auto dry the timer uses a sensor to tell the timer to move. If your not getting any heat your sensor might not tell the timer to move.
So lets start with the no heat problem. First make sure your Vent is clear or just disconnect the vent and put a pair of womans stocking over the end to keep the dust down, This will ensure you do not have a blocked vent. ((( If you have a blocked vent on a gas dryer the safty sensor will shut off the gas valve and you will only get a little bit of heat))) Now try the dryer for small load, ((( if this solved your problem then you have a cloged vent )))
If this did not solve your problem then the coils on your gas valve in the dryer are probably bad.
Posted on Sep 02, 2010
My whirlpool duet dryer will not allow a normal cycle, it swicthes to delicate or bulky items
The control board is failing... I would use it until it will not dry clothes at all, then get it rebuilt for a fraction of what a new control costs. CoreCentric Solutions Reverse Logistics Core Collection and Recovery...
This place rebuilds controls and offers a one year warranty for about 130 bucks
May 22, 2016 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
MY HOTPOINT AQUARIUS TCM580 CONDENSER DRYER STOPS WORKING AFTER ABOUT FIVE MINUTES USAGE AND IN SO DOING TRIPS OUT THE MAIN HOUSE FUSE, WHAT CAN CAUSE THIS PROBLEM
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Oct 05, 2014 | Hotpoint Dryers
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Hi i replaced the thermal fuse in my kenmore dryer, started it up and it blew less than five minutes, what`s the problem any takers?
I would check your venting and also replace your cycle thermostat (4 wire therm) mounted right next to the thermal fuse. If you have a clear vent and new cycle therm this will take care of the problem. part number on the cycle therm is 3387134
Good luck _MJ_
Feb 06, 2010 | Kenmore Dryers
Whirlpool Dryer works on 1 cycle
Activate the diagnostic test mode to determine the functionality of the console buttons and the console electronics as a whole.
Diagnostic Mode Activation Procedure
  1. Make sure the machine is plugged and in standby mode. That is, no indicator light is on.
  2. Press the following keypad sequence within five seconds: More Time>Less Time>More Time>Less Time. All of the indicator lights should light up and "88" is displayed.
  3. Turn the cycle selector knob one complete rotation. When the knob points to a cycle, the corresponding indicator light should turn off and the machine should beep. Only a beep is heard when the knob points at the large spaces between the Automatic and Manual cycle groups.
  4. A beep should be heard when a button is pressed and the indicator light corresponding to it should turn off.
Any failure on the above tests indicates a faulty console board. Please let me know the result of the test for further troubleshooting and repair guide.
Jan 22, 2010 | Dryers
WHIRLPOOL DUET GAS DRYER CONTROL LOCKED ON.
Hold down the end of cycle signal botton for three to five sec that should turn that off good luck
Apr 11, 2009 | Dryers
Flame only stays on for five minuts. After start
the flame doesn't stay on the whole drying time, it cycles.The thermal fuse allows machine to work and heat up but the cycling thermostat directs the flame to come on and shut off. Do your clothes dry fine?
Mar 04, 2009 | Kenmore 60172 Electric Commercial Dryer
GE 5 cycle automatic heavy duty dryer
Turn off the electricity to the dryer.Try spraying the belt with automotive belt dressing inside that goes around the bucket.. If that does not work it is probably the bushing at the back of the dryer. you will have to remove the bucket to grease the bushing.if it is still good. judging by your details it seems good.But it could be dry.Needs lubrication.
Aug 21, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Alarm Keeps Sounding
I WOULD REPLACE THE TIMER OR POWER CONTROL BOARD
Dec 29, 2006 | Zanussi TC7102W Electric Dryer
Dryers Logo
51 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
